Hello, would anyone be able to help me enable Wayland in Microsoft Edge? I tried to find ozon-platform in edge://flags but couldn’t find it. I’m using Gnome. Thank you!
Search for ozone-platform ![]()
Don’t directly modify desktop files in /usr/share/applications/. Otherwise, the next time the package is updated it will overwrite the desktop file. Instead, copy the desktop file from there to ~/.local/share/applications/ and modify it there.
