is it possible to change a theme color in plasma style? currently i’m using the kde-simple theme the base color is # 31363b and I would like to have # 3b3b3b
System Setting/Colors Choose your color scheme that you want to start with, hover on it, there will be an edit button, click it.
Yes I know about the main theme but it doesn’t change the menu color (plasma style) and this is the menu of applications that I want to modify.
You’re looking to change just one color of a theme and not switch color themes is that correct? Here’s a link to the Plasma Theme Tutorial that’ll help walk you through that.
@MissionFailure yes that’s what I was looking for. thanks to you
