Kernel: 6.1.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F21 date: 02/08/2018
System RAM: total: 16 GiB available: 15.57 GiB used: 4.7 GiB (30.2%)
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001129
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2803 high: 3393 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2721 2: 2610
3: 1357 4: 1357 5: 3200 6: 3393 7: 3393 8: 3393 9: 3393 10: 3393 11: 2715
12: 2715 bogomips: 76672
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET, no microcode
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 08:00.0 chip-ID: 10de:1c02 class-ID: 0300
Device-2: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0894
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
memory: 2.93 GiB
API: Vulkan v: 1.3.269 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: nvidia v: 535.129.03 device-ID: 10de:1c02
surfaces: xcb,xlib
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
Device-4: Blue Microphones Yeti Nano
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: b58e:0005 class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.62-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: jack_control
Server-3: PipeWire v: 0.3.84 status: off with: 1: pipewire-media-session
status: off 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
status: discoverable: no pairing: no
Local Storage: total: 3.41 TiB used: 1.08 TiB (31.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 191.14 GiB (83.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 80.3 MiB (26.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 689.52 GiB (75.3%) fs: ext4 dev: /dev/sdd
maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 214.27 GiB (50.2%) fs: ext4 dev: /dev/sdc2
maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 15.84 GiB (0.9%) fs: ext4 dev: /dev/sda
maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: 1-2:3 info: Logitech CrystalCam type: video,audio
chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Device-1: 3-1:2 info: Blue Microphones Yeti Nano type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
chip-ID: b58e:0005 class-ID: 0300 serial: <filter>
Device-2: 3-3:3 info: Ducky One 3Ě type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
serial: <filter>
Device-3: 3-4:4 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 45.8 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 359 Uptime: 4m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 2394
pm: pacman pkgs: 2380 libs: 590 tools: gnome-software,pamac pm: flatpak
pkgs: 5 pm: snap pkgs: 9 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.31
Whenever I try to play Portal 2 I get the error Engine Error: Steam is not running. You must start Steam in order to play this game
Other games work fine.
I have tried reinstalling the game, reinstalling Steam, to no avail.
Before this I also had a problem with Portal 2 opening on the wrong monitor in my dual monitor setup.
Here’s the output when I run the game through terminal until the error pops up then I click “stop” in the GUI.
steam.sh[9639]: Running Steam on manjarolinux 23.1.0 64-bit
steam.sh[9639]: STEAM_RUNTIME is enabled automatically
setup.sh[9711]: Steam runtime environment up-to-date!
steam.sh[9639]: Steam client's requirements are satisfied
[2023-11-19 08:36:16] Startup - updater built Nov 16 2023 18:22:28
[2023-11-19 08:36:16] Startup - Steam Client launched with: '/home/nicholas/.local/share/Steam/ubuntu12_32/steam'
11/19 08:36:16 Init: Installing breakpad exception handler for appid(steam)/version(1700160213)/tid(9763)
[2023-11-19 08:36:16] Loading cached metrics from disk (/home/nicholas/.local/share/Steam/package/steam_client_metrics.bin)
[2023-11-19 08:36:16] Using the following download hosts for Public, Realm steamglobal
[2023-11-19 08:36:16] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-11-19 08:36:16] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-11-19 08:36:16] 3. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-11-19 08:36:16] Verifying installation...
[2023-11-19 08:36:16] Verification complete
Steam logging initialized: directory: /home/nicholas/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf0aa2dc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf0aa1500
steamwebhelper.sh[9769]: Runtime for steamwebhelper: defaulting to /home/nicholas/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[9769]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 82 milliseconds to initialize
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 9852
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
BRefreshApplicationsInLibrary 1: 2ms
Fossilize INFO: Setting autogroup scheduling.
BuildCompleteAppOverviewChange: 294 apps
RegisterForAppOverview 1: 21ms
RegisterForAppOverview 2: 22ms
/bin/sh\0-c\0/home/nicholas/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=620 -- /home/nicholas/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/run/media/nicholas/fourth-disk/steam-ssd/steamapps/common/Portal 2/portal2.exe' -game portal2 -steam\0
chdir "/run/media/nicholas/fourth-disk/steam-ssd/steamapps/common/Portal 2"
ERROR: ld.so: object '/home/nicholas/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/nicholas/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
007c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
007c:fixme:hid:build_joystick_report_descriptor More than 8 absolute axes found, ignoring.
0024:fixme:heap:RtlSetHeapInformation HEAP_INFORMATION_CLASS 1 not implemented!
CDynamicFunction: Loading library 'Kernel32.dll' (7BEE0000)
CDynamicFunction: Lookup of 'TryEnterCriticalSection' in 'Kernel32.dll': 7BFA8B80
Using shader api: shaderapidx9
0024:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
Using breakpad crash handler
0024:fixme:keyboard:LoadKeyboardLayoutW name L"00000409", flags 0, semi-stub!
0024:fixme:d3d:debug_d3dformat Unrecognized 0x41415353 (as fourcc: SSAA) WINED3DFORMAT!
0024:fixme:d3d:wined3d_get_format Can't find format unrecognized (0x41415353) in the format lookup table.
CSoundEmitterSystemBase::BaseInit: Manifest 'scripts/game_sounds_manifest.txt' with bogus file type 'new_sound_scripts_must_go_below_here', expecting 'declare_file' or 'precache_file'
Convar r_flashlightscissor has conflicting FCVAR_CHEAT flags (child: no FCVAR_CHEAT, parent: has FCVAR_CHEAT, parent wins)
0024:fixme:ole:CoInitializeSecurity 00000000, -1, 00000000, 00000000, 0, 3, 00000000, 0, 00000000 stub
0024:fixme:wbemprox:client_security_SetBlanket 78B31850, 00AE2130, 10, 0, (null), 3, 3, 00000000, 0
0024:fixme:wbemprox:client_security_Release 78B31850
0024:fixme:d3d:wined3d_check_device_format_conversion output 0059AC68, device_type WINED3D_DEVICE_TYPE_HAL, src_format WINED3DFMT_B8G8R8A8_UNORM, dst_format WINED3DFMT_B8G8R8X8_UNORM stub!
0024:fixme:d3d9:D3DPERF_SetOptions options 0x1, stub!
0148:fixme:d3d:state_linepattern_w Setting line patterns is not supported in OpenGL core contexts.
0148:fixme:d3d_shader:print_glsl_info_log Info log received from GLSL shader #3:
0148:fixme:d3d_shader:print_glsl_info_log Vertex info
0148:fixme:d3d_shader:print_glsl_info_log -----------
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[0].zw" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[2].yzw" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[3]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[4]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[5]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[6]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[7]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[8]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[9]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[11].yzw" might be used before being initialized
CClientSteamContext logged on = 0
Convar building_cubemaps has conflicting FCVAR_CHEAT flags (child: has FCVAR_CHEAT, parent: no FCVAR_CHEAT, parent wins)
0148:fixme:d3d_shader:print_glsl_info_log Info log received from GLSL shader #7:
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[1].zw" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[2].zw" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[3].w" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[10]" might be used before being initialized
0148:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[11]" might be used before being initialized
Game.dll loaded for "Half-Life 2"
0024:fixme:thread:NtSetInformationThread ThreadIdealProcessor stub!
0024:err:winediag:ntlm_check_version ntlm_auth was not found. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0024:err:ntlm:ntlm_LsaApInitializePackage no NTLM support, expect problems
Looking up breakpad interfaces from steamclient
Calling BreakpadMiniDumpSystemInit
018c:fixme:dbghelp:elf_search_auxv can't find symbol in module
Last line repeats until game fully closes.
Update/Edit: I’ve tried restarting my computer multiple times, uninstalled and reinstalled the game, uninstalled and reinstalled Steam, moved the installation folder, deleted the compatdata folder, ran the game natively and with Proton to no avail.
