Hi there guys,
I am running Manjaro with Kernel 6.3.5 (6.3.5-1-MANJARO), and using the Unified Linux Driver (uld_V1.00.39_01.17.tar.gz) I was able to make the printer “part” of my device work but scanner did not succeeded.
Checking scanimage commands I got the following outputs:
scanimage -L
device `smfp:usb;04e8;3441;Z5ZZBDAB708599X' is a Samsung SCX-3200 Series on USB Scanner
device `xerox_mfp:libusb:003:003' is a Samsung Samsung SCX-3200 Series multi-function peripheral
device `v4l:/dev/video0' is a Noname C922 Pro Stream Webcam virtual device
scanimage -T
Output format is not set, using pnm as a default.
scanimage: sane_start: Error during device I/O
If someone has faced this issue or know something about, I would deeply appreciate some help on this.
Thanks!!!
