Following NVIDIA/Tips and tricks - ArchWiki,
It created an xorg.conf file in /etc/X11. After a reboot, boot hangs and it shows the network card crashing for some reason and starts dumping the last line repeatedly until I force reboot:
rtw_8822ce 0000:04:00.0: sta 04:33:89:19:2c:8c with macid 0 left
[ 5162.453798] ieee80211 phy0: Hardware restart was requested
[ 5162.669555] rtw_8822ce 0000:04:00.0: start vif d8:c0:a6:58:69:1b on port 0
[ 5162.886611] rtw_8822ce 0000:04:00.0: sta 04:33:89:19:2c:8c joined with macid 0
[ 5162.889840] rtw_8822ce 0000:04:00.0: failed to send h2c command
After some research, I read that Manjaro uses /etc/X11/mhwd.d//nvidia.conf instead. I tried copy pasting the content of xorg.conf to nvidia.conf but I end up getting the same error.
Here are some specs that might be relevant.
Host: PZ0-ASUS-TUF-FX505DT-HN657T Kernel: 5.13.5-1-MANJARO x86_64 bits: 64
compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=/dev/nvme0n1p1 rw
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 cache: L2: 2 MiB
bogomips: 33550
Speed: 2635 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 2635 2: 2586 3: 1534 4: 1570 5: 2171 6: 2485 7: 1948 8: 1299
disabled, RSB filling
raphics:
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: 0x0001
Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0
5.13.5-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Not sure if I am doing something wrong, missing a step or accidentally uncovered a bug.
