EFI signing process tries to sign non existing kernels
Hello,
I replaced GRUB with systemd-boot ([How To] Convert to systemd-boot) a while ago and I noticed a few days ago when trying to run an update with pacman -Syu that when the EFI signing process starts, that the process tries to sign kernels that are no longer available.
(23/23) Signing EFI binaries...
Generating EFI bundles....
failed signing /lib/modules/6.10.0-3-MANJARO/vmlinuz: /lib/modules/6.10.0-3-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.6.32-1-MANJARO/vmlinuz: /lib/modules/6.6.32-1-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.8.12-3-MANJARO/vmlinuz: /lib/modules/6.8.12-3-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.9.5-1-MANJARO/vmlinuz: /lib/modules/6.9.5-1-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.10.0-3-MANJARO/vmlinuz: /usr/lib/modules/6.10.0-3-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.8.11-1-MANJARO/vmlinuz: /usr/lib/modules/6.8.11-1-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.8.12-3-MANJARO/vmlinuz: /usr/lib/modules/6.8.12-3-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.9.2-1-MANJARO/vmlinuz: /usr/lib/modules/6.9.2-1-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.9.3-3-MANJARO/vmlinuz: /usr/lib/modules/6.9.3-3-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.9.5-1-MANJARO/vmlinuz: /usr/lib/modules/6.9.5-1-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.10.0-1-MANJARO/vmlinuz: /lib/modules/6.10.0-1-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.8.11-1-MANJARO/vmlinuz: /lib/modules/6.8.11-1-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.10.0-1-MANJARO/vmlinuz: /usr/lib/modules/6.10.0-1-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.6.32-1-MANJARO/vmlinuz: /usr/lib/modules/6.6.32-1-MANJARO/vmlinuz does not exist
File has already been signed /efi/EFI/BOOT/BOOTX64.EFI
File has already been signed /efi/EFI/systemd/systemd-bootx64.efi
failed signing /lib/modules/6.9.2-1-MANJARO/vmlinuz: /lib/modules/6.9.2-1-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.9.3-3-MANJARO/vmlinuz: /lib/modules/6.9.3-3-MANJARO/vmlinuz does not exist
failed signing /lib/modules/6.9.9-1-MANJARO/vmlinuz: /lib/modules/6.9.9-1-MANJARO/vmlinuz does not exist
failed signing /usr/lib/modules/6.9.9-1-MANJARO/vmlinuz: /usr/lib/modules/6.9.9-1-MANJARO/vmlinuz does not exist
error: command failed to execute correctly
Before that I always updated packages via pamac-manager so I missed those errors because of that.
The kernels were installed and removed via manjaro-settings-manager. Might the errors originate in using manjaro-settings-manager instead of kernel-install remove or could this not be related to the errors?
kernel-install list gives me the following output:
VERSION           HAS KERNEL PATH
6.12.64-1-MANJARO          ✓ /usr/lib/modules/6.12.64-1-MANJARO
6.18.4-1-MANJARO           ✓ /usr/lib/modules/6.18.4-1-MANJARO
A few days I think 6.10 was still in the list but I failed to remove it with kernel-install remove. But now it seems that it’s gone. 6.6.32-1 or 6.9.5-1 where never in the list that day but still showed in the log.
My system seems to run fine even with those errors but I still wonder if I should switch to kernel install remove in the future for removing kernels or use it in addition to manjaro-settings-manager and if there are some unused resources left that I could remove.
I hope someone can help.
You can also use mhwd-kernel to manage the kernels.
If i remember correctly, at some point there was some bug and the /usr/lib/modules/ folders of the uninstalled kernels were left behind. So just delete those (for the uninstalled kernels).
The bug was with the pacman hook that copied the modules to not needing a reboot after a kernel update.
I forgot to mention, that I already deleted an old module in that folder. I think it was 6.10.. /lib/modules/ and /usr/lib/modules/ does only contain the currently installed kernels: 6.12 and 6.18. So I wonder why the process tries to do something with kernels or modules that do not exists any longer.
Well it seems to find remnants of those kernels somewhere. You can also check the mkinitcpio presets and the /boot for remnants. Or do a search for the deleted kernel numbers. Otherwise, no idea.
I used sudo grep -rlnIFi -f missing-kernels.txt --exclude-dir={proc,sys} / to search for the missing kernels and found /var/lib/sbctl/files.json
    "/efi/EFI/BOOT/BOOTX64.EFI": {
        "file": "/efi/EFI/BOOT/BOOTX64.EFI",
        "output_file": "/efi/EFI/BOOT/BOOTX64.EFI"
    "/efi/EFI/systemd/systemd-bootx64.efi": {
        "file": "/efi/EFI/systemd/systemd-bootx64.efi",
        "output_file": "/efi/EFI/systemd/systemd-bootx64.efi"
    "/lib/modules/6.10.0-1-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.10.0-1-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.10.0-1-MANJARO/vmlinuz"
    "/lib/modules/6.10.0-3-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.10.0-3-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.10.0-3-MANJARO/vmlinuz"
    "/lib/modules/6.6.32-1-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.6.32-1-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.6.32-1-MANJARO/vmlinuz"
    "/lib/modules/6.8.11-1-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.8.11-1-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.8.11-1-MANJARO/vmlinuz"
    "/lib/modules/6.8.12-3-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.8.12-3-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.8.12-3-MANJARO/vmlinuz"
    "/lib/modules/6.9.2-1-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.9.2-1-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.9.2-1-MANJARO/vmlinuz"
    "/lib/modules/6.9.3-3-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.9.3-3-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.9.3-3-MANJARO/vmlinuz"
    "/lib/modules/6.9.5-1-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.9.5-1-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.9.5-1-MANJARO/vmlinuz"
    "/lib/modules/6.9.9-1-MANJARO/vmlinuz": {
        "file": "/lib/modules/6.9.9-1-MANJARO/vmlinuz",
        "output_file": "/lib/modules/6.9.9-1-MANJARO/vmlinuz"
    "/usr/lib/modules/6.10.0-1-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.10.0-1-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.10.0-1-MANJARO/vmlinuz"
    "/usr/lib/modules/6.10.0-3-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.10.0-3-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.10.0-3-MANJARO/vmlinuz"
    "/usr/lib/modules/6.6.32-1-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.6.32-1-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.6.32-1-MANJARO/vmlinuz"
    "/usr/lib/modules/6.8.11-1-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.8.11-1-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.8.11-1-MANJARO/vmlinuz"
    "/usr/lib/modules/6.8.12-3-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.8.12-3-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.8.12-3-MANJARO/vmlinuz"
    "/usr/lib/modules/6.9.2-1-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.9.2-1-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.9.2-1-MANJARO/vmlinuz"
    "/usr/lib/modules/6.9.3-3-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.9.3-3-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.9.3-3-MANJARO/vmlinuz"
    "/usr/lib/modules/6.9.5-1-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.9.5-1-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.9.5-1-MANJARO/vmlinuz"
    "/usr/lib/modules/6.9.9-1-MANJARO/vmlinuz": {
        "file": "/usr/lib/modules/6.9.9-1-MANJARO/vmlinuz",
        "output_file": "/usr/lib/modules/6.9.9-1-MANJARO/vmlinuz"
This explains the usage of the file:
files_db: /path/to/files/json
The location of the json file storing the files sbctl will sign.
Default: /var/lib/sbctl/files.json
(sbctl.conf(5) — Arch manual pages)
Not sure where it is used. Maybe someone like @linux-aarhus knows more. But I guess that I could remove the parts with /lib/modules/... and leave the /efi/...-parts. Interestingly the current kernels are not listed there. Maybe I missed some notice while updating due to the usage of pamac-manager explaining this issue I’m having. I also found this:
The sbctl install hook automatically signs the following boot components when using kernel-install (see Installkernel).
Use sbctl sign -s instead of sbctl sign to automatically save files to be signed to /var/lib/sbctl/files.json. (sbctl - Gentoo Wiki).
Maybe somewhere sbctl sign is used without the -s option and so files.json is not updated. Or maybe it is not used anylonger. :person_shrugging:
I removed the old kernels from files.jsonand now the errors are gone as expected. Thank you for your support.
