When i start chromium browser, A prompt pops up showing “Enter password to unlock keyring” . Is there any way to disable it?
Hi @spidermonkey,
a Quick bit of searching led me to https://askubuntu.com/questions/31786/chrome-asks-for-password-to-unlock-keyring-on-startup
Where it states:
From the manpage:
--password-store=<basic|gnome|kwallet>Set the password store to use. The default is to automatically detect based on the desktop environment.
basicselects the built in, unencrypted password store.gnomeselects Gnome keyring.kwalletselects (KDE) KWallet. (Note that KWallet may not work reliably outside KDE.)The easiest way to fix that in the launcher is to copy the
.desktopfile to your home folder and edit it (google chrome users should copy the appropriate file):cp /usr/share/applications/chromium-browser.desktop ~/.local/share/applicationsThen edit the new file such that the
Execline reads like this:Exec=chromium-browser --password-store=basic %UIf you have any other Chromium app installed, their
.desktopfiles should also be in~/.local/share/applications, edit them accordingly.
Hope this helps!
