Hi,
I’m trying to configure emojis on my system and I’m almost complete , but I’m struggling with Firefox, all the emojis inside web pages appear as an outline font, here are some screenshots:
In G Classroom
In YouTube’s search bar
But it only happens inside web pages, elements of the Firefox interface display fonts fine, here is an example in the adress bar:
I’ve tried some things, but didn’t work.
My current setup of emoji fonts are just the AUR ttf-twemoji package, I removed the noto-fonts-emoji package, and created a symlink for Twemoji
Thanks, I’ll try this and come back to mark this as solution if works for me, but I have a question, can I use this same config but with Twemoji? I think I just need to replace Noto Color Emoji with Twemoji (or whatever is called)
Well, I have another question, I’m using another font for the interfaces, I’m not using the default Noto Sans, I’m using Inter, do I have to replace that somewhere in the config? And also in monospace? I’m using another monospace font, not the default
