DVD not working
Hi linux ppl hope your all running well, my issue ATM my dvd wont work. Further inspection its looks like its not in the kernel. I was wondering why if its gone. I have the latest manjaro mate on an i5 samsung laptop. I could live without it but I have lots of my kids pictures on cds. Maybe if anyone know of a portable dvd that would work let me know please. Thank yous.
inxi out put if it helps thanks again
  Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=3a6e263d-3e29-433e-afd3-8524fd688548 rw quiet splash apparmor=1
  Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
    v: 42.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: SAMSUNG product: 350V5C/351V5C/3540VC/3440VC
    v: P09ABE.012.CP serial: <superuser required> Chassis: type: 9 v: 0.1
  Mobo: SAMSUNG model: NP350V5C-A0EUK v: BOARD REVISION 00
    serial: <superuser required> UEFI: American Megatrends v: P09ABE
    date: 07/04/2013
  ID-1: BAT1 charge: 47.4 Wh (100.0%) condition: 47.4/48.8 Wh (97.1%)
    volts: 12.5 min: 11.1 model: COMPAL PABAS0241231 type: Li-ion
    serial: <filter> status: full cycles: 158
  RAM: total: 5.69 GiB used: 3.48 GiB (61.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58)
    stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2126 high: 2666 min/max: 1200/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2666 2: 1908 3: 2055
    4: 1878 bogomips: 19961
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
    xsave xsaveopt xtopology xtpr
    vulnerable
    prctl and seccomp
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
    driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0166 class-ID: 0300
  Device-2: Silicon Motion WebCam SC-13HDL11939N type: USB driver: uvcvideo
    bus-ID: 1-1.4:5 chip-ID: 2232:1029 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: LVDS-1 model: AU Optronics 0x21ec built: 2011 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1366x768
  OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 22.1.4
    direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
    vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter
    vendor: Samsung Co driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0032 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  IP v4: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy scope: link
  Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
    v: 0.8 bus-ID: 1-1.2:8 chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
  Local Storage: total: 1.59 TiB used: 272.79 GiB (16.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS547575A9E384
    size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: A50A scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital model: WD
    Elements 25A2 size: 931.48 GiB block-size: physical: 512 B logical: 512 B
    type: N/A serial: <filter> rev: 1021 scheme: MBR
  ID-1: / raw-size: 698.34 GiB size: 686.31 GiB (98.28%) used: 30.8 GiB (4.5%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 3a6e263d-3e29-433e-afd3-8524fd688548
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 3D24-DDD4
  ID-3: /run/media/manjaro/WD-HD raw-size: 931.48 GiB size: 931.48 GiB
    (100.00%) used: 241.99 GiB (26.0%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
    label: WD-HD uuid: 241C1D8514F81921
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-2: 1-1.2:8 info: Qualcomm Atheros AR3012 Bluetooth 4.0
    type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
  Device-3: 1-1.4:5 info: Silicon Motion WebCam SC-13HDL11939N type: Video
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:3 info: SteelSeries ApS Rival 110 Gaming Mouse
    type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 1038:1729 class-ID: 0301
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Device-1: 4-1:2 info: Western Digital Elements 25A2 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
    chip-ID: 1058:25a2 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 52.0 C mobo: N/A
  Processes: 242 Uptime: 6h 21m wakeups: 1 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
  Packages: pacman: 1313 lib: 351 flatpak: 0 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.20
Just curious, how old is the laptop? Secondly does the dvd work with other OS’s?
well for a possibly 9 year old DVD drive chances are its seen better days, laptop DVD drives are very finicky and so are those DVDs, the writable kind dont last that long if you dont backup often onto new discs.
if the recognition of the DVD is the issue, you can check if it works in windows?
Its old now I think I will look at a better at a better newer model, thank you for your help, oh it worked in windows and my fist try of manjaro but not now in manjaro gnome.
Thanks for getting back, it worked before this version of manjaro gnome and it worked in windows. I will look at getting a better laptop more worthy and maybe an external drive that could work with manjaro and thanks again for the help. :slight_smile:
external DVD drive should serve you just fine
another 3rd gen laptop user here, got rid of the DVD drive bay to install a second drive
Its amazing they’ve did it this long. I will look for a an external drive. Thanks man.
