Hi,
i’m using the elgato streamdeck xl. Most functions are working, without “Press Keys” and “Write Text”.
Does anybody has a hint how to use this?
Can you go further into details? We press keys and write text every ■■■■■■■ day, no?
Edit: 2 min google search:
Check out
[Github] streamdeck-ui and/or Install xautomation or xdotool
Should solve the issue quite frankly.
Did you build AUR package streamdeck-ui?
Or follow instructions for Installing on Arch · streamdeck-ui · GitHub?
Github page has 15 open issue reports for “streamdeck xl”
Hey, it’s working and how do i solved it: “i didn’t do anything”… except a shutdown, and one day later a start of my laptop. So i think that not every dependency was started as i installed it.
Thanks.
