Eluktronics Max-15 hangs, sleeps randomly, etc. when on battery
Hi, I’m a Linux newbie with a fresh Manjaro install on my Eluktronics max-15. System runs fine on AC, but when I unplug it I quickly encounter a number of issues: the system hangs periodically, inputs are duplicated (I type “a” and “aaaaaaaaaa” appears), my computer randomly goes to sleep, and the wifi may disconnect and be unable to locate any networks. I have no such issues running Windows on the same computer. Any help would be appreciated!
System information:
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=b3b48cd2-d452-4554-a6f8-9dfb77d341ef rw quiet apparmor=1
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Eluktronics product: MAX-15 v: Standard
  serial: <filter>
  Mobo: Eluktronics model: GK5CP0Y v: Standard serial: <filter>
  UEFI: American Megatrends v: N.1.02 date: 11/28/2019
  ID-1: BAT0 charge: 53.2 Wh condition: 53.2/62.3 Wh (85%) volts: 17.1/15.2
  model: standard type: Li-ion serial: <filter> status: Full
  Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
  L2 cache: 12.0 MiB
  bogomips: 62431
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Tongfang Hongkong Limited
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
  vendor: Tongfang Hongkong Limited driver: nvidia v: 450.66
  alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f11
  Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus ID: 1-13:4
  chip ID: 04f2:b68b serial: <filter>
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
  driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Tongfang Hongkong Limited
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus ID: 00:1f.3 chip ID: 8086:a348
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  port: 7000 bus ID: 00:14.3 chip ID: 8086:a370
  vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: 3000
  bus ID: 04:00.0 chip ID: 10ec:8168
  IF: enp4s0 state: down mac: <filter>
  Local Storage: total: 931.51 GiB used: 12.46 GiB (1.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: 2B2QEXE7 scheme: GPT
  ID-2: /dev/nvme1n1 model: 500GB-PRO-X-SS size: 465.76 GiB block size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
  rev: R1115F0 scheme: GPT
  ID-1: / raw size: 30.00 GiB size: 29.40 GiB (98.01%) used: 9.19 GiB (31.3%)
  fs: ext4 dev: /dev/nvme1n1p2
  ID-2: /home raw size: 430.76 GiB size: 423.00 GiB (98.20%)
  used: 3.24 GiB (0.8%) fs: ext4 dev: /dev/nvme1n1p3
  ID-1: swap-1 type: partition size: 5.00 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme1n1p1
  System Temperatures: cpu: 53.0 C mobo: 42.0 C
  Processes: 326 Uptime: 22h 50m Memory: 15.50 GiB used: 3.35 GiB (21.6%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1223 pacman: 1219
  lib: 319 flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: konsole
  inxi: 3.1.05
Here’s a dump of the journald after I unplugged the computer: https://pastebin.com/YWvN1B03
:+1: Welcome to Manjaro! :+1:
If you’re new, the best thing you can do is install slimbookbattery:
pamac install slimbookbattery
That’s a GUI frontend to tlp and you should set the settings to balanced because you’re using way too stringent battery savings and then :poop: like this happens if you don’t use your laptop for about 1 minute…
:wink:
Thanks for your help! Unfortunately, running slimbookbattery on any of its settings does not seem to affect my problems at all. If overzealous power management is to blame, is there some other service I need to disable or setting I need to adjust?
Yup, TLP is the standard one and more documentation can be found:
:+1:
