Being unable to boot anymore to my system I use a manjaro live disk.
After manjaro-chroot -a I try install-grub but I get EFI directory not found! Grub couldn't be installed.
[manjaro /]# inxi -zv8
12System:
12Kernel 6.6.7-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1 12clocksource tsc
12avail hpet,acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
lang=en_US keytable=fr tz=UTC lang=fr_FR keytable=fr tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2310 quiet systemd.show_status=1 splash driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1 rdinit=/vtoy/vtoy
12Desktop KDE Plasma 12v 5 12tk Qt 12v N/A 12vt 2 12dm N/A 12Distro Manjaro 12base Arch Linux
12Machine:
12Type Laptop 12System HP 12product HP ProBook 450 G3 12v N/A 12serial <filter> 12Chassis 12type 10
12serial <filter>
12Mobo HP 12model 8101 12v KBC Version 40.73 12serial <filter> 12part-nu T6P76EA#ABF
12uuid 1e0a58f0-da48-11e5-a037-1d58730180fd 12UEFI HP 12v N78 Ver. 01.61 12date 10/03/2023
12Battery:
12ID-1 BAT0 12charge 26.5 Wh (79.1%) 12condition 33.5/44.4 Wh (75.5%) 12volts 15.3 12min 14.8
12model Hewlett-Packard Primary 12type Li-ion 12serial <filter> 12status not charging 12cycles 54
12Memory:
12System RAM 12total 8 GiB 12available 7.65 GiB 12used 2.89 GiB (37.7%) 12igpu 32 MiB
12Array-1 12capacity 16 GiB 12slots 2 12modules 1 12EC None 12max-module-size 8 GiB 12note est.
12Device-1 Bottom-Slot 2(under) 12type DDR3 12detail synchronous unbuffered (unregistered) 12size 8 GiB
12speed 1600 MT/s 12volts 12curr 1.35 12width (bits) 12data 64 12total 64 12manufacturer Samsung
12part-no M471B1G73EB0-YK0 12serial <filter>
12Device-2 Bottom-Slot 1(top) 12type no module installed
12PCI Slots:
12Slot 1 12type PCI 12bits 32 12status available 12length long 12volts 3.3 12bus-ID 00:00.0
12CPU:
12Info 12model Intel Core i5-6200U 12socket U3E1 12bits 64 12type MT MCP 12arch Skylake 12gen core 6 12level v3
12note check 12built 2015 12process Intel 14nm 12family 6 12model-id 0x4E (78) 12stepping 3 12microcode 0xF0
12Topology 12cpus 1x 12cores 2 12tpc 2 12threads 4 12smt enabled 12cache 12L1 128 KiB
12desc d-2x32 KiB; i-2x32 KiB 12L2 512 KiB 12desc 2x256 KiB 12L3 3 MiB 12desc 1x3 MiB
12Speed (MHz) 12avg 600 12min/max 400/2800 12base/boost 2700/8300 12scaling 12driver intel_pstate
12governor powersave 12volts 0.9 V 12ext-clock 100 MHz 12cores 121 600 122 600 123 600 124 600 12bogomips 19204
12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
12Vulnerabilities
12Type gather_data_sampling 12status Vulnerable: No microcode
12Type itlb_multihit 12status KVM: VMX disabled
12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
12Type meltdown 12mitigation PTI
12Type mmio_stale_data 12mitigation Clear CPU buffers; SMT vulnerable
12Type retbleed 12mitigation IBRS
12Type spec_rstack_overflow 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation IBRS, IBPB: conditional, STIBP: conditional, RSB filling,
PBRSB-eIBRS: Not affected
12Type srbds 12mitigation Microcode
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel Skylake GT2 [HD Graphics 520] 12vendor Hewlett-Packard 12driver i915 12v kernel
12arch Gen-9 12process Intel 14n 12built 2015-16 12ports 12active eDP-1 12empty DP-1,HDMI-A-1,HDMI-A-2
12bus-ID 00:02.0 12chip-ID 8086:1916 12class-ID 0300
12Device-2 AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535 620/625 Mobile]
12vendor Hewlett-Packard 12driver amdgpu 12v kernel 12arch GCN-3 12code Volcanic Islands 12process TSMC 28nm
12built 2014-19 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 4 12link-max 12gen 3 12speed 8 GT/s 12lanes 8
12bus-ID 01:00.0 12chip-ID 1002:6900 12class-ID 0380 12temp 40.0 C
12Device-3 Cheng Uei Precision Industry (Foxlink) HP HD Camera 12driver uvcvideo 12type USB 12rev 2.0
12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-6:4 12chip-ID 05c8:0383 12class-ID 0e02
12Display x11 12server X.org 12v 1.21.1.13 12with Xwayland 12v 23.2.6 12driver 12X 12loaded intel 12dri i965
12gpu i915 12display-ID :0
12Monitor-1 eDP-1 12model AU Optronics 0x36ed 12built 2014 12res 1920x1080 12dpi 142 12gamma 1.2 12chroma 12red
12x 0.580 12y 0.333 12green 12x 0.329 12y 0.565 12blue 12x 0.153 12y 0.137 12white 12x 0.314 12y 0.329
12size 344x193mm (13.54x7.6") 12diag 394mm (15.5") 12ratio 16:9 12modes 1920x1080
12EDID-Warnings 121 parse_edid: unknown flag 2
12API EGL 12v 1.5 12hw 12drv intel iris 12drv amd radeonsi 12platforms 12device 0 12drv iris 12device 1
12drv radeonsi 12device 2 12drv swrast 12gbm 12drv radeonsi 12surfaceless 12drv iris 12inactive wayland,x11
12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 24.0.6-manjaro1.1 12note incomplete (EGL sourced)
12renderer AMD Radeon R7 M340 (radeonsi iceland LLVM 17.0.6 DRM 3.54 6.6.7-1-MANJARO), Mesa Intel
HD Graphics 520 (SKL GT2), llvmpipe (LLVM 17.0.6 256 bits)
12API Vulkan 12Message No Vulkan data available.
12Audio:
12Device-1 Intel Sunrise Point-LP HD Audio 12vendor Hewlett-Packard 12driver snd_hda_intel 12v kernel
12bus-ID 00:1f.3 12chip-ID 8086:9d70 12class-ID 0403
12API ALSA 12v k6.6.7-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 sndiod 12v N/A 12status off 12tools aucat,midicat,sndioctl
12Server-2 JACK 12v 1.9.22 12status off 12tools N/A
12Server-3 PipeWire 12v 1.0.5 12status off 12with pipewire-media-session 12status off 12tools pw-cli
12Server-4 PulseAudio 12v 17.0 12status off 12with pulseaudio-jack 12type module 12tools pacat,pactl
12Network:
12Device-1 Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet 12vendor Hewlett-Packard
12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port 4000 12bus-ID 02:00.0
12chip-ID 10ec:8168 12class-ID 0200
12IF enp2s0 12state down 12mac <filter>
12Device-2 Intel Wireless 3165 12driver iwlwifi 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1
12bus-ID 03:00.0 12chip-ID 8086:3165 12class-ID 0280
12IF wlp3s0 12state up 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type dynamic noprefixroute 12scope global
12IP v6 <filter> 12type noprefixroute 12scope link
12Info 12services No services found.
12WAN IP No WAN IP found. Connected to web? SSL issues? Try enabling dig
12Bluetooth:
12Device-1 Intel Bluetooth wireless interface 12driver btusb 12v 0.8 12type USB 12rev 2.0 12speed 12 Mb/s
12lanes 1 12mode 1.1 12bus-ID 1-7:5 12chip-ID 8087:0a2a 12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 0 12state down 12bt-service N/A 12rfk-block 12hardware no 12software no
12address see --recommends
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 938.97 GiB 12used 275.1 GiB (29.3%)
12ID-1 /dev/sda 12maj-min 8:0 12vendor Samsung 12model ST1000LM024 HN-M101MBB 12family Seagate SpinPoint
M8 (AF) 12size 931.51 GiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.1 12speed 6.0 Gb/s
12tech HDD 12rpm 5400 12serial <filter> 12fw-rev 0001 12temp 33 C
12SMART yes 12state enabled 12health PASSED 12on 6y 53d 1h 12cycles 2143 12Old-Age 12g-sense error rate 162
12ID-2 /dev/sdb 12maj-min 8:16 12vendor Patriot 12model N/A 12size 7.46 GiB 12block-size 12physical 512 B
12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech N/A 12serial <filter> 12fw-rev PMAP
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Optical-1 /dev/sr0 12vendor hp 12model DVDRW GUD1N 12rev MD00 12dev-links cdrom
12Features 12speed 24 12multisession yes 12audio yes 12dvd yes 12rw cd-r,cd-rw,dvd-r,dvd-ram 12state running
12Partition:
12ID-1 / 12raw-size 60 GiB 12size 58.76 GiB (97.93%) 12used 31.6 GiB (53.8%) 12fs ext4 12block-size 4096 B
12dev /dev/sda3 12maj-min 8:3 12label N/A 12uuid 2067097a-1b2e-4759-8bf3-1b5398b38c34
12ID-2 /boot/efi 12raw-size 360 MiB 12size 356 MiB (98.89%) 12used 90.7 MiB (25.5%) 12fs vfat
12block-size 512 B 12dev /dev/sda1 12maj-min 8:1 12label SYSTEM 12uuid 801A-497E
12ID-3 /home 12raw-size 300 GiB 12size 295.11 GiB (98.37%) 12used 243.41 GiB (82.5%) 12fs ext4
12block-size 4096 B 12dev /dev/sda4 12maj-min 8:4 12label N/A 12uuid 10c56cef-455e-42ed-bc0a-f941db9826bb
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/dm-0 12maj-min 254:0 12mapped ventoy 12size 3.64 GiB 12fs N/A 12label MANJARO_KDE_2310
12uuid 2023-12-15-02-06-08-00
12ID-2 /dev/sda10 12maj-min 8:10 12size 2 GiB 12fs fat (32 bit) 12label HP_TOOLS 12uuid A08C-74BD
12ID-3 /dev/sda11 12maj-min 8:11 12size 20 GiB 12fs swap 12label N/A
12uuid 7ace45ae-fcbc-441c-b23d-80105d4fa4f8
12ID-4 /dev/sda2 12maj-min 8:2 12size 128 MiB 12fs N/A 12label N/A 12uuid N/A
12ID-5 /dev/sda5 12maj-min 8:5 12size 93.41 GiB 12fs ntfs 12label Windows 12uuid 341439A814396DCC
12ID-6 /dev/sda6 12maj-min 8:6 12size 319.39 GiB 12fs ext4 12label N/A
12uuid 455639ff-2551-4f69-905c-4901a3113d11
12ID-7 /dev/sda8 12maj-min 8:8 12size 950 MiB 12fs ntfs 12label Windows RE tools 12uuid B46AE48C6AE44CA4
12ID-8 /dev/sda9 12maj-min 8:9 12size 15.58 GiB 12fs ntfs 12label Recovery Image 12uuid 1AEC8261EC8236D3
12ID-9 /dev/sdb1 12maj-min 8:17 12size 7.43 GiB 12fs N/A 12label Ventoy 12uuid 19C1-1283
12ID-10 /dev/sdb2 12maj-min 8:18 12size 32 MiB 12fs N/A 12label VTOYEFI 12uuid B2C8-40D2
12USB:
12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 12 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Device-1 1-4:2 12info Phison flash drive (4GB EMTEC) 12type mass storage 12driver usb-storage
12interfaces 1 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 200mA 12chip-ID 13fe:3600
12class-ID 0806 12serial <filter>
12Device-2 1-5:3 12info Elan Micro 2.4G RX 12type keyboard 12driver hid-generic,usbhid 12interfaces 1
12rev 1.1 12speed 1.5 Mb/s (183 KiB/s) 12lanes 1 12mode 1.0 12power 100mA 12chip-ID 04f3:00a4 12class-ID 0301
12Device-3 1-6:4 12info Cheng Uei Precision Industry (Foxlink) HP HD Camera 12type video
12driver uvcvideo 12interfaces 2 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 500mA
12Device-4 1-7:5 12info Intel Bluetooth wireless interface 12type bluetooth 12driver btusb 12interfaces 2
12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA 12chip-ID 8087:0a2a 12class-ID e001
12Device-5 1-8:6 12info Validity Sensors VFS495 Fingerprint Reader 12type <vendor specific>
12driver N/A 12interfaces 1 12rev 1.1 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA
12chip-ID 138a:003f 12class-ID ff00 12serial <filter>
12Hub-2 2-0:1 12info super-speed hub 12ports 6 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1
12mode 3.2 gen-1x1 12chip-ID 1d6b:0003 12class-ID 0900
12Sensors:
12System Temperatures 12cpu 42.0 C 12pch 41.5 C 12mobo N/A 12gpu amdgpu 12temp 41.0 C
12Fan Speeds (rpm) N/A
12Repos:
12Packages 12pm nix-default 12pkgs 0 12pm nix-sys 12pkgs 0 12pm nix-usr 12pkgs 0 12pm pacman 12pkgs 2159 12libs 391
12tools octopi,pacaur,trizen,yay
12Active pacman repo servers in /etc/pacman.d/mirrorlist
121 https: //mirror.init7.net/manjaro/stable/$repo/$arch
122 https: //mirror.netcologne.de/manjaro/stable/$repo/$arch
123 http: //ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
124 https: //mirrors2.manjaro.org/stable/$repo/$arch
125 https: //nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
126 https: //manjaro.mirror.wearetriple.com/stable/$repo/$arch
127 https: //ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
128 https: //ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
129 http: //mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
1210 https: //ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
1211 https: //mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
1212 https: //volico.mm.fcix.net/manjaro/stable/$repo/$arch
1213 https: //mirrors.netix.net/manjaro/stable/$repo/$arch
1214 https: //southfront.mm.fcix.net/manjaro/stable/$repo/$arch
1215 https: //nocix.mm.fcix.net/manjaro/stable/$repo/$arch
1216 https: //mirror.telepoint.bg/manjaro/stable/$repo/$arch
1217 https: //opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
1218 https: //mirrors.ft.uam.es/manjaro/stable/$repo/$arch
1219 https: //ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
1220 https: //edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
1221 https: //coresite.mm.fcix.net/manjaro/stable/$repo/$arch
1222 https: //mirror.erickochen.nl/manjaro/stable/$repo/$arch
1223 https: //mirrors.cicku.me/manjaro/stable/$repo/$arch
1224 https: //mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
1225 https: //mirror.kamtv.ru/manjaro/stable/$repo/$arch
1226 https: //gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
1227 https: //mirrors.manjaro.org/repo/stable/$repo/$arch
1228 https: //repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
1229 http: //free.nchc.org.tw/manjaro/stable/$repo/$arch
1230 http: //manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
1231 https: //manjaro.mirrors.lavatech.top/stable/$repo/$arch
1232 https: //mirror.futureweb.be/manjaro/stable/$repo/$arch
1233 https: //mirror.vinehost.net/manjaro/stable/$repo/$arch
1234 https: //manjaro.c3sl.ufpr.br/stable/$repo/$arch
1235 https: //mirror.truenetwork.ru/manjaro/stable/$repo/$arch
1236 https: //www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
1237 https: //mirror.koddos.net/manjaro/stable/$repo/$arch
1238 https: //repos.silknet.com/manjaro/stable/$repo/$arch
1239 https: //mirror.bouwhuis.network/manjaro/stable/$repo/$arch
1240 http: //kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
1241 https: //mirror.zetup.net/manjaro/stable/$repo/$arch
1242 https: //mirror.easyname.at/manjaro/stable/$repo/$arch
1243 https: //ask4.mm.fcix.net/manjaro/stable/$repo/$arch
1244 https: //forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
1245 https: //ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
1246 http: //mirror.xeonbd.com/manjaro/stable/$repo/$arch
1247 https: //mirror.albony.xyz/manjaro/stable/$repo/$arch
1248 https: //mirrors.atlas.net.co/manjaro/stable/$repo/$arch
1249 https: //mirrors.dotsrc.org/manjaro/stable/$repo/$arch
1250 https: //mirrors.gigenet.com/manjaro/stable/$repo/$arch
1251 https: //mirror.xenyth.net/manjaro/stable/$repo/$arch
1252 https: //irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
1253 https: //fastmirror.pp.ua/manjaro/stable/$repo/$arch
1254 https: //mirror.23m.com/manjaro/stable/$repo/$arch
1255 http: //manjaro.grena.ge/stable/$repo/$arch
1256 https: //quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
1257 https: //manjaro.kurdy.org/stable/$repo/$arch
1258 https: //manjaro.ynh.ovh/stable/$repo/$arch
1259 https: //uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
1260 https: //mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
1261 https: //muug.ca/mirror/manjaro/stable/$repo/$arch
1262 https: //mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
1263 https: //mirrors.up.pt/pub/manjaro/stable/$repo/$arch
1264 https: //mirror.freedif.org/Manjaro/stable/$repo/$arch
1265 https: //mirror.funami.tech/manjaro/stable/$repo/$arch
1266 http: //ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
1267 http: //mirror.fcix.net/manjaro/stable/$repo/$arch
1268 https: //ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
1269 https: //mirror.ufam.edu.br/manjaro/stable/$repo/$arch
1270 https: //mirror.alpix.eu/manjaro/stable/$repo/$arch
1271 https: //manjaro.repo.cure.edu.uy/stable/$repo/$arch
1272 http: //ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
1273 https: //codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
1274 https: //mirror.2degrees.nz/manjaro/stable/$repo/$arch
1275 https: //mirror.ufro.cl/manjaro/stable/$repo/$arch
1276 http: //manjaro.mirrors.uk2.net/stable/$repo/$arch
1277 https: //mirror.kku.ac.th/manjaro/stable/$repo/$arch
1278 https: //mirror.dkm.cz/manjaro/stable/$repo/$arch
1279 https: //mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
1280 https: //ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
1281 https: //mirror.archlinux.tw/Manjaro/stable/$repo/$arch
1282 http: //ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
1283 http: //mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
1284 https: //mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
12No nix channels found for user manjaro
12Processes:
12Message No process data available.
12Info:
12Processes 0 12Power 12uptime 43m 12states freeze,mem,disk 12suspend deep 12avail s2idle 12wakeups 0
12hibernate platform 12avail shutdown, reboot, suspend, test_resume 12image 3.04 GiB 12Init systemd 12v 255
12default graphical 12tool systemctl
12Compilers 12clang 17.0.6 12gcc 13.2.1 12Client systemd 12inxi 3.3.34
