I broke my kernel and couldn’t fix it, so I had to reinstall my Manjaro.
Before reinstall, I was able to set GPU-core clock offset and GPU-memory clock offset from Nvidia X server.
After reinstall, when I run Nvidia X server, I no longer see these options, under “PowerMizer”
After researching I found some fixes, like creating xorg.conf file in /etc/X11, through sudo nvidia-config and editing nvidia.conf in /etc/X11/mhwd.d. But every time I edited either of these files and rebooted the system, boot screen would show that Samba has failed to initialise and then It wouldn’t load up the GUI. System would not go past [OK] Bluetooth Services, and I would have to switch to a tty and undo all the edits and then reboot the system.
I tried to disable Samba with systemctl disable samba, but it would still get stuck at [ok] Bluetooth Services and won’t go past it.
I tried GreenWithEnvy and overclocking options are greyed out.
System info:
System: Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.3
Machine: Type: Laptop System: HP product: HP Pavilion Notebook v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 8216 v: 83.18 serial: <filter> UEFI: Insyde v: F.52 date: 05/02/2019
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S charge: 55% (should be ignored)
status: Discharging
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check
rev: 9 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
Speed: 742 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 742 2: 771 3: 700 4: 707
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard driver: nvidia v: 460.67 bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
Device-2: JMTek LLC. USB PnP Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-6.2:5
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus-ID: 03:00.0
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: 3000
bus-ID: 05:00.0
IF: wlo1 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
Drives: Local Storage: total: 2.26 TiB used: 1.18 TiB (52.4%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
ID-2: /dev/sdb vendor: Western Digital model: WDS480G2G0A-00JH30 size: 447.13 GiB
Partition: ID-1: / size: 421.94 GiB used: 106.93 GiB (25.3%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1
Swap: ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) dev: /dev/sdb3
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A
Info: Processes: 216 Uptime: 30m Memory: 15.52 GiB used: 2.2 GiB (14.2%) Init: systemd Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: 1480 Shell: Zsh v: 5.8 inxi: 3.3.03
Thank you.
