Is there some way to enable the Scroll Lock key?
I’ve found that the command:
xmodmap -e 'add mod3 = Scroll_Lock'
will do the trick, but it has to be done every boot and it even last to next boot. It always stops working about 10 minutes.
I’m confused:
Which of the 2 is it?
Sorry for my English. That command is useless, because every about 10 minutes I had toto use that command to activate scroll lock key functionality. Also after reboot.
But I’ve made some next internet research and found working solution.
I wonder why is caps lock key functionality not activated automatically…
Found the permanent way after a long night up with lots of half baked solutions.
# backup your symbols file sudo cp /usr/share/X11/xkb/symbols/us{,.distribution}Add the following line in the
xkb_symbols "basic" {section. do not worry if that second line is not there, it is only there for some languages and was not there for us on my system.... modifier_map Mod3 { Scroll_Lock }; <==<< Add this line include "level3(ralt_switch)" <==<< before this line };You may have to do the same in your other layouts if you switch between languages
Also, there is a cache where xkb layouts live. You should clear it before restarting your X server to check the new keyboard symbol file(s).
sudo rm -f /var/lib/xkb/*
