Even after enabling in preferences, aur packages are not visible when searching in pamac
Did you update the database?
At the moment i get also this strange error:
pamac search linux57
** (pamac:2000): WARNING **: 14:57:48.417: aur.vala:60: ZeitĂĽberschreitung bei Ein-/Ausgabeoperation des Sockets
(translation: Socket input/output operation timeout)
Could be not only me?
Have you tried restarting Pamac, or perhaps logging out and back in, or even a Restart? Simple things I know, but It’s the first thing I would try. Also sudo pacman -Syu in a terminal. Pamac may just need a little “nudge” in order to see the aur packages. Apologies if you have already tried these rather obvious things. Apart from that I have no idea unless you try uninstallling Pamac and then reinstalling.
think there might be a connectivity glitch right now. i can’t reach the aur either through trizen or the web interface.
504 Gateway Time-out
Yeah I did all that. No effect
Okay, now that i try opening in browser, it seems its really down. That was unexpected
It took me a long time to open the AUR packages link in a browser, but it finally opened. Just now Pamac was not showing AUR packages but it is now. It seems the problem is at the Arch end. Just sit back for a while I guess…
You can use the –aur or -a parameter in the syntax pamac search -a , then it doesn’t matter if it is enabled in the GUI or not
--no-aur excludes searching in AUR.
