I am moving a set of files between 2 computers … A and B
I want to have an identical set on each system. A system has a full rsync backup
Total File size is > 1Tb.
When I uuse ‘rsync -rv A B --delete’ old unwanted files remain on the B system and I am trying to get a full duplication.
I could simply delete everything on the B system and then copy but that is a longer process.
Any ideas?
CloneZilla
use the option to save and restore partitions. for using and handling tutorials check their website, internet tutorials and youtube
I can recommend using syncthing … it uses bittorrent to sync between networked systems
rsync is quite overwhelming - so using a gui to create the scripts - grsync - may help you.
This may be no bug, but a feature of rsync
There are several --delete -options in rsync because rsync is used for a lot of things.
I suggest using the documentation of rsync yourself. This is one of the best i found.
man rsync
info rsync
example:
Prior to rsync 2.6.7, this option would have no effect unless --recursive was enabled. Beginning with 2.6.7, deletions will also occur when --dirs (-d)
is enabled, but only for directories whose contents are being copied.
If you’re investigating which files weren’t deleted, you can use the rsync documentation to find out why.
- This could be due to permissions
- or because rsync doesn’t delete directories when they should go away
- or …
You have to look at individual examples.
But rsync
is one of the most reliable programs I’ve seen.
THIS could never work but:
rsync -rv --delete A B
Thank you … my error understood.
My goto backup/restore line.
--exclude
can be changed to --exclude-from=/path/to/file/exclude.txt
a txt file with one directory per line.
rsync -ahvD --exclude={/dir1/*,/dir2} --info=progress2 --stats --delete --delete-excluded --force --partial SOURCE DESTINATION
# info and some extra options that might be useful, well, -x I guess. xD
--progress = copy with progress information
--stats = give some file-transfer stats
--delete = delete extraneous files from dest dirs
--force = force deletion of dirs even if not empty
--partial = keep partially transferred files
--numeric-ids = don't map uid/gid values by user/group name
a = keep permissions/recursive direcories etc (equals -rlptgoD)
h = human readable
v = verbose
l = copy symlinks as symlinks
x = don't cross filesystem boundaries
D = transfer character and block device files and transfer special files such as named sockets and fifos
Edit
Note that THIS WILL DELETE ALL OTHER FILES ON THE DESTINATION OTHER THAN WHAT YOU ARE TRANSFERING FROM SOURCE
