I realise this is more of a generic Linux question & not directly Manjaro, but Im hoping you can help regardless as it’s so hard to find good advice. I will be using Manjaro to complete this task.
I recently replaced Ubuntu with Nitrux on a 2nd partition. Now when I enter the UEFI bootmanager screen (F12) I can still see Ubuntu as well as Manjaro & Nitrux.
I removed this entry using sudo efibootmgr -b 0003 -B & it was apparently successful. However, after a reboot this entry was back again.
How should I get the removal to persist?
efibootmgr -v ✔
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,0005,0003,2001,2002,2003
Boot0000* manjaro HD(1,GPT,b81116c0-132d-4850-aa2a-0aa263bea0df,0x800,0x100000)/File(\EFI\manjaro\grubx64.efi)
Boot0001* EFI PXE 0 for IPv4 (7C-8A-E1-80-E5-AB) PciRoot(0x0)/Pci(0x2,0x3)/Pci(0x0,0x0)/MAC(7c8ae180e5ab,0)/IPv4(0.0.0.00.0.0.0,0,0)RC
Boot0002* EFI PXE 0 for IPv6 (7C-8A-E1-80-E5-AB) PciRoot(0x0)/Pci(0x2,0x3)/Pci(0x0,0x0)/MAC(7c8ae180e5ab,0)/IPv6([::]:<->[::]:,0,0)RC
Boot0003* ubuntu HD(1,GPT,b81116c0-132d-4850-aa2a-0aa263bea0df,0x800,0x100000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot0005* Nitrux HD(1,GPT,b81116c0-132d-4850-aa2a-0aa263bea0df,0x800,0x100000)/File(\EFI\Nitrux\shimx64.efi)
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
Solution: In Manjaro /boot/efi/EFI there are multiple folders for OS’s. I deleted the ones no longer needed (nitrux, ubuntu) & the UEFI menu is now correct.
