Entire system randomly becomes unstable, windows flicker and sometimes stop responding
I had this exact same issue with OpenSUSE, and it was one of the unbearable issues that made me switch to Manjaro, and now I am observing the same thing on Manjaro too. That’s not very surprising, it just means that wherever the bug is, it’s in some piece of the system that is shared by both distributions, which again, is not surprising.
At random times, for no apparent reason, different applications randomly start to behave erratically, exhibiting any of the following symptoms:
  • rapid flickering of random regions of the screen. Usually a given rectangular region of the screen alternates between displaying the contents of the focused tab and the contents of another random inactive tab of the same application (but it’s not the entire contents of the tab, it’s a random rectangular region of it). I’m not sure whether the fact that
  • then sometimes the affected application will stop responding to mouse and/or keyboard. I always doubt whether the application is actually not responding, or if it’s “invisibly” doing all it is supposed to do, but part of the screen is frozen and it looks like it’s doing nothing. What makes me doubt this is that most of the time, the close button on the corner of the window will succesfully close the affected application.
  • another thing that makes me wonder if it’s just part of the screen not refreshing, as opposed as applications really not responding, is that when the affected application is playing audio (e.g. Chrome playing a video), the audio usually keeps playing. Again, for example, I may be playing a video in Chrome, and part of the image freezes or jumps pathetically, but the audio keeps playing. Although, now that I think about it, I was unable to pause the video by clicking on the pause button in one occasion. So, I don’t know, it seems a mix of unresponsiveness to input, and parts of the screen randomly freezing or “jumping”.
This happens especially often in Chrome, to the point that for a while I thought this was a Chrome bug, but just now I have seen the exact same thing happen in other programs.
What are the next diagnosing steps? I want to get to the bottom of this and turn this into a bug report to the right bug tracker.
provide system info:
inxi -Faz
use formatting, click this icon in editor: </>
  Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=1a215379-e21a-47c1-9171-67e1681ddbdf rw quiet
    udev.log_priority=3 pci=nocrs
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
  Type: Laptop System: LENOVO product: 81WE v: IdeaPad 3 15IIL05
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15IIL05
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    serial: <superuser required> UEFI: LENOVO v: EMCN14WW date: 05/11/2020
  ID-1: BAT0 charge: 42.0 Wh (100.0%) condition: 42.0/45.0 Wh (93.3%)
    volts: 12.7 min: 11.3 model: Celxpert L19C3PF7 type: Li-poly
    serial: <filter> status: full cycles: 13
  Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB2
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1300 high: 1302 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1300 2: 1300 3: 1300
    4: 1301 5: 1302 6: 1300 7: 1301 8: 1301 bogomips: 23968
  Type: retbleed mitigation: Enhanced IBRS
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: HDMI-A-1
    off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
  Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-5:4 chip-ID: 174f:118d class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
    s-diag: 581mm (22.86")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Samsung S24D330
    serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 note: disabled model: BOE Display 0x0812 built: 2018
    res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa
    22.1.7 direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: yes
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
  Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
    type: USB driver: r8152 bus-ID: 1-9:5 chip-ID: 2357:0601 class-ID: 0000
    serial: <filter>
  IF: enp0s20f0u9 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-10:6 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 476.94 GiB used: 48.33 GiB (10.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFM512GDHTNI-87A0B size: 476.94 GiB block-size: physical: 512 B
    rev: 11010C00 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 48.33 GiB
    (10.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 12 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 235 Uptime: 30m wakeups: 1 Memory: 7.33 GiB used: 2.57 GiB
  (35.0%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1385
  libs: 360 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.22
first do this:
open this file:
kate /etc/environment
and add there this line:
QT_LOGGING_RULES='*=false'
save it… it will disable kwin/qt logs, so that they are more readable…
did you try different kernels? if no, install the 6.0.2 from system settings/kernel, reboot and boot with it and see if it helped…
if not provide logs:
journalctl -b0 -p4 --no-pager
but provide them after the flickering happened
Thank you so much.
No I had not tried other kernels.
I have now installed 6.0.2 and am running it. I will report back if the issue persists, or if a reasonably long time goes by without observing it anymore. I have also edited /etc/environment as you said.
Meanwhile, there were a bunch of warnings in the output when installing the new kernel.
Is any of them worth worrying about?
Below is the complete output.
The following packages will be installed:
linux60
Starting
resolving dependencies...
Packages (1) linux60-6.0.2-2
Total Download Size:   181.73 MiB
Total Installed Size:  185.92 MiB
:: Retrieving packages...
linux60-6.0.2-2-x86_64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux60...
Optional dependencies for linux60
    wireless-regdb: to set the correct wireless channels of your country [installed]
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'default'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64.img
==> Starting build: 6.0.2-2-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'fallback'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64-fallback.img
(4/5) Refreshing PackageKit...
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.0-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.0-x86_64.img
Found initrd fallback image: /boot/initramfs-6.0-x86_64-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Done ...
the output looks ok, the warnings are nothing to worry about… everyone has them
I was facing similar problems. Manjaro downloaded April 2022, KDE Plasma Desktop.
Frequent hangs, etc. Keyboard/mouse - very feeble and slow response during the freeze/hangs.
I stopped using Chrome and Microsoft-Edge and switched to Vivaldi.
I have not uninstallled Chrome, but not using it now. Have uninstalled MS-Edge.
It’s been 24 hours and not a single problem. I’ve also uninstalled Kmail and all its associated programs.
I am using Kernel version 6
The bug is still present after the kernel upgrade.
Below is the output of journalctl -b0 -p4 --no-pager.
I ran now this just after observing issues, but I had also observed issues several minutes ago.
I don’t know whether the timestamps are in GMT or in my local timezone which is currently GMT+1.
Either way the last message is from more than 24 hours ago.
Oct 26 22:24:00 lenovo-teo-m kernel: [Firmware Bug]: TSC ADJUST: CPU0: -2502588901 force to 0
Oct 26 22:24:00 lenovo-teo-m kernel: [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
Oct 26 22:24:00 lenovo-teo-m kernel:  #2 #3 #4
Oct 26 22:24:00 lenovo-teo-m kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Oct 26 22:24:00 lenovo-teo-m kernel:  #5 #6 #7
Oct 26 22:24:00 lenovo-teo-m kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 26 22:24:00 lenovo-teo-m kernel: hpet_acpi_add: no address or irqs in _CRS
Oct 26 22:24:00 lenovo-teo-m kernel: integrity: Problem loading X.509 certificate -65
Oct 26 22:24:00 lenovo-teo-m kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Oct 26 22:24:00 lenovo-teo-m kernel: nvme nvme0: missing or invalid SUBNQN field.
Oct 26 22:24:01 lenovo-teo-m kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-c0-jf-b0-72.ucode failed with error -2
Oct 26 22:24:01 lenovo-teo-m kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Oct 26 22:24:01 lenovo-teo-m kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
Oct 26 22:24:02 lenovo-teo-m systemd[457]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 26 22:24:04 lenovo-teo-m kernel: kauditd_printk_skb: 27 callbacks suppressed
Oct 26 22:24:04 lenovo-teo-m systemd-xdg-autostart-generator[547]: /home/teo/.config/autostart/telegramdesktop.desktop:13: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Oct 26 22:24:04 lenovo-teo-m systemd-xdg-autostart-generator[547]: /home/teo/.config/autostart/telegramdesktop.desktop:14: Unknown key name 'SingleMainWindow' in section 'Desktop Entry', ignoring.
Oct 26 22:24:04 lenovo-teo-m systemd-xdg-autostart-generator[547]: /home/teo/.config/autostart/telegramdesktop.desktop:18: Unknown section 'Desktop Action Quit'. Ignoring.
Oct 26 22:24:05 lenovo-teo-m systemd-xdg-autostart-generator[578]: /home/teo/.config/autostart/telegramdesktop.desktop:13: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Oct 26 22:24:05 lenovo-teo-m systemd-xdg-autostart-generator[578]: /home/teo/.config/autostart/telegramdesktop.desktop:14: Unknown key name 'SingleMainWindow' in section 'Desktop Entry', ignoring.
Oct 26 22:24:05 lenovo-teo-m systemd-xdg-autostart-generator[578]: /home/teo/.config/autostart/telegramdesktop.desktop:18: Unknown section 'Desktop Action Quit'. Ignoring.
Oct 26 22:24:05 lenovo-teo-m NetworkManager[420]: <warn>  [1666815845.4626] device (wlp0s20f3): no secrets: No agents were available for this request.
Oct 26 22:24:05 lenovo-teo-m NetworkManager[420]: <warn>  [1666815845.4629] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 26 22:24:05 lenovo-teo-m pipewire-media-session[752]: mod.rt: Can't find xdg-portal: (null)
Oct 26 22:24:05 lenovo-teo-m pipewire-media-session[752]: mod.rt: found session bus but no portal
Oct 26 22:24:05 lenovo-teo-m pipewire[741]: mod.rt: Can't find xdg-portal: (null)
Oct 26 22:24:05 lenovo-teo-m pipewire[741]: mod.rt: found session bus but no portal
Oct 26 22:24:07 lenovo-teo-m pulseaudio[911]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 26 22:24:08 lenovo-teo-m kernel: irq 9: nobody cared (try booting with the "irqpoll" option)
Oct 26 22:24:08 lenovo-teo-m kernel: CPU: 1 PID: 0 Comm: swapper/1 Not tainted 6.0.2-2-MANJARO #1 3201429db279b991ed623dff5d7b05e56f9c1c48
Oct 26 22:24:08 lenovo-teo-m kernel: Hardware name: LENOVO 81WE/LNVNB161216, BIOS EMCN14WW 05/11/2020
Oct 26 22:24:08 lenovo-teo-m kernel: Call Trace:
Oct 26 22:24:08 lenovo-teo-m kernel:  <IRQ>
Oct 26 22:24:08 lenovo-teo-m kernel:  dump_stack_lvl+0x48/0x60
Oct 26 22:24:08 lenovo-teo-m kernel:  __report_bad_irq+0x35/0xaa
Oct 26 22:24:08 lenovo-teo-m kernel:  note_interrupt.cold+0xa/0x65
Oct 26 22:24:08 lenovo-teo-m kernel:  handle_irq_event+0x75/0x80
Oct 26 22:24:08 lenovo-teo-m kernel:  handle_fasteoi_irq+0x8e/0x1f0
Oct 26 22:24:08 lenovo-teo-m kernel:  __common_interrupt+0x43/0xa0
Oct 26 22:24:08 lenovo-teo-m kernel:  common_interrupt+0x81/0xa0
Oct 26 22:24:08 lenovo-teo-m kernel:  </IRQ>
Oct 26 22:24:08 lenovo-teo-m kernel:  <TASK>
Oct 26 22:24:08 lenovo-teo-m kernel:  asm_common_interrupt+0x26/0x40
Oct 26 22:24:08 lenovo-teo-m kernel: RIP: 0010:cpuidle_enter_state+0xe2/0x420
Oct 26 22:24:08 lenovo-teo-m kernel: Code: 00 00 31 ff e8 5f ed 7c ff 45 84 ff 74 16 9c 58 0f 1f 40 00 f6 c4 02 0f 85 25 03 00 00 31 ff e8 04 ac 83 ff fb 0f 1f 44 00 00 <45> 85 f6 0f 88 85 01 00 00 49 63 d6 48 8d 04 52 48 8d 04 82 49 8d
Oct 26 22:24:08 lenovo-teo-m kernel: RSP: 0018:ffffb23dc011fe90 EFLAGS: 00000246
Oct 26 22:24:08 lenovo-teo-m kernel: RAX: ffff8bbdd2c72d40 RBX: ffff8bbdd2c7e200 RCX: 0000000000000000
Oct 26 22:24:08 lenovo-teo-m kernel: RDX: 0000000000000001 RSI: fffffffd84bab52d RDI: 0000000000000000
Oct 26 22:24:08 lenovo-teo-m kernel: RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000055785785
Oct 26 22:24:08 lenovo-teo-m kernel: R10: 000000000000000a R11: 0000000000000008 R12: ffffffffa6d46320
Oct 26 22:24:08 lenovo-teo-m kernel: R13: 000000021bf71fc7 R14: 0000000000000001 R15: 0000000000000000
Oct 26 22:24:08 lenovo-teo-m kernel:  cpuidle_enter+0x2d/0x40
Oct 26 22:24:08 lenovo-teo-m kernel:  do_idle+0x1ed/0x270
Oct 26 22:24:08 lenovo-teo-m kernel:  cpu_startup_entry+0x1d/0x20
Oct 26 22:24:08 lenovo-teo-m kernel:  start_secondary+0x115/0x140
Oct 26 22:24:08 lenovo-teo-m kernel:  secondary_startup_64_no_verify+0xe5/0xeb
Oct 26 22:24:08 lenovo-teo-m kernel:  </TASK>
Oct 26 22:24:08 lenovo-teo-m kernel: handlers:
Oct 26 22:24:08 lenovo-teo-m kernel: [<00000000b9c43c5e>] acpi_irq
Oct 26 22:24:08 lenovo-teo-m kernel: Disabling IRQ #9
Oct 26 22:24:12 lenovo-teo-m kernel: kauditd_printk_skb: 11 callbacks suppressed
Oct 27 09:08:55 lenovo-teo-m NetworkManager[420]: <warn>  [1666854535.9503] device (wlp0s20f3): link timed out.
Oct 27 09:08:56 lenovo-teo-m NetworkManager[420]: <warn>  [1666854536.0190] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 27 17:56:35 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 27 20:15:08 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 28 06:10:46 lenovo-teo-m NetworkManager[420]: <warn>  [1666930246.0535] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 28 06:11:38 lenovo-teo-m NetworkManager[420]: <warn>  [1666930298.0118] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 28 07:24:51 lenovo-teo-m NetworkManager[420]: <warn>  [1666934691.0012] device (enp0s20f0u9): Activation: failed for connection 'Wired connection 1'
Oct 28 21:14:38 lenovo-teo-m systemd[541]: app-\x2fusr\x2fbin\x2fqdbus-c1c7ec7597c3487e92efe915c006ca89.scope: Failed to add PIDs to scope's control group: No such process
Oct 28 21:14:38 lenovo-teo-m systemd[541]: app-\x2fusr\x2fbin\x2fqdbus-c1c7ec7597c3487e92efe915c006ca89.scope: Failed with result 'resources'.
Oct 28 21:14:38 lenovo-teo-m systemd[541]: Failed to start /usr/bin/qdbus.
Oct 28 21:18:05 lenovo-teo-m systemd[541]: app-\x2fusr\x2fbin\x2fqdbus-153d183b12d94d3583b6c149c676be9f.scope: Failed to add PIDs to scope's control group: No such process
Oct 28 21:18:05 lenovo-teo-m systemd[541]: app-\x2fusr\x2fbin\x2fqdbus-153d183b12d94d3583b6c149c676be9f.scope: Failed with result 'resources'.
Oct 28 21:18:05 lenovo-teo-m systemd[541]: Failed to start /usr/bin/qdbus.
Oct 29 00:45:23 lenovo-teo-m NetworkManager[420]: <warn>  [1666997123.9506] device (wlp0s20f3): link timed out.
Oct 29 00:45:23 lenovo-teo-m NetworkManager[420]: <warn>  [1666997123.9995] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 29 04:25:35 lenovo-teo-m NetworkManager[420]: <warn>  [1667010335.9870] device (enp0s20f0u9): Activation: failed for connection 'Wired connection 1'
Oct 29 12:00:21 lenovo-teo-m systemd[541]: app-\x2fusr\x2fbin\x2fqdbus-53a93cb7141c4388b69a8696bdff2e8c.scope: Failed to add PIDs to scope's control group: No such process
Oct 29 12:00:21 lenovo-teo-m systemd[541]: app-\x2fusr\x2fbin\x2fqdbus-53a93cb7141c4388b69a8696bdff2e8c.scope: Failed with result 'resources'.
Oct 29 12:00:21 lenovo-teo-m systemd[541]: Failed to start /usr/bin/qdbus.
Oct 29 15:30:51 lenovo-teo-m pamac-manager[120340]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 29 17:23:25 lenovo-teo-m kernel: kauditd_printk_skb: 10 callbacks suppressed
Oct 29 19:14:52 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 29 19:14:55 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 29 21:47:13 lenovo-teo-m NetworkManager[420]: <warn>  [1667072833.0657] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 30 01:26:20 lenovo-teo-m NetworkManager[420]: <warn>  [1667085980.9793] device (enp0s20f0u9): Activation: failed for connection 'Wired connection 1'
Oct 30 17:48:02 lenovo-teo-m NetworkManager[420]: <warn>  [1667148482.0707] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 30 17:48:49 lenovo-teo-m NetworkManager[420]: <warn>  [1667148529.0311] device (wlp0s20f3): Activation: failed for connection 'Sixty-Seven 5G'
Oct 31 16:51:18 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 31 16:51:22 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 31 16:59:50 lenovo-teo-m filezilla[28672]: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
Oct 31 19:58:56 lenovo-teo-m systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
you have these following with the kernel call trace logs…
it looks that these are common on lenovo, and without any fix…
lets try some kernel parameters:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
ahci.mobile_lpm_policy=1
dont remove any parameters from there, just add it to the existing ones;
save the file, update grub:
sudo update-grub
reboot and test
Some options for you to try out (from my notepad https://root.nix.dk/en/notes-and-bookmarks/intel-xorg-config)
intel driver configuration
For Early KMS - edit /etc/mkinitcpio.conf
MODULES=(... i915 ...)
Rebuild initram
mkinitcpio -P
Reboot your system
reboot
Configuration /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
    Identifier  "Intel Graphics"
    Driver      "intel"
    Option      "TearFree" "true"
EndSection
Or
Section "Device"
    Driver      "intel"
    Option      "AccelMethod"     "sna"
    Option      "SwapbuffersWait" "true"
    Option      "DRI"             "2"
EndSection
Use wayland
Install the package plasma-wayland-session
sudo pacman -Syu plasma-wayland-session
Log Out then select wayland at lower left corner of you login greeter and login.
Is that a general suggestion, or do you actually think that that can fix the issues? Do you believe these could be bugs in Xorg that are not present in Wayland?
(and as a general question, is Wayland already anywhere near something stable that can be relied upon for everyday use by a normal person using a computer to do actual work other than testing or contributing to Wayland?)
I don’t think wayland is a magic wand - it is a process of elimination - no more no less.
I do actual work every day - using Plasma with Wayland - contract work for a client and my system is as stable as I need it and I need it stable. I run several VirtualBox VMs developing and testing .NET 4 Web API server and webclient.
