I put my /home folder as an icon (Wirget) on the desktop. Is there any way to change the icon name?
If it’s a .desktop file, then you can right-click the icon and give it a different name there.
No, i’s a Widget / Plasmoid.
Well, does it not have any configuration options? (You may have to unlock the widgets first.)
Despite the “View and edit possible” permission, only the file type details and the path appear.
Then I’m afraid there’s no way to change its name.
Ok, thx
