basically, I am trying to enable intel turbo boost on linux (works fine on Windows), since I see the cpu clock speed fixed at 1.8GHz, when it should be going up to 3.9
I’ve tried editing /sys/devices/system/cpu/cpufreq/boost to 1, in many different ways (including using su root) but I always get a “Permission Denied” error.
Could be useful:
neofetch:
██████████████████ ████████ alba4k@alba4k
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Kernel: 5.15.2-2-MANJARO
██████████████████ ████████ Desktop Environnement: Plasma 5.23.3
████████ ████████ Host: HP ProBook 440 G6
████████ ████████ ████████ CPU: i5-8265U (8) @ 1.8GHz [43.0°C]
████████ ████████ ████████ CPU Usage: 13%
████████ ████████ ████████ GPU: Intel WhiskeyLake-U GT2 [UHD Graphics 620]
████████ ████████ ████████ Resolution: 1920x1080 @ 60.00Hz, 1920x1080 @ 60.00Hz
████████ ████████ ████████ Memory: 3057MiB / 23440MiB (13%)
████████ ████████ ████████ Battery0: 100% [Full]
████████ ████████ ████████ Uptime: 1h 11m
████████ ████████ ████████ Terminal: konsole
sudo i7z:
Cpu speed from cpuinfo 1799.00Mhz
cpuinfo might be wrong if cpufreq is enabled. To guess correctly try estimating via
Linux's inbuilt cpu_khz code emulated now
True Frequency (without accounting Turbo) 1799 MHz
CPU Multiplier 18x || Bus clock frequency (BCLK) 99.94 MHz
Socket [0] - [physical cores=4, logical cores=8, max online cores ever=4]
TURBO DISABLED on 4 Cores, Hyper Threading ON
Max Frequency without considering Turbo 1800.00 MHz (100.00 x [18])
Max TURBO Multiplier (if Enabled) with 1/2/3/4 Cores is 39x/38x/37x/37x
Real Current Frequency 1590.57 MHz [100.00 x 15.91] (Max of below)
Core [core-id] :Actual Freq (Mult.) C0% Halt(C1)% C3 % C6 % C7
Core 1 [0]: 1590.57 (15.91x) 12.1 20.7 1.95 20 46.6
Core 2 [1]: 1586.71 (15.87x) 11.5 24.5 2.11 20.3 42.9
Core 3 [2]: 1573.67 (15.74x) 14.6 27.4 3.36 25.6 30.9
Core 4 [3]: 1588.76 (15.89x) 12.4 25.3 1.26 16.4 46.1
sudo cpupower frequency-info:
analisi della CPU 0:
nessun modulo o modulo cpufreq sconosciuto per questa CPU
CPU che operano alla stessa frequenza hardware: Not Available
CPU che è necessario siano coordinate dal software: Not Available
latenza massima durante la transizione: Cannot determine or is not supported.
Not Available
gestori disponibili: Not Available
Unable to determine current policy
current CPU frequency: Unable to call hardware
current CPU frequency: Unable to call to kernel
boost state support:
Supported: no
Active: no
[su root]
sudo touch /sys/devices/system/cpu/cpufreq/boost:
touch: impossibile fare touch di '/sys/devices/system/cpu/cpufreq/boost': Permesso negato
I am pretty new to Linux, but I would still like to have turbo boost working as intended
the weird thing is that i7z sees turbo frequency right, but cpupower says that it doesn’t support boost?
how can I enable this pretty basic feature?
