My earphones are not recognised sometimes. After I unplug and plug them in again, they work. Once recognised, they work perfectly without any issues. This happens randomly, sometimes they are recognised on the first try, sometimes not. I know that this is not a hardware problem since the earphones are always recognised on the first try on the same machine on Windows 10.
System: Manjaro 21.0.5 Ornara, Kernel: 5.12.2-1-MANJARO
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Fabby
7 June 2021 08:01
2
Do you mean at boot time or they disappear after a while?
Also, the full output of an inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command).
At boot time as well as when I plug in after login.
I’ve updated the system after I posted the original post.
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.12.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=34f56dbc-d37a-403b-b26a-0e6de7753689 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-bs1xx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 832A v: 23.70 serial: <filter> UEFI-[Legacy]: Insyde v: F.52
date: 03/04/2019
ID-1: BAT1 charge: 34.7 Wh (95.1%) condition: 36.5/32.1 Wh (113.5%)
volts: 16.3 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Unknown
RAM: total: 7.69 GiB used: 2.13 GiB (27.7%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 6 MiB bogomips: 28808
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-5:5 chip-ID: 1bcf:2c9b class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.12.8-1-MANJARO running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard
driver: rtw_8723de v: N/A modules: rtw88_8723de port: 3000 bus-ID: 02:00.0
chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-4:3 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 294.29 GiB (31.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
rotation: 5400 rpm serial: <filter> rev: 1C scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUE1N rev: UE00 dev-links: cdrom
ID-1: / raw-size: 276.84 GiB size: 271.5 GiB (98.07%)
used: 113.11 GiB (41.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 34f56dbc-d37a-403b-b26a-0e6de7753689
ID-2: /run/media/apoorv/Apoorv Drive raw-size: 279.17 GiB
size: 279.17 GiB (100.00%) used: 181.18 GiB (64.9%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: Apoorv Drive uuid: 8C5442D35442C026
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 579 MiB fs: ntfs label: System Reserved
uuid: 684633204632EF06
ID-2: /dev/sda2 maj-min: 8:2 size: 374.43 GiB fs: ntfs label: N/A
uuid: D4304A71304A5B1E
ID-3: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-4:3 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-3: 1-5:5 info: Sunplus Innovation HP TrueVision HD Camera type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: 29.8 C
Processes: 285 Uptime: 46m wakeups: 11 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1450 lib: 421 flatpak: 0
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
Fabby
10 June 2021 07:31
4
ApoorvPotnis:
Have you tried 5.10 LTS and 5.4 LTS already instead of 5.12 Stable?
I can’t see any headset in the inxi
output. What kind of earphone / headset / … are you using and where they plugged in at the time you performed the inxi
