My ELAN Touch pad is not detected by the system. It used to work fine in the pre-configured Windows 10 that it came with but it is not working on any Linux distro now.
The same issue happens with Ubuntu as well. It also does not seem to work on a fresh install of Windows 10 too.
I have tried all the solutions available online regarding this topic but none of them seem to work.
I have attached the output of xinput list.
Please tell if I should attach some other results.
Thanks
Kernel Version: 5.12.9-1
xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech USB Optical Mouse id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Integrated Camera: Integrated C id=9 [slave keyboard (3)]
↳ Ideapad extra buttons id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
What’s the version of kernel you currently running? Have you tried other kernels?
I am currently running 5.12.9-1
And yes I have tried other versions, but it still didn’t work.
Output of inxi -Fazy please.
What kernels have you tried so far?
Output of journalctl --no-pager --no-hostname -b -p 3 after suspend and wake please.
inxi _Fazy
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=ecf2b4ea-9114-4fb3-94b3-5c2fadce967e rw quiet splash i8042.nopnp
apparmor=1 security=apparmor
resume=UUID=a320a7b5-31ce-4462-8ede-f5f87ae81dc4 udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 82C5 v: Lenovo V15-IIL serial: <filter>
Chassis: type: 10 v: Lenovo V15-IIL serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <filter>
UEFI: LENOVO v: DKCN49WW date: 10/26/2020
ID-1: BAT0 charge: 28.8 Wh (98.3%) condition: 29.3/30.0 Wh (97.8%)
volts: 8.6 min: 7.5 model: SMP L16M2PB1 type: Li-poly serial: <filter>
status: Charging cycles: 196
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A0 cache:
L2: 6 MiB
bogomips: 19048
Speed: 1300 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 1300 2: 1300
3: 1296 4: 1301 5: 1300 6: 1301 7: 1300 8: 1297
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 04f2:b624 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,intel,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 4000
bus-ID: 01:00.0 chip-ID: 10ec:c82f class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 0bda:c02f class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 49.97 GiB (21.0%)
model: PC SN530 SDBPMPZ-256G-1101 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 21160001 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 49.97 GiB (22.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 271 Uptime: 1m wakeups: 1 Memory: 7.57 GiB used: 2.62 GiB (34.6%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1398
pacman: 1392 lib: 324 flatpak: 0 snap: 6 Shell: Zsh v: 5.8 running-in: guake
inxi: 3.3.04
Jun 30 10:09:34 kernel: x86/cpu: SGX disabled by BIOS
Jun 30 10:09:34 systemd[1]: Failed to start Setup Virtual Console.
Jun 30 10:09:34 systemd-vconsole-setup[247]: /usr/bin/loadkeys failed with exit status 1.
Jun 30 10:09:34 kernel: platform idma64.0: failed to claim resource 0: [mem 0x00000800-0x00000fff]
Jun 30 10:09:40 kernel: irq 9: nobody cared (try booting with the "irqpoll" option)
Jun 30 10:09:40 kernel: handlers:
Jun 30 10:09:40 kernel: [<000000004d18a57b>] acpi_irq
Jun 30 10:09:40 kernel: Disabling IRQ #9
Jun 30 10:09:40 bluetoothd[717]: Failed to set mode: Blocked through rfkill (0x12)
Jun 30 10:09:44 gdm-password][1198]: gkr-pam: unable to locate daemon control file
Jun 30 10:09:47 systemd[1208]: Failed to start Application launched by gnome-session-binary.
Jun 30 10:13:01 bluetoothd[717]: Failed to set mode: Blocked through rfkill (0x12)
I have used the 5.10, 5.11 kernels and 4.14 as well just to check if it worked.
