Environment block is too small
Recently, when I choose manjaro in grub, I get the error:
Environment block is too small.
Press any key to continue...
After I press a key, the loading proceeds as normal.
What I need to do to overcome this error?
According to google, there was a similar post a couple of years ago, however, I can not find it in the forum.
Thank you for the help in advance.
Hi. Probably the post about this error is on archived forum. See here:
https://archived.forum.manjaro.org/t/solved-what-does-error-environment-block-too-small-on-booting-up-laptop-mean-how-is-it-resolved/28026
The solution from that post is this:
sudo rm /boot/grub/grubenv
sudo grub-editenv /boot/grub/grubenv create
