Enlarge scroll bar width - how to
Hi,
what’s the procedure to enlarge/change the width of the vertical/horizontal scroll bar in Thunar, Mousepad, etc.
Thanks
Create the file ~/.config/gtk-3.0/gtk.css if it doesn’t already exists and paste the following CSS rules in it:
scrollbar, scrollbar button, scrollbar slider {
    min-width: 10px;
    min-height: 10px;
The min-width value is for the vertical scrollbar and the min-height value is for the horizontal scrollbar. You can change the values according to your liking.
After saving the file, you have to logout/login in order to see the changes.
Bare in mind that the above CSS rule will change the scrollbars in all Gtk-based applications, not only the two you’re mentioning.
Thanks. Perfect
