Dear All,
The issue I’m facing with is the touchpad not being available once the laptop is put to sleep, be it through closing the top lid or by going over start menu. It doesn’t matter if I choose “suspned/hibernate/hybrid sleep”. Once put to sleep, when it’s back then no thouchpad whatsoever. In addition to that sometimes keyboard is behaving erratic. It renders multiple letters/signs of the same, thus I’m unable to log back in.
On the other hand, when started from usb with the same version of the OS, at least closing the lid and opening it back again doesn’t render the touchpad or keyboard unavailable.
Below I’m pasting the inxi output. Btw. I’ve been through some similar threads on here, but unfortunately none was either completely solved or gave indication as to how to tackle the problem properly.
Summary:
Issue : touchpad not working once laptop is back from being put to sleep through closing lid or by invoking it through start menu. The same applies when putting the laptop to hibernation or any other form of state that one can resume from. No issue when started from usb, though.
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1cd3f08f-c9b8-40af-bbb1-56a530074f47 rw quiet splash
resume=UUID=e3e104fe-596e-46a6-a74a-c7fe0327ad58 udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: FUJITSU product: LIFEBOOK E557 v: 10601115935
serial: <filter> Chassis: type: 10 v: LIFEBOOK E557 serial: <filter>
Mobo: FUJITSU model: FJNB2A2 v: A1 serial: <filter> UEFI: FUJITSU // Insyde
v: Version 1.12 date: 08/22/2018
ID-1: CMB1 charge: 19.5 Wh (85.9%) condition: 22.7/62.2 Wh (36.5%)
volts: 12.7 min: 11.1 model: Fujitsu CP708751-01 type: Li-ion
serial: <filter> status: charging
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 400 min/max: 400/3100 base/boost: 2400/2700 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 21607
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Fujitsu driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 04f2:b413
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: LG Display 0x04a7 built: 2015 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 30.51 GiB unified: yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Fujitsu
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
Device-1: Intel Ethernet I219-V vendor: Fujitsu driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
class-ID: e001
Local Storage: total: 148.78 GiB used: 7.69 GiB (5.2%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: USD00 size: 29.54 GiB block-size:
physical: 512 B logical: 512 B type: Removable tech: SSD serial: <filter>
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Apacer model: AS350 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3PE0 scheme: GPT
ID-1: / raw-size: 84.57 GiB size: 82.69 GiB (97.77%) used: 7.69 GiB (9.3%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 217 Uptime: 13m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 3.55 GiB (11.3%) igpu: 32 MiB Init: systemd v: 255
Packages: pm: pacman pkgs: 989 libs: 288 tools: octopi,pamac,yay
Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
lsusb
Bus 001 Device 002: ID 0451:8043 Texas Instruments, Inc. Hub
Bus 001 Device 003: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 004: ID 04f2:b413 Chicony Electronics Co., Ltd FJ Camera
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0451:8041 Texas Instruments, Inc. Hub
dmesg
psmouse serio2: elantech: assuming hardware version 4 (with firmware version 0x570f01)
psmouse serio2: elantech: Synaptics capabilities query result 0x40, 0x14, 0x0c.
psmouse serio2: elantech: Elan sample query result 02, 24, a7
lsmod before sleep/suspend mode are the same:
ac97_bus 12288 1 snd_soc_core
acpi_pad 24576 0
aesni_intel 360448 4
af_alg 36864 6 algif_hash,algif_skcipher
algif_hash 12288 1
algif_skcipher 12288 1
atkbd 40960 0
bluetooth 1114112 44 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
bnep 36864 2
bpf_preload 20480 0
btbcm 24576 1 btusb
btintel 57344 1 btusb
btmtk 12288 1 btusb
btrtl 32768 1 btusb
btusb 86016 0
cec 86016 2 drm_display_helper,i915
cfg80211 1339392 3 iwlmvm,iwlwifi,mac80211
cmac 12288 3
coretemp 16384 0
crc16 12288 2 bluetooth,ext4
crc32c_generic 12288 0
crc32c_intel 16384 2
crc32_pclmul 12288 0
crct10dif_pclmul 12288 1
cryptd 28672 3 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 20480 0
dm_mod 225280 0
drm_buddy 20480 1 i915
drm_display_helper 229376 1 i915
e1000e 368640 0
ecdh_generic 16384 2 bluetooth
ee1004 16384 0
ext4 1175552 1
fat 106496 1 vfat
fujitsu_laptop 28672 0
fuse 212992 5
gf128mul 16384 1 polyval_generic
ghash_clmulni_intel 16384 0
i2c_algo_bit 20480 1 i915
i2c_i801 40960 0
i2c_smbus 20480 1 i2c_i801
i8042 53248 0
i915 4136960 5
intel_cstate 20480 0
intel_gtt 28672 1 i915
intel_pmc_bxt 16384 1 iTCO_wdt
intel_powerclamp 20480 0
intel_rapl_common 40960 1 intel_rapl_msr
intel_rapl_msr 20480 0
intel_tcc_cooling 12288 0
intel_uncore 258048 0
intel_wmi_thunderbolt 16384 0
intel_xhci_usb_role_switch 12288 0
ip_tables 36864 0
irqbypass 12288 1 kvm
iTCO_vendor_support 12288 1 iTCO_wdt
iTCO_wdt 16384 0
iwlmvm 696320 0
iwlwifi 569344 1 iwlmvm
jbd2 221184 1 ext4
joydev 24576 0
kvm 1376256 1 kvm_intel
kvm_intel 425984 0
ledtrig_audio 12288 1 snd_hda_codec_generic
libarc4 12288 1 mac80211
libps2 20480 2 atkbd,psmouse
loop 40960 0
mac80211 1572864 1 iwlmvm
mac_hid 12288 0
mbcache 16384 1 ext4
mc 90112 6 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mei 200704 5 mei_hdcp,mei_pxp,mei_me
mei_hdcp 28672 0
mei_me 57344 2
mei_pxp 16384 0
mmc_block 65536 0
mmc_core 270336 2 rtsx_pci_sdmmc,mmc_block
Module Size Used by
mousedev 24576 0
nfnetlink 20480 1
pcspkr 12288 0
polyval_clmulni 12288 0
polyval_generic 12288 1 polyval_clmulni
psmouse 233472 0
qrtr 57344 4
rapl 20480 0
rfcomm 102400 16
rfkill 40960 8 iwlmvm,bluetooth,cfg80211
roles 16384 1 intel_xhci_usb_role_switch
rtsx_pci 131072 1 rtsx_pci_sdmmc
rtsx_pci_sdmmc 32768 0
serio 28672 9 serio_raw,atkbd,psmouse,i8042
serio_raw 16384 0
sha1_ssse3 32768 0
sha256_ssse3 32768 0
sha512_ssse3 53248 0
snd 155648 16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
snd_compress 28672 2 snd_soc_avs,snd_soc_core
snd_hda_codec 225280 8 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_soc_skl
snd_hda_codec_generic 114688 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 94208 1
snd_hda_codec_realtek 196608 1
snd_hda_core 151552 10 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_soc_skl
snd_hda_ext_core 36864 4 snd_soc_avs,snd_soc_hda_codec,snd_soc_hdac_hda,snd_soc_skl
snd_hda_intel 65536 1
snd_hrtimer 12288 1
snd_hwdep 20480 1 snd_hda_codec
snd_intel_dspcfg 40960 3 snd_soc_avs,snd_hda_intel,snd_soc_skl
snd_intel_sdw_acpi 16384 1 snd_intel_dspcfg
snd_pcm 204800 9 snd_soc_avs,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_compress,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_seq 131072 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
snd_seq_dummy 12288 0
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_soc_skl
snd_soc_acpi_intel_match 94208 1 snd_soc_skl
snd_soc_avs 221184 0
snd_soc_core 458752 4 snd_soc_avs,snd_soc_hda_codec,snd_soc_hdac_hda,snd_soc_skl
snd_soc_hdac_hda 28672 1 snd_soc_skl
snd_soc_hda_codec 28672 1 snd_soc_avs
snd_soc_skl 241664 0
snd_soc_sst_dsp 45056 1 snd_soc_skl
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_timer 53248 3 snd_seq,snd_hrtimer,snd_pcm
soundcore 16384 1 snd
sparse_keymap 12288 1 fujitsu_laptop
ttm 110592 1 i915
uas 32768 0
usb_storage 90112 1 uas
uvc 12288 1 uvcvideo
uvcvideo 176128 4
vfat 20480 1
video 77824 2 fujitsu_laptop,i915
videobuf2_common 94208 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videobuf2_memops 16384 1 videobuf2_vmalloc
videobuf2_v4l2 40960 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 389120 4 videobuf2_v4l2,uvcvideo
vivaldi_fmap 12288 1 atkbd
wmi 45056 2 video,intel_wmi_thunderbolt
x86_pkg_temp_thermal 16384 0
xhci_pci 28672 0
xhci_pci_renesas 24576 1 xhci_pci
x_tables 69632 1 ip_tables
