Manjaro boots into Emergency mode after editing fstab to mount drives.
Here is my fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=0d24548a-528a-477d-ae87-ef1af05880aa / btrfs subvol=/@,defaults,discard=async,ssd 0 0
UUID=0d24548a-528a-477d-ae87-ef1af05880aa /var/cache btrfs subvol=/@cache,defaults,discard=async,ssd 0 0
UUID=0d24548a-528a-477d-ae87-ef1af05880aa /var/log btrfs subvol=/@log,defaults,discard=async,ssd 0 0
UUID=bb4a3dec-91d5-47c4-9af4-ae7d68da84cb /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=8ef8bd2f-dbe6-42b6-aa88-f0cfc3745de6 /mnt/GAMING ext4 defaults 0 0 nofail
UUID=19263c53-23f2-49ad-99eb-d57e1269cc6b /mnt/DOCUMENTS ext4 defaults 0 0 nofail
UUID=a6d7961b-52de-4738-b12e-a3ef209f61c5 /mnt/ENTERTAINMENT ext4 defaults 0 0 nofail
I searched these forums and I found a piece of advice to add nofail but this didnt fix it for me.
I found another possible solution, to try and mount the drives via systemd. So I tried that.
I created 3 files in /etc/systemd/system that follow this pattern
mnt-DOCUMENTS.mount
mnt-GAMING.mount
mnt-ENTERTAINMENT.mount
The contents of each of those files looks like this
[Unit]
Description=Mount DOCUMENTS
[Mount]
What=/dev/disk/by-uuid/19263c53-23f2-49ad-99eb-d57e1269cc6b
Where=/mnt/DOCUMENTS
Type=ext4
Options=defaults,rw,noatime
#TimeoutSec=seconds
[Install]
WantedBy=multi-user.target
Obviously content is adjusted for each UUID and mount point.
I still have the same problem. Manjaro boots to Emergency mode which is non-interactive. I can only boot into the system via a Timeshift snapshot.
here is my inxi
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2024-05-16_22-41-49/@/boot/vmlinuz-6.9-x86_64
root=UUID=0d24548a-528a-477d-ae87-ef1af05880aa quiet splash
udev.log_priority=3
rootflags=defaults,discard=async,ssd,subvol=timeshift-btrfs/snapshots/2024-05-16_22-41-49/@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends LLC. v: F39
date: 03/22/2024
System RAM: total: 32 GiB available: 31.27 GiB used: 3.72 GiB (11.9%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2D3600C18 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB
desc: 1x96 MiB
Speed (MHz): avg: 2434 high: 4456 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3149 2: 2200
3: 2544 4: 2408 5: 2200 6: 2200 7: 4456 8: 2200 9: 2200 10: 2200 11: 2200
12: 2199 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 108838
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3 empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 0b:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:10
chip-ID: 046d:0826 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-1 pos: primary,left model: LG (GoldStar) 27GL650F
serial: <filter> built: 2019 res: 1920x1080 hz: 144 dpi: 82 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-3 pos: right model: LG (GoldStar) 27GL650F serial: <filter>
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.9.0-1-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 24.0.6-manjaro1.1
device-ID: 1002:73bf surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
Device-4: Focusrite-Novation Scarlett 2i4 driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.3:11
chip-ID: 1235:800a class-ID: fe01
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic scope: global broadcast: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.3:4
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 18.63 TiB used: 213.93 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Sabrent
model: SB-ROCKET-NVMe4-2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: RKT4B5.1 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 27.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> scheme: MBR
ID-7: /dev/sdg maj-min: 8:96 vendor: SanDisk model: Ultra Fit
size: 114.56 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-8: /dev/sdh maj-min: 8:112 vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 8.01 scheme: MBR
ID-9: /dev/sdi maj-min: 8:128 vendor: SanDisk model: USB 3.2Gen1
size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 68.76 GiB (13.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
uuid: 0d24548a-528a-477d-ae87-ef1af05880aa
ID-2: /home raw-size: 1.33 TiB size: 1.31 TiB (98.35%)
used: 145.17 GiB (10.8%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:5
label: N/A uuid: bb4a3dec-91d5-47c4-9af4-ae7d68da84cb
ID-3: /var/cache raw-size: 500 GiB size: 500 GiB (100.00%)
used: 68.76 GiB (13.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
label: N/A uuid: 0d24548a-528a-477d-ae87-ef1af05880aa
ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
ID-1: swap-1 type: partition size: 800 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:6 label: N/A
uuid: 4643b72c-393d-468e-acbf-944313fd2402
ID-1: /dev/nvme0n1p1 maj-min: 259:3 size: 8 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme1n1p1 maj-min: 259:2 size: 1.86 TiB fs: ext4 label: GAMING
uuid: 8ef8bd2f-dbe6-42b6-aa88-f0cfc3745de6
ID-3: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
uuid: F7D0-91AA
ID-4: /dev/sda2 maj-min: 8:2 size: 1.79 TiB fs: btrfs label: N/A
uuid: 232fe29c-93cb-4d58-a28d-b06ce5f74a36
ID-5: /dev/sda3 maj-min: 8:3 size: 31.26 GiB fs: swap label: N/A
uuid: 9bd8c0a7-3b68-444c-b435-070289da78e8
ID-6: /dev/sdb1 maj-min: 8:17 size: 5.46 TiB fs: ext4 label: ENTERTAINMENT
uuid: a6d7961b-52de-4738-b12e-a3ef209f61c5
ID-7: /dev/sdc1 maj-min: 8:33 size: 5.46 TiB fs: ext4 label: DOCUMENTS
uuid: 19263c53-23f2-49ad-99eb-d57e1269cc6b
ID-8: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: <superuser required>
ID-9: /dev/sdg1 maj-min: 8:97 size: 114.56 GiB fs: exfat label: LITTLESTICK
uuid: FF7F-EF2E
ID-10: /dev/sdh1 maj-min: 8:113 size: 58.56 GiB fs: exfat label: Ventoy
uuid: 386C-5E29
ID-11: /dev/sdh2 maj-min: 8:114 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 3F32-27F5
ID-12: /dev/sdi1 maj-min: 8:129 size: 232.87 GiB fs: vfat label: APP STICK
uuid: 1D57-6408
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-2.3:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-3.4:6 info: HP Photosmart 6520 series
type: printer,mass storage driver: usb-storage,usblp interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 03f0:af11 class-ID: 0806 serial: <filter>
Device-2: 1-4:5 info: Integrated Express IT8297 RGB LED Controller
type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 048d:8297 class-ID: 0301
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 2-2:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Device-1: 2-2.1:3 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E
ASM1153 3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Device-2: 2-2.4:4 info: Genesys Logic USB Storage type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 05e3:0764 class-ID: 0806
serial: <filter>
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-7: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-10: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-1.1:4 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 5-1.3:6 info: Areson Corp Elecom MR-K013 Multicard Reader
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 25a7:fa61 class-ID: 0301
Device-3: 5-1.4:10 info: Logitech HD Webcam C525 type: audio,video
Hub-11: 5-2:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 5-2.1:7 info: Razer USA Naga Trinity type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0067 class-ID: 0300
serial: <filter>
Device-2: 5-2.3:11 info: Focusrite-Novation Scarlett 2i4 type: audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1235:800a class-ID: fe01
Device-3: 5-2.4:12 info: Microdia Backlit Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
chip-ID: 0c45:652f class-ID: 0301
Hub-12: 5-3:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-3.3:9 info: Holtek USB Gaming Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a0f8 class-ID: 0300
Hub-13: 5-4:8 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-14: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-15: 6-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-16: 6-2:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-17: 6-3:4 info: Genesys Logic Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
Device-1: 6-3.4:6 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
Hub-18: 6-4:5 info: Genesys Logic Hub ports: 4 rev: 3.0
Device-1: 6-4.2:7 info: Alcor Micro Flash Drive type: mass storage
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Device-2: 6-4.3:8 info: SanDisk Ultra Flair type: mass storage
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 41.0 C mobo: 28.0 C gpu: amdgpu temp: 33.0 C
mem: 40.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 394 Power: uptime: 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1917 pm: dpkg pkgs: 0 pm: pacman pkgs: 1862 libs: 523
tools: pamac,yay pm: flatpak pkgs: 55 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
