Pulseaudio starts normally and works fine, but whenever I enable the ability to listen to the line in audio, it takes around 30 seconds for pulseaudio to crash entirely. have to start it up manually.
When I open it up in terminal initially, I see this when I open it up initially, but it’s inconsequential afaik
$ pulseaudio
W: [pulseaudio] pid.c: Stale PID file, overwriting.
E: [pulseaudio] udev-util.c: Failed to get card object.
E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="3" name="usb-FiiO_FiiO_BTR5-00" card_name="alsa_card.usb-FiiO_FiiO_BTR5-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=yes deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
After I initialize the audio via pactl load-module module-loopback, I get this after like 10-30 seconds
E: [alsa-sink-USB Audio] speex.c: Assertion 'speex_resampler_set_rate(state, r->i_ss.rate, r->o_ss.rate) == 0' failed at ../pulseaudio/src/pulsecore/resampler/speex.c:125, function speex_update_rates(). Aborting.
Aborted (core dumped)
Edit: Oh yeah my config file
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
resample-method = speex-float-10
avoid-resampling = true
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
flat-volumes = no
; flat-volumes = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
default-sample-format = float32le
default-sample-rate = 96000
alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
Fabby
8 October 2021 16:51
2
Good diagnostics, just one thing missing:
please?
Sorry about the delay; loong day at work.
Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=ab97410d-219d-4b6b-a11e-ecd4e63ac169 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI)
v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 2103
date: 06/19/2020
RAM: total: 62.72 GiB used: 3.66 GiB (5.8%)
Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 6 MiB bogomips: 182131
Speed: 2069 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2069 2: 2053 3: 2195 4: 2195 5: 2050 6: 2052 7: 3592 8: 3593 9: 2051
10: 2050 11: 2092 12: 3593 13: 3593 14: 2110 15: 2196 16: 2195 17: 2197
18: 3586 19: 2050 20: 2049 21: 2049 22: 3590 23: 2052 24: 2196
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070]
vendor: PC Partner Limited / Sapphire driver: nvidia v: 470.63.01
bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2.1:4 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5120x1440 s-dpi: 121 s-size: 1073x302mm (42.2x11.9")
s-diag: 1115mm (43.9")
Monitor-1: DP-2 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio
vendor: PC Partner Limited / Sapphire driver: snd_hda_intel v: kernel
bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: FiiO FiiO BTR5 type: USB driver: snd-usb-audio bus-ID: 1-1.1:24
chip-ID: 2972:0047 class-ID: fe01
Device-4: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000
bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.96 TiB used: 56.51 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:5 model: PCIe SSD size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM22.6 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: PCIe SSD size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: EGFM11.0 temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
type: HDD rpm: 7200 serial: <filter> rev: CC25 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 56.51 GiB (24.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
label: N/A uuid: ab97410d-219d-4b6b-a11e-ecd4e63ac169
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
uuid: F49E-8144
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: A0CEC91DCEC8ED1A
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 10C9-47BA
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 930.88 GiB fs: ntfs label: N/A
uuid: 084EC9E74EC9CE1E
ID-5: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: externalData
uuid: 2652FC3C52FC11F3
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 3 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-1.1:24 info: FiiO FiiO BTR5 type: Audio driver: snd-usb-audio
interfaces: 3 rev: 2.0 speed: 480 Mb/s chip-ID: 2972:0047 class-ID: fe01
Device-2: 1-1.3:10 info: Realtek BillBoard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 0bda:5418
class-ID: 1100 serial: <filter>
Hub-3: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-5.3:6 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-2: 1-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-3:2 info: Realtek Hub ports: 2 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-7: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 3-2.1:4 info: ARC Camera type: Video,Audio
power: 200mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Device-2: 3-5:3 info: Cooler Master AMD SR4 lamplight Control
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-10: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-11: 5-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Hub-12: 5-2:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
Hub-13: 5-4:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-4.1:5 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 256mA chip-ID: 258a:1007 class-ID: 0301
Device-2: 5-4.4:6 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Hub-14: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-15: 6-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-16: 6-2:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
Hub-17: 6-4:4 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 405 Uptime: 9m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1389 lib: 425
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Fabby
9 October 2021 11:05
4
GinGear:
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”.
You have both PipeWire and PulseAudio running. Please disable PipeWire:
systemctl --user disable --now pipewire.socket && systemctl --user disable --now pipewire.service && systemctl --user mask pipewire.socket
Thanks! I actually tried the kernel thing before, alas it didn’t help. I swapped back after seeing it didn’t.
I kind of forgot about swap, but this pc has 64 gigs of ram so I haven’t encountered issues so far. Hibernation seems nice though so I’ll set it up, even if I don’t plan on using it.
Also, ah, do you know of a clean way of disabling PipeWire? I never manually installed it; so something must have as a dependency or something. Or can I just,
sudo systemctl disable --global pipewire
Another thing, I can monitor the microphone/line in inputs completely fine with OBS on using it’s own monitor system, which I might just end up using instead. Do you think this relates to anything going on?
Fabby
9 October 2021 13:05
6
GinGear:
OBS
Not familiar with that abbreviation…
I suppose all of the above didn’t solve the issue?
If no, please provide the crashdump and the output to pacmd dump
Apologies, I meant OBS-Studio; the entire point of me listening in is to stream my nintendo switch; and the audio was routed in from the line-in spot. I wanted to be able to listen to the gameplay as I played and streamed it at the same time.
I have not yet disabled pipewire, systemctl says it’s not running?
$ systemctl stop pipewire
Failed to stop pipewire.service: Unit pipewire.service not loaded.
$ systemctl stop pipewire-media-session
Failed to stop pipewire-media-session.service: Unit pipewire-media-session.service not loaded.
Fabby
9 October 2021 13:37
8
Post a new inxi --admin --verbosity=7 --filter --no-host --width
please?
It seems to have fully turned off after a reboot.
Well, at least the issue seems to be gone
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
date: 06/19/2020
RAM: total: 62.72 GiB used: 3.37 GiB (5.4%)
L2: 6 MiB bogomips: 182126
Speed: 3247 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 3247 2: 2111 3: 2170 4: 4311 5: 3569 6: 2197 7: 2088 8: 2192 9: 2192
10: 2194 11: 2169 12: 4234 13: 2145 14: 3962 15: 2106 16: 2163 17: 4341
18: 2195 19: 2195 20: 2193 21: 2172 22: 4342 23: 3841 24: 2175
alternate: nouveau,nvidia_drm bus-ID: 0b:00.0 chip-ID: 10de:2484
class-ID: 0300
diag: 604mm (23.8")
diag: 604mm (23.8")
class-ID: 0403
Device-3: FiiO FiiO BTR5 type: USB driver: snd-usb-audio bus-ID: 1-1.1:16
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: no
Local Storage: total: 2.99 TiB used: 56.83 GiB (1.9%)
type: SSD serial: <filter> rev: ECFM22.6 temp: 28.9 C scheme: GPT
type: SSD serial: <filter> rev: EGFM11.0 temp: 37.9 C scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB model: USB DISK 3.0 size: 28.93 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
ID-1: / raw-size: 166.25 GiB size: 162.64 GiB (97.83%)
used: 56.83 GiB (34.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
uuid: F49E-8144
ID-1: swap-1 type: partition size: 71.92 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:8 label: N/A
uuid: fe86311b-6721-4cfd-b9bc-6676c056c68c
uuid: 10C9-47BA
ID-6: /dev/sdb1 maj-min: 8:17 size: 396 MiB fs: iso9660
Device-1: 1-1.1:16 info: FiiO FiiO BTR5 type: Audio driver: snd-usb-audio
class-ID: e001
Device-1: 6-2.4:5 info: Kingston SP Mobile C31 (64GB) type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 504mA
chip-ID: 13fe:6300 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 51.8 C mobo: N/A gpu: nvidia temp: 33 C
Processes: 441 Uptime: 3m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1356 lib: 394
EDIT: I spoke literally 1 second too early; right after I pressed enter to send this message it crashed again. Also it still appears to be running in the above dump
EDIT 2: Ah,
no it seems to be stopped, I misread
Fabby
9 October 2021 14:16
10
Please go back here and follow instructions one-by-one.
The solution for my particular situation does seem to either use OBS as a loopback feed directly, or to just swap to pipewire via
pamac install manjaro-pipewire
I am definitely pipewire permanently if the experience is like this consistently; this is really nice.
It seems I can’t just install pulseaudio again if I wanted to using the same method; so I will have to attempt to see if it was a kernel issue later I guess.
$ pamac install manjaro-pulse
Preparing...
Choose optional dependencies for manjaro-pulse:
1: paprefs: Configuration dialog
2: pasystray: system tray application
3: pavucontrol-qt: A Qt volume control tool
4: pulseaudio-equalizer: for equalizer sink (qpaeq)
5: pulseaudio-equalizer-ladspa: A GUI equalizer
Enter a selection (default=none): ^[[F,^[[B,^[[6~,^[[D,^[[E
Enter a selection (default=none): 1,2,3,4,5
Warning: zsh-theme-powerlevel10k: local (1.15.0+66+g3e515a7-1) is newer than community (1.15.0-2)
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- unable to satisfy dependency 'pulseaudio-bluetooth' required by manjaro-pulse
I’ll downgrade the kernel and test pulseaudio to see if the issue still occurs sometime later in the week when I don’t have work; but I highly suspect it’s just pulseaudio not being able to handle high sample rates and audio quality in general with multiple streams mixing; as I already had to lower the sample rate from 384k, to 96k to prevent crashes.
(and before you ask yes I have actual music and other audio stuff that is at that sample rate, I find it fun)
Oh gdi I edited an old post rather than posting a new one. whoops
Thank you for your time however! I really do appreciate it. nikgnomic as well
I checked pipewire sockets/services again after recent updates and it appears that the pipewire-media-session.service is no longer used
systemctl can manage root privilege elevation without sudo.
Using sudo is likely to fail for --user
services
Option --global
would probably work in place of more specific option --local
Option --now
also stops the service and socket (so rebooting system not needed)
Using OBSstudio is a better option than using a loopback module
Line In and Microphone capture sources can be added direct from ALSA instead of via sound servers PulseAudio, JACK or Pipewire by using the + button to add sources
system
Closed
12 October 2021 06:51
13
