eMudhra Intermediate CA-Certificates Compromised
It would be much appreciated if an update of the ca-certificates-mozilla package can be pushed out of band.
There has been a compromise of intermediate certificates which means bogus certificates can be generated for a trusted root.
More details: https://emudhra.we-have-a-problem.com/
Thanks in advance.
Mod edit:- Title edited for brevity. No charge.
firefox v158.0.1, which is in all 3 Manjaro repos, should fix that issue:
Output of: mbn info firefox -q | grep -Ev 'Name|Repository|Packager'
Branch : archlinux
Version : 158.0.1-1
Build Date : Tue 20 Oct 2026 19:58:20
Branch : unstable
Version : 158.0.1-1
Branch : testing
Version : 158.0.1-1
Branch : stable
Version : 158.0.1-1
mbn can be found in the manjaro-check-repos package
I had just updated and checked this. Firefox is at 158.0.1 on my system, but pacman -Qi ca-certificates-mozilla returns 3.128-1.
So at least on my system, the update of Firefox did not update the certificates package. I don’t know what’s wrong then.
[Edit:] The certificates package has been updated on my Arch install.
firefox uses a block list to block the compromised certificates, so an update to the ca-certificates-mozilla package shouldn’t be immediately required.
Output of: mbn info ca-certificates-mozilla -q
Branch : archlinux
Version : 3.131.1-1
Repository : core
Build Date : Wed 21 Oct 2026 01:11:09
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Branch : unstable
Version : 3.131.1-1
Repository : core
Branch : testing
Version : 3.130-1
Repository : core
Build Date : Thu 24 Sep 2026 05:36:29
Branch : stable
Version : 3.128-1
Repository : core
Build Date : Thu 27 Aug 2026 11:38:19
However, as the versions of ca-certificates-mozilla in Testing & Stable branches are both behind Arch & Unstable, if you are still concerned that the older package in your branch might cause issues, then you could switch to Unstable branch to ensure you have the latest packages. Switching branches is a fairly simple process:
To switch to Unstable branch:
sudo pacman-mirrors -a -B unstable && sudo pacman-mirrors -f && sudo pacman -Syyu
To return to Stable branch:
sudo pacman-mirrors -a -B stable && sudo pacman-mirrors -f && sudo pacman -Syyuu
Note: the extra u is required to enable package downgrades when moving from Unstable to Testing or Stable, or from Testing to Stable
Point is, ca-certificates uses the mozilla package to generate the trust store data which is used system wide, so other packages don’t necessarily use the CRL that Firefox uses. At least, that is my understanding and i could be missing the point somewhere :slight_smile:
My understanding mightn’t be perfect either (actually, I know it is a long way from perfect).
I do know that the advantage of block lists is that the browser downloads them from a remote location - I’m not sure how frequently though (such as browser start-up, every 5 minutes). That means that the block list should be updated more frequently than it would be if it had to wait until a system update was done.
Still, it might alleviate some concerns if the Manjaro Team was able to fast-track the latest version of ca-certificates-mozilla to the Testing & Stable branches.
A valid request.
Branch         : archlinux
Version        : 3.131.1-1
Repository     : core
Build Date     : Wed 21 Oct 2026 00:41:09
Branch         : unstable
Version        : 3.131.1-1
Repository     : core
Branch         : testing
Version        : 3.130-1
Repository     : core
Build Date     : Thu 24 Sep 2026 05:06:29
Branch         : stable
Version        : 3.128-1
Repository     : core
Build Date     : Thu 27 Aug 2026 11:08:19
Let’s see if we can prompt some action. @philm @Yochanan
The example usage of curl that the we-have-a-problem website shows highlights how it affects things other than firefox. On my up2date manjaro system this curl call accepts the certificate.
That seems to indicate to me that an urgent update of the system certs is needed.
Stable branch;
$ curl https://dv-g3b-emudhra.we-have-a-problem.com/
Your client successfully connected to the site. That's bad!
After manually updating to ca-certificates-mozilla-3.131.1-1;
curl: (60) SSL certificate OpenSSL verify result: unable to get local issuer certificate (20)
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the webpage mentioned above.
which is the correct response. This is URGENT.
Done, no need to wait.
The Internet goes on high alert after discovery of 8 compromised TLS certs
Arstechnica
Most browsers have already patched them out. Arch updated the CA-Certs package. The most interesting thing is the code-signing ones, as they will take longer for blocks to roll out.
Mod edit:- URL now bears title of target article. No charge.
@akin2silver
Thanks for the info. As you can see, there is already a Feedback thread concerning this issue, so I have moved your post here.
If users are concerned, they can download latest version from Arch core repository:
ca-certificates-mozilla-3.131.1-1-x86_64.pkg.tar.zst
and install it locally:
pamac install ca-certificates-mozilla-3.131.1-1-x86_64.pkg.tar.zst
Why not using manjaro-downgrade to install the unstable branch repo version, which is up-to-date?
I appreciate everyone offering solutions for updating the package. Thanks @Wollie, I didn’t realize I could use manjaro-downgrade to actually upgrade, that is very neat!
I want to put forward an idea though, that comes from doing IT security as a dayjob for my colleagues who don’t care about computers and just want to get things done with as little fuss as possible.
That idea is simply: sane defaults and secure by design.
This helps both the uninitiated/uncaring and those like us, who mess with Linux for fun and, in my case, started poking at computers in the 8bit era.
This line of thinking is why we already do get the browser updates fasttracked, right? So, in the case of this fairly important package update, the sane and secure thing to do, would be simply bump it into stable. Maybe add an announcement on the forum. That way you don’t leave it up to each and every individual’s wildly varying abilities, judgement and alertness.
I really do appreciate that eventually, this is a slippery slope. Before you know it, other things are Important Updates as well and you basically end up at the rolling release model. So I would fully support the release managers having ultimate say in what goes, but it would be nice if Manjaro had some sort of policy or mechanism to suggest updates like this, take a decision and update (or not). At least that way there is an informed decision from the project as a whole.
ca-certificates-mozilla / nss / lib32-nss 3.131.1 are now available in all branches:
  • Unstable: 3.131.1-1
  • Testing: 3.131.1-0.2
  • Stable: 3.131.1-0.1
