New here and fairly beginner when it comes to Linux. Please bare with me. In order to introduce Noise cancellation to my mic I inserted load-module module-echo-cancel aec_method=webrtc aec_args=“analog_gain_control=0\ digital_gain_control=0” into default.pa located in /etc/pulse and it seemed to do the trick however my audio comes out as mono instead of stereo. Any ideas? If I insert channels=2 after the digital_gain_control=0 my mic shows 2 channels but output is still mono. I’m a bit lost unfortunately. Makes gaming and chatting a bit rough. To whoever took the time to read this thank you.
Thanks for replying! Its a headset mic and Ive managed to get it to work before with as stereo input so I know it can be done however I had to reinstall Manjaro when merging unallocated space went bad. I can’t reproduce my results.
IT WORKED!!! I love you! Its been two days of trying line on line and trying to piece things together. You made my day good Sir! I don’t know if you believe in a higher power or not, but God bless you!!!
