Manjaro KDE is running really well on my Lenovo Thinkpad laptop.
I’d like to clean up efibbotmgr, it is full of “garbage entries”. My question is where all this “garbage” is coming from.
I understand, efibootmgr gets its information handed over in the “efi boot chain” from the maninboard bios.
With that as a given, I speculate the Lenovo Bios, at least firmware 1.48, must have an GUI invisible memory section that equals GUI visible Bios boot order menu plus all other entries in life of the laptop that were deleted and so no longer GUI visible.
Is that speculation true?
If so, how can I clean out that memory?
annex:
efibootmgr
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 0002,001C,0000,0001,0017,0018,0019,001A,001B,001D,001E,001F,0024
Boot0000* Windows Boot Manager HD(1,MBR,0x0,0x723e14,0x2000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d0000003a2f0100000010000000040000007fff0400
Boot0001 ubuntu HD(1,GPT,b1fddb88-61c6-4f64-90b3-e92eda96f79d,0x800,0x82000)/File(\EFI\ubuntu\shimx64.efi)
Boot0002* manjaro HD(1,GPT,3ecc1a7d-3af6-2a40-8457-3985d680a570,0x1000,0x96000)/File(\EFI\manjaro\grubx64.efi)
Boot0010 Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot0011 Boot Menu FvFile(126a762d-5758-4fca-8531-201a7f57f850)
Boot0012 Diagnostic Splash Screen FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0013 Lenovo Diagnostics FvFile(3f7e615b-0d45-4f80-88dc-26b234958560)
Boot0014 Startup Interrupt Menu FvFile(f46ee6f4-4785-43a3-923d-7f786c3c8479)
Boot0015 Rescue and Recovery FvFile(665d3f60-ad3e-4cad-8e26-db46eee9f1b5)
Boot0016 MEBx Hot Key FvFile(ac6fd56a-3d41-4efd-a1b9-870293811a28)
Boot0017* USB CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot0018* USB FDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot0019* NVMe1 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a401)
Boot001A* NVMe0 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a400)
Boot001B* ATA HDD0 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f602)
Boot001C* USB HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,33e821aaaf33bc4789bd419f88c50803)
Boot001D PCI LAN VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
Boot001E Other CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a35406)
Boot001F Other HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f606)
Boot0020* USBR BOOT CDROM PciRoot(0x0)/Pci(0x14,0x0)/USB(11,1)
Boot0021* USBR BOOT Floppy PciRoot(0x0)/Pci(0x14,0x0)/USB(11,0)
Boot0022* ATA HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f6)
Boot0023* ATAPI CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
Boot0024* PCI LAN VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
nvme0n1
├─nvme0n1p1 vfat FAT32 E44A-39F9 298,9M 0% /boot/efi
└─nvme0n1p2 crypto_LUKS 1 d74b9c8d-9bb0-4945-80a2-b917d8143295
└─luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 ext4 1.0 6c159802-2769-4409-a0cb-434bed39f4e6 424,3G 49% /
sudo parted -l
Model: WD_BLACK SN770 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=6c159802-2769-4409-a0cb-434bed39f4e6 rw quiet
cryptdevice=UUID=d74b9c8d-9bb0-4945-80a2-b917d8143295:luks-d74b9c8d-9bb0-4945-80a2-b917d8143295
root=/dev/mapper/luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20L6S29E02 v: ThinkPad T480
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20L6S29E02 v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: N24ET71W (1.46 ) date: 09/29/2022
ID-1: BAT0 charge: 4.3 Wh (48.9%) condition: 8.8/23.9 Wh (37.0%) power: 6.7 W
volts: 11.1 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
status: discharging cycles: 457
ID-2: BAT1 charge: 0.8 Wh (5.6%) condition: 14.3/23.9 Wh (59.9%)
volts: 11.2 min: 11.4 model: LGC 01AV490 type: Li-poly serial: <filter>
status: not charging cycles: 554
System RAM: total: 24 GiB available: 23.23 GiB used: 3.27 GiB (14.1%)
igpu: 32 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1.2 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A1K43CB1-CRC
serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 2400 MT/s volts: curr: 1.2 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43CB1-CTD
serial: <filter>
Info: model: Intel Core i5-8350U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 699 high: 800 min/max: 400/3600 base/boost: 1700/1900
scaling: driver: intel_pstate governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 400 7: 798
8: 400 bogomips: 30409
sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b613
class-ID: 0e02
Device-3: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x103d built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
device-ID: 8086:5917 memory: 22.68 GiB unified: yes
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 620 (KBL GT2) driver: mesa intel
v: 23.1.9-manjaro1.1 device-ID: 8086:5917 surfaces: xcb,xlib
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: pipewire-media-session status: active
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
tools: pactl,pw-cat,pw-cli
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-1: luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 444.61 GiB (47.7%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731030WD temp: 27.9 C scheme: GPT
SMART: yes health: PASSED on: 5d 6h cycles: 1,528
read-units: 8,151,255 [4.17 TB] written-units: 3,456,725 [1.76 TB]
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
used: 444.61 GiB (48.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 label: N/A
uuid: 6c159802-2769-4409-a0cb-434bed39f4e6
used: 460 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: E44A-39F9
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-5:3 info: Chicony Integrated IR Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b613 class-ID: 0e02
Device-3: 1-8:5 info: Chicony Integrated Camera (1280x720@30) type: video
mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-4: 1-9:14 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Device-5: 1-10:7 info: Raydium Touch System type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
chip-ID: 2386:432f class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Device-1: 2-3:2 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 40.0 C pch: 35.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Processes: 233 Uptime: 7h 47m wakeups: 7 Init: systemd v: 254
Packages: pm: pacman pkgs: 1398 libs: 390 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Sudo (sudo) v: 1.9.15p4 default: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
