sudo mount /dev/nvme1n1p1 /run/media/manjaro/ac9981da-f704-479c-ab21-1c31a29664ad/boot/efi
manjaro-chroot /run/media/manjaro/ac9981da-f704-479c-ab21-1c31a29664ad /bin/bash
tty: ttyname error: No such device
inxi:
Kernel 6.18.0-1-MANJARO arch x86_64 bits 64 compiler gcc v 15.2.1 clocksource tsc
avail hpet,acpi_pm parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_251PRE1 quiet systemd.show_status=1 splash
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop KDE Plasma v ERR-101 tk Qt v N/A wm kwin_wayland dm N/A Distro Manjaro base Arch Linux
Type Desktop System ASUS product N/A v N/A serial N/A
Mobo ASUSTeK model ROG CROSSHAIR VIII DARK HERO v Rev X.0x serial <filter> part-nu SKU
uuid 4c54ddb1-4204-a91a-8c6f-04421aa98c6e Firmware UEFI vendor American Megatrends v 5302
date 10/03/2025
Message No system battery data found. Is one present?
System RAM total 32 GiB available 31.25 GiB used 2.65 GiB (8.5%)
Array-1 capacity 128 GiB slots 4 modules 2 EC None max-module-size 32 GiB note est.
Device-1 DIMM_A1 type no module installed
Device-2 DIMM_A2 type DDR4 detail synchronous unbuffered (unregistered) size 16 GiB
speed 3200 MT/s volts curr 1.2 min 1.2 max 1.2 width (bits) data 64 total 64
manufacturer G Skill Intl part-no F4-3200C14-16GTZ serial N/A
Device-3 DIMM_B1 type no module installed
Device-4 DIMM_B2 type DDR4 detail synchronous unbuffered (unregistered) size 16 GiB
Slot 0 type PCIe status in use length long volts 3.3 bus-ID 00:03.1 children 1 0b:00.0
class-ID 0604 type bridge children 1 0c:00.0 class-ID 0604 type bridge children 1 0d:00.0
class-ID 0300 type display 2 0d:00.1 class-ID 0403 type audio
Slot 1 type PCIe status available length long volts 3.3 bus-ID 00:1f.7
Slot 2 type PCIe status available length short volts 3.3 bus-ID 00:1f.7
Slot 3 type PCIe status available length short volts 3.3 bus-ID 00:1f.7
Info model AMD Ryzen 5 5600 socket AM4 bits 64 type MT MCP arch Zen 3+ gen 3 level v3 note check
built 2022 process TSMC n6 (7nm) family 0x19 (25) model-id 0x21 (33) stepping 2
microcode 0xA201213
Topology cpus 1x dies 1 clusters 1 cores 6 threads tpc 2 smt enabled cache L1 384 KiB
desc d-6x32 KiB; i-6x32 KiB L2 3 MiB desc 6x512 KiB L3 32 MiB desc 1x32 MiB
Speed (MHz) avg 3592 min/max 566/4471 boost enabled base/boost 3500/4450 scaling
driver amd-pstate-epp governor powersave volts 1.1 V ext-clock 100 MHz cores 1 3592 2 3592 3 3592
4 3592 5 3592 6 3592 7 3592 8 3592 9 3592 10 3592 11 3592 12 3592 bogomips 84004
Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3
cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms
extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb
ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr
mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36
rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Vulnerabilities
Type gather_data_sampling status Not affected
Type ghostwrite status Not affected
Type indirect_target_selection status Not affected
Type itlb_multihit status Not affected
Type l1tf status Not affected
Type mds status Not affected
Type meltdown status Not affected
Type mmio_stale_data status Not affected
Type old_microcode status Not affected
Type reg_file_data_sampling status Not affected
Type retbleed status Not affected
Type spec_rstack_overflow mitigation Safe RET
Type spec_store_bypass mitigation Speculative Store Bypass disabled via prctl
Type spectre_v1 mitigation usercopy/swapgs barriers and __user pointer sanitization
Type spectre_v2 mitigation Retpolines; IBPB: conditional; IBRS_FW; STIBP: always-on; RSB
filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type srbds status Not affected
Type tsa mitigation Clear CPU buffers
Type tsx_async_abort status Not affected
Type vmscape mitigation IBPB before exit to userspace
Device-1 Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor Sapphire TOXIC driver amdgpu v kernel arch RDNA-2 code Navi-2x process TSMC n7 (7nm)
built 2020-22 pcie gen 4 speed 16 GT/s lanes 16 ports active HDMI-A-1 empty DP-1, DP-2, DP-3,
Writeback-1 bus-ID 0d:00.0 chip-ID 1002:73bf class-ID 0300
Device-2 Razer USA Kiyo Pro driver snd-usb-audio,uvcvideo type USB rev 3.2 speed 5 Gb/s lanes 1
mode 3.2 gen-1x1 bus-ID 4-3:2 chip-ID 1532:0e05 class-ID 0102
Display server X.org v 1.21.1.21 with Xwayland v 24.1.9 compositor kwin_wayland driver X
loaded amdgpu unloaded modesetting,radeon alternate fbdev,vesa dri radeonsi gpu amdgpu
display-ID :1
Monitor-1 HDMI-A-1 model LG (GoldStar) ULTRAWIDE serial <filter> built 2015 res 2560x1080
dpi 81 gamma 1.2 chroma red x 0.651 y 0.333 green x 0.306 y 0.631 blue x 0.149 y 0.059 white
x 0.314 y 0.329 size 798x334mm (31.42x13.15") diag 869mm (34.2") modes 2560x1080, 1920x1080,
1680x1050, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480, 720x400
API EGL v 1.5 hw drv amd radeonsi platforms device 0 drv radeonsi device 1 drv swrast gbm
drv radeonsi surfaceless drv radeonsi inactive wayland,x11
API OpenGL v 4.6 compat-v 4.5 vendor mesa v 25.3.1-arch1.2 note incomplete (EGL sourced)
renderer AMD Radeon RX 6900 XT (radeonsi navi21 LLVM 21.1.6 DRM 3.64 6.18.0-1-MANJARO), llvmpipe
(LLVM 21.1.6 256 bits)
API Vulkan Message No Vulkan data available.
Info Tools api clinfo, eglinfo, glxinfo, vulkaninfo de kscreen-console,kscreen-doctor
gpu radeontop wl wayland-info x11 xdpyinfo, xprop, xrandr
Device-1 Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio driver snd_hda_intel v kernel
pcie gen 4 speed 16 GT/s lanes 16 bus-ID 0d:00.1 chip-ID 1002:ab28 class-ID 0403
Device-2 Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor ASUSTeK
driver snd_hda_intel v kernel pcie gen 4 speed 16 GT/s lanes 16 bus-ID 0f:00.4 chip-ID 1022:1487
class-ID 0403
Device-3 XMOS usb audio driver snd-usb-audio type USB rev 2.0 speed 480 Mb/s lanes 1 mode 2.0
bus-ID 3-6:5 chip-ID 20b1:000a class-ID fe01
Device-4 Razer USA Kiyo Pro driver snd-usb-audio,uvcvideo type USB rev 3.2 speed 5 Gb/s lanes 1
API ALSA v k6.18.0-1-MANJARO status kernel-api with aoss type oss-emulator
tools alsactl,alsamixer,amixer
Server-1 sndiod v N/A status off tools aucat,midicat,sndioctl
Server-2 JACK v 1.9.22 status off tools N/A
Server-3 PipeWire v 1.4.9 status n/a (root, process) with 1 pipewire-pulse status active
2 wireplumber status active 3 pipewire-alsa type plugin tools pactl,pw-cat,pw-cli,wpctl
Device-1 Realtek RTL8125 2.5GbE vendor ASUSTeK driver r8169 v kernel pcie gen 2 speed 5 GT/s
lanes 1 port e000 bus-ID 05:00.0 chip-ID 10ec:8125 class-ID 0200
IF enp5s0 state up speed 2500 Mbps duplex full mac <filter>
IP v6 <filter> type noprefixroute scope link
Device-2 Intel I211 Gigabit Network vendor ASUSTeK driver igb v kernel pcie gen 1
speed 2.5 GT/s lanes 1 port d000 bus-ID 06:00.0 chip-ID 8086:1539 class-ID 0200
IF enp6s0 state down mac <filter>
Device-3 Intel Wi-Fi 6 AX200 driver iwlwifi v kernel pcie gen 2 speed 5 GT/s lanes 1
bus-ID 07:00.0 chip-ID 8086:2723 class-ID 0280
IF wlp7s0 state down mac <filter>
Info services NetworkManager, systemd-timesyncd, wpa_supplicant
WAN IP No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1 Intel AX200 Bluetooth driver btusb v 0.8 type USB rev 2.0 speed 12 Mb/s lanes 1 mode 1.1
bus-ID 1-6:4 chip-ID 8087:0029 class-ID e001
Report rfkill ID hci0 rfk-id 0 state up address see --recommends
Message No logical block device data found.
Message No RAID data found.
Local Storage total 1.17 TiB used 110.2 GiB (9.2%)
ID-1 /dev/nvme0n1 maj-min 259:0 vendor Gigabyte model GP-AG41TB size 931.51 GiB block-size
physical 512 B logical 512 B speed 63.2 Gb/s lanes 4 tech SSD serial <filter> fw-rev EGFM13.0
temp 40.9 C
SMART yes health PASSED on 2y 146d 1h cycles 1,807 read-units 46,217,591 [23.6 TB]
written-units 45,280,504 [23.1 TB]
ID-2 /dev/nvme1n1 maj-min 259:2 model 256GB NVMe SSD size 238.47 GiB block-size physical 512 B
logical 512 B speed 31.6 Gb/s lanes 4 tech SSD serial <filter> fw-rev AP005PI0 temp 17.9 C
SMART yes health PASSED on 2y 16d 1h cycles 1,809 read-units 40,706,704 [20.8 TB]
written-units 53,469,131 [27.3 TB]
ID-3 /dev/sda maj-min 8:0 vendor Kingston model DataTraveler 3.0 size 28.82 GiB block-size
physical 512 B logical 512 B type USB rev 3.2 spd 5 Gb/s lanes 1 mode 3.2 gen-1x1 tech N/A
serial <filter>
SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
Message No optical or floppy data found.
ID-1 / raw-size 238.17 GiB size 233.37 GiB (97.99%) used 110.2 GiB (47.2%) fs ext4
block-size 4096 B dev /dev/dm-0 maj-min 253:0 mapped luks-02db1f6a-9578-4cd5-be9e-97a2fc3bb1a3
label N/A uuid ac9981da-f704-479c-ab21-1c31a29664ad
ID-2 /boot/efi raw-size 300 MiB size 299.4 MiB (99.80%) used 568 KiB (0.2%) fs vfat
block-size 512 B dev /dev/nvme1n1p1 maj-min 259:3 label N/A uuid 7DF3-8C09
Alert No swap data was found.
ID-1 /dev/nvme0n1p1 maj-min 259:1 size 931.51 GiB fs ext4 label N/A
uuid 65e3e02a-889c-4a89-af73-1e1918b632f9
ID-2 /dev/nvme1n1p2 maj-min 259:4 size 238.17 GiB fs N/A label N/A
uuid 02db1f6a-9578-4cd5-be9e-97a2fc3bb1a3
ID-3 /dev/sda1 maj-min 8:1 size 5.25 GiB fs N/A label MANJARO_KDE_251PRE1
uuid 2025-12-08-16-47-40-00
ID-4 /dev/sda2 maj-min 8:2 size 4 MiB fs N/A label MISO_EFI uuid D453-59DC
Hub-1 1-0:1 info hi-speed hub with single TT ports 6 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1
mode 2.0 chip-ID 1d6b:0002 class-ID 0900
Device-1 1-1:2 info Yubicom Yubikey 4/5 U2F type HID driver hid-generic,usbhid interfaces 1
rev 2.0 speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 30mA chip-ID 1050:0402 class-ID 0300
Hub-2 1-5:3 info Genesys Logic Hub ports 4 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0
power 100mA chip-ID 05e3:0610 class-ID 0900
Device-1 1-5.1:5 info Laview Mionix NAOS 8200 [STM32F103 MCU] type mouse,HID
driver hid-generic,usbhid interfaces 2 rev 2.0 speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1
power 200mA chip-ID 22d4:1301 class-ID 0300
Device-2 1-5.2:6 info Valve Wireless Steam Controller type keyboard,HID driver hid-steam,usbhid
interfaces 5 rev 2.0 speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 100mA chip-ID 28de:1142
class-ID 0300
Device-3 1-5.3:7 info ASUSTek AURA LED Controller type HID driver hid-generic,usbhid
interfaces 2 rev 2.0 speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 16mA chip-ID 0b05:18f3
class-ID 0300 serial <filter>
Device-4 1-6:4 info Intel AX200 Bluetooth type bluetooth driver btusb interfaces 2 rev 2.0
speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 100mA chip-ID 8087:0029 class-ID e001
Hub-3 2-0:1 info super-speed hub ports 4 rev 3.1 speed 10 Gb/s (1.16 GiB/s) lanes 1
mode 3.2 gen-2x1 chip-ID 1d6b:0003 class-ID 0900
Hub-4 3-0:1 info hi-speed hub with single TT ports 6 rev 2.0 speed 480 Mb/s (57.2 MiB/s)
lanes 1 mode 2.0 chip-ID 1d6b:0002 class-ID 0900
Device-1 3-1:2 info Atmel EasyAVR Multimedia Keyboard v2.03.01 type keyboard,mouse,HID
driver hid-generic,usbhid interfaces 3 rev 2.0 speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1
power 100mA chip-ID 03eb:20ff class-ID 0300
Hub-5 3-2:3 info ASMedia ASM1074 High-Speed hub ports 4 rev 2.1 speed 480 Mb/s (57.2 MiB/s)
lanes 1 mode 2.0 power 100mA chip-ID 174c:2074 class-ID 0900
Device-1 3-4:4 info 8BitDo Retro 108 Keyboard type mouse,keyboard driver hid-generic,usbhid
interfaces 3 rev 1.1 speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 200mA chip-ID 2dc8:5209
class-ID 0301
Device-2 3-6:5 info XMOS usb audio type audio driver snd-usb-audio interfaces 3 rev 2.0
speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 chip-ID 20b1:000a class-ID fe01
Hub-6 4-0:1 info super-speed hub ports 4 rev 3.1 speed 10 Gb/s (1.16 GiB/s) lanes 1
Hub-7 4-2:3 info ASMedia ASM1074 SuperSpeed hub ports 4 rev 3.0 speed 5 Gb/s (596.0 MiB/s)
lanes 1 mode 3.2 gen-1x1 power 8mA chip-ID 174c:3074 class-ID 0900
Device-1 4-2.2:4 info Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson type mass storage
driver usb-storage interfaces 1 rev 3.2 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1
power 296mA chip-ID 0951:1666 class-ID 0806 serial <filter>
Device-2 4-3:2 info Razer USA Kiyo Pro type video,audio driver snd-usb-audio,uvcvideo
interfaces 4 rev 3.2 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1 power 896mA
Hub-8 5-0:1 info hi-speed hub with single TT ports 4 rev 2.0 speed 480 Mb/s (57.2 MiB/s)
Hub-9 6-0:1 info super-speed hub ports 4 rev 3.1 speed 10 Gb/s (1.16 GiB/s) lanes 1
System Temperatures cpu 35.1 C mobo N/A gpu amdgpu temp 40.0 C mem 36.0 C
Fan Speeds (rpm) N/A gpu amdgpu fan 0
Packages pm pacman pkgs 1893 libs 443 tools pamac
Active pacman repo servers in /etc/pacman.d/mirrorlist
1 https: //mirror.alwyzon.net/manjaro/stable/$repo/$arch
2 https: //ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
3 https: //mirrors.cicku.me/manjaro/stable/$repo/$arch
4 https: //mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
5 https: //edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
6 https: //quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
Processes:
CPU top 5 of 368
1 cpu 100% command ps pid 3959 mem 3.85 MiB (0.0%)
2 cpu 5.3% command plasmashell pid 1848 mem 509.4 MiB (1.5%)
3 cpu 4.2% command kwin_wayland pid 1648 mem 321.5 MiB (1.0%)
4 cpu 1.4% command zsh pid 3606 mem 9.01 MiB (0.0%)
5 cpu 1.1% command gpg-agent pid 901 mem 4.42 MiB (0.0%)
Memory top 5 of 368
1 mem 509.4 MiB (1.5%) command plasmashell pid 1848 cpu 5.3%
2 mem 321.5 MiB (1.0%) command kwin_wayland pid 1648 cpu 4.2%
3 mem 164.6 MiB (0.5%) command thumbnail.so started-by kioworker pid 3388 cpu 0.7%
4 mem 155.7 MiB (0.4%) command konsole pid 3585 cpu 0.4%
5 mem 144.0 MiB (0.4%) command Xorg pid 1542 cpu 0.4%
Processes 368 Power uptime 2m states freeze,mem,disk suspend deep avail s2idle wakeups 0
hibernate platform avail shutdown, reboot, suspend, test_resume image .43 GiB
services org_kde_powerdevil, power-profiles-daemon, upowerd Init systemd v 258
default graphical tool systemctl
Compilers clang 21.1.6 gcc 15.2.1 Client systemd inxi 3.3.40
# cat /etc/fstab:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=7DF3-8C09 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-02db1f6a-9578-4cd5-be9e-97a2fc3bb1a3 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
/dev/nvme0n1p1 /media/nvme_0 ext4 defaults 0 0
# fdisk -l:
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: GIGABYTE GP-AG41TB
Disklabel type: gpt
Disk identifier: C82A86AF-8E97-BF4E-A76F-A522D5BB948D
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1953523711 1953521664 931.5G Linux filesystem
Disk /dev/nvme1n1: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: 256GB NVMe SSD
Disklabel type: gpt
Disk identifier: A5FC521A-05DE-42E6-9EC4-15CFFBACDC7F
/dev/nvme1n1p1 4096 618495 614400 300M EFI System
/dev/nvme1n1p2 618496 500103449 499484954 238.2G Linux filesystem
Disk /dev/sda: 28.82 GiB, 30943995904 bytes, 60437492 sectors
Disk model: DataTraveler 3.0
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 11014187 11014124 5.3G 0 Empty
/dev/sda2 11014188 11022379 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 40.23 MiB, 42180608 bytes, 82384 sectors
Disk /dev/loop1: 2.16 GiB, 2324520960 bytes, 4540080 sectors
Disk /dev/loop2: 1.89 GiB, 2029875200 bytes, 3964600 sectors
Disk /dev/loop3: 968.82 MiB, 1015881728 bytes, 1984144 sectors
Disk /dev/mapper/luks-02db1f6a-9578-4cd5-be9e-97a2fc3bb1a3: 238.17 GiB, 255734199296 bytes, 499480858 sectors
# gparted -l:
Running in chroot, ignoring command 'show'
Authorization required, but no authorization protocol specified
(gpartedbin:186): Gtk-WARNING **: 20:03:14.871: cannot open display: :1
[manjaro /]# blkid
/dev/loop1: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/nvme0n1p1: UUID="65e3e02a-889c-4a89-af73-1e1918b632f9" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="b83c9341-aae4-c74e-b31c-f3c092883efa"
/dev/loop2: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/loop0: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/mapper/luks-02db1f6a-9578-4cd5-be9e-97a2fc3bb1a3: UUID="ac9981da-f704-479c-ab21-1c31a29664ad" BLOCK_SIZE="4096" TYPE="ext4"
/dev/nvme1n1p2: UUID="02db1f6a-9578-4cd5-be9e-97a2fc3bb1a3" TYPE="crypto_LUKS" PARTLABEL="root" PARTUUID="11afab67-b9da-4e15-a33a-6ce0b3fcf918"
/dev/nvme1n1p1: UUID="7DF3-8C09" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="45fb5210-396d-46f9-ab9f-7752d771ec50"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="D453-59DC" BLOCK_SIZE="512" TYPE="vfat"
/dev/sda1: BLOCK_SIZE="2048" UUID="2025-12-08-16-47-40-00" LABEL="MANJARO_KDE_251PRE1" TYPE="iso9660"
/dev/loop3: BLOCK_SIZE="262144" TYPE="squashfs"
I hope its ok being posted like this, dont see an option to just attach txt file.
