Oh sorry, here’s the output from inxi
Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=1db409f5-c8b1-4ad1-a8ec-c4ca3402733b rw quiet apparmor=1
security=apparmor resume=UUID=af605eac-94c6-40cb-9b46-c72617f084e2
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: Micro-Star model: PRO Z690-A DDR4(MS-7D25) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.10 date: 12/13/2021
System RAM: total: 32 GiB available: 31.14 GiB used: 7.01 GiB (22.5%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Controller0-DIMMA1 type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMK16GX4M2B3200C16
serial: N/A
Device-2: Controller0-DIMMA2 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Device-3: Controller1-DIMMB1 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Device-4: Controller1-DIMMB2 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x35
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 796 high: 800 min/max: 800/4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 796 4: 788
5: 800 6: 800 7: 800 8: 757 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 bogomips: 118000
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq
pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1
xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: none
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA GA104 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-3
empty: DP-4,HDMI-A-5,HDMI-A-6 bus-ID: 01:00.0 chip-ID: 10de:2487
class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: DP-3 mapped: DP-0 note: disabled model: VG259QM serial: <filter>
built: 2021 res: 1920x1080 dpi: 90 gamma: 1.2 chroma: red: x: 0.651 y: 0.341
green: x: 0.306 y: 0.639 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9
modes: 1920x1080, 1280x1024, 1280x800, 1280x720, 1440x576, 1024x768,
1440x480, 800x600, 720x576, 720x480, 640x480
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.90.07
device-ID: 10de:2487 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics 770 (ADL-S GT1) driver: mesa intel
v: 24.1.1-manjaro1.1 device-ID: 8086:4680 surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.1.3:10 chip-ID: 0c76:161e class-ID: 0300
API: ALSA v: k6.6.34-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
chip-ID: 8086:15f3 class-ID: 0200
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 0b05:190e
Local Storage: total: 4.55 TiB used: 2.53 TiB (55.7%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 43.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-1: / raw-size: 128 GiB size: 125.43 GiB (97.99%) used: 52.25 GiB (41.7%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 1db409f5-c8b1-4ad1-a8ec-c4ca3402733b
used: 608 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 4D4A-9B9B
ID-3: /home raw-size: 786.38 GiB size: 772.97 GiB (98.29%)
used: 397.65 GiB (51.4%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: 2d4f9509-0211-4fe2-a33f-906ed7730c04
ID-4: /mnt/d820a04b-0b0d-4dc4-9bc2-e0b3710087ff raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 1.48 TiB (82.9%) fs: ext4 dev: /dev/nvme0n1
maj-min: 259:0 label: 2TB SSD uuid: d820a04b-0b0d-4dc4-9bc2-e0b3710087ff
ID-5: /run/media/enrique/0181b8de-2f24-4f93-85f0-b8c2aafad9da
raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 625.84 GiB (34.1%) fs: ext4
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0181b8de-2f24-4f93-85f0-b8c2aafad9da
ID-1: swap-1 type: partition size: 16.6 GiB used: 2.5 MiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: af605eac-94c6-40cb-9b46-c72617f084e2
Device-1: 1-2:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d25 class-ID: 0300
serial: <filter>
Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 1-5.1:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-5.1.1:8 info: Keebio Iris Rev. 7 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: cb10:7256 class-ID: 0300
Device-2: 1-5.1.2:9 info: Razer USA DeathAdder V2 Mini type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:008c class-ID: 0300
Device-3: 1-5.1.3:10 info: JMTek LLC. USB PnP Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-4: 1-5.1.4:11 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 1-5.3:7 info: XP-Pen Deco Pro XLW (Gen 2) type: mouse,HID
driver: hid-generic,usbfs,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 70mA
chip-ID: 28bd:0944 class-ID: 0300 serial: <filter>
Device-2: 1-12:4 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Hub-5: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-6: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-7: 2-4:2 info: Realtek Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-8: 2-4.4:3 info: Realtek Hub ports: 4 rev: 3.1
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (rpm): cpu: 367 fan-2: 0 fan-3: 932 fan-4: 0 fan-5: 0 fan-6: 0
fan-7: 0 fan-8: 944 fan-9: 0 fan-10: 0 gpu: nvidia fan: 49%
Packages: 2744 pm: pacman pkgs: 2725 libs: 548 tools: pamac pm: appimage
pkgs: 0 pm: flatpak pkgs: 15 pm: snap pkgs: 4
1: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
6: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 440
1: cpu: 32.7% command: Discord pid: 3006 mem: 471.6 MiB (1.4%)
2: cpu: 20.8% command: firefox pid: 8574 mem: 786.2 MiB (2.4%)
3: cpu: 13.5% command: firefox pid: 10573 mem: 262.5 MiB (0.8%)
4: cpu: 12.0% command: firefox pid: 16453 mem: 212.9 MiB (0.6%)
5: cpu: 9.7% command: firefox pid: 15661 mem: 231.2 MiB (0.7%)
Memory top: 5 of 440
1: mem: 786.2 MiB (2.4%) command: firefox pid: 8574 cpu: 20.8%
2: mem: 761.7 MiB (2.3%) command: thunderbird pid: 1978 cpu: 0.4%
3: mem: 651.2 MiB (2.0%) command: steamwebhelper pid: 4425 cpu: 2.3%
4: mem: 471.6 MiB (1.4%) command: Discord pid: 3006 cpu: 32.7%
5: mem: 455.8 MiB (1.4%) command: plasmashell pid: 1780 cpu: 1.1%
Processes: 440 Power: uptime: 56m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: kitty
inxi: 3.3.35
