Yes, I do understand. Nothing can be done. And no, I am not dual booting with Windows - has read that dual booting gives a lot of problems. Here are the logs:
~ journalctl -b0 -p4 --no-pager ✔
Sep 28 21:18:05 r-cave kernel: x86/cpu: SGX disabled by BIOS.
Sep 28 21:18:05 r-cave kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Sep 28 21:18:05 r-cave kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Sep 28 21:18:05 r-cave kernel: #2 #3
Sep 28 21:18:05 r-cave kernel: hpet_acpi_add: no address or irqs in _CRS
Sep 28 21:18:05 r-cave kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Sep 28 21:18:05 r-cave kernel: i8042: Warning: Keylock active
Sep 28 21:18:06 r-cave kernel: elants_i2c i2c-ELAN0001:00: supply vcc33 not found, using dummy regulator
Sep 28 21:18:06 r-cave kernel: elants_i2c i2c-ELAN0001:00: supply vccio not found, using dummy regulator
Sep 28 21:18:06 r-cave kernel: elan_i2c i2c-ELAN0000:00: supply vcc not found, using dummy regulator
Sep 28 21:18:08 r-cave systemd[395]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 28 21:18:08 r-cave kernel: kauditd_printk_skb: 20 callbacks suppressed
Sep 28 21:18:08 r-cave kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
Sep 28 21:18:08 r-cave kernel: HDMI HDA Codec ehdaudio0D2: Max dais supported: 3
Sep 28 21:18:08 r-cave kernel: ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
Sep 28 21:18:08 r-cave kernel: snd_soc_skl 0000:00:1f.3: Direct firmware load for 9d70-INTEL-SCRDMAX-0-tplg.bin failed with error -2
Sep 28 21:18:08 r-cave kernel: snd_soc_skl 0000:00:1f.3: Direct firmware load for skl_n88l25_m98357a-tplg.bin failed with error -2
Sep 28 21:18:08 r-cave kernel: snd_soc_skl 0000:00:1f.3: Direct firmware load for dfw_sst.bin failed with error -2
Sep 28 21:18:08 r-cave kernel: snd_soc_skl 0000:00:1f.3: Fallback tplg fw dfw_sst.bin load failed with -2
Sep 28 21:18:08 r-cave kernel: snd_soc_skl 0000:00:1f.3: Failed to init topology!
Sep 28 21:18:08 r-cave kernel: snd_soc_skl 0000:00:1f.3: ASoC: error at snd_soc_component_probe on 0000:00:1f.3: -2
Sep 28 21:18:08 r-cave kernel: skl_n88l25_m98357a skl_n88l25_m98357a: ASoC: failed to instantiate card -2
Sep 28 21:18:08 r-cave kernel: skl_n88l25_m98357a: probe of skl_n88l25_m98357a failed with error -2
Sep 28 21:18:12 r-cave baloo_file[483]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.22'
Sep 28 21:18:12 r-cave ksmserver[522]: Qt: Session management error: networkIdsList argument is NULL
Sep 28 21:18:13 r-cave ksplashqml[465]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Sep 28 21:18:13 r-cave ksplashqml[465]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Sep 28 21:18:13 r-cave ksmserver[522]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Sep 28 21:18:13 r-cave kernel: kauditd_printk_skb: 12 callbacks suppressed
Sep 28 21:18:13 r-cave kwin_x11[525]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 28 21:18:13 r-cave kwin_x11[525]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 28 21:18:13 r-cave plasmashell[550]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 28 21:18:13 r-cave plasmashell[550]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 28 21:18:14 r-cave kwin_x11[525]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Sep 28 21:18:14 r-cave org_kde_powerdevil[569]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Sep 28 21:18:14 r-cave plasmashell[550]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 28 21:18:14 r-cave plasmashell[550]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 28 21:18:14 r-cave kded5[524]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: cannot open shared object file: No such file or directory)"
Sep 28 21:18:14 r-cave org_kde_powerdevil[569]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 28 21:18:15 r-cave plasmashell[550]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Sep 28 21:18:15 r-cave plasmashell[550]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Sep 28 21:18:15 r-cave plasmashell[550]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Sep 28 21:18:15 r-cave plasmashell[550]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Sep 28 21:18:15 r-cave plasmashell[550]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 28 21:18:15 r-cave pipewire[773]: mod.rt: Can't find xdg-portal: (null)
Sep 28 21:18:15 r-cave pipewire[773]: mod.rt: found session bus but no portal
Sep 28 21:18:15 r-cave pipewire[773]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Sep 28 21:18:15 r-cave pipewire[773]: mod.rt: could not make thread 778 realtime using RTKit: Permission denied
Sep 28 21:18:15 r-cave wireplumber[774]: Failed to set scheduler settings: Operation not permitted
Sep 28 21:18:15 r-cave plasmashell[550]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Sep 28 21:18:15 r-cave plasmashell[550]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Sep 28 21:18:16 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Sep 28 21:18:16 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Sep 28 21:18:16 r-cave plasmashell[550]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Sep 28 21:18:16 r-cave plasmashell[550]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55c6b7d26460)
Sep 28 21:18:16 r-cave plasmashell[550]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55c6b7d2b3a0)
Sep 28 21:18:16 r-cave plasmashell[550]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55c6b7d2bd20)
Sep 28 21:18:16 r-cave plasmashell[550]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55c6b79bfad0)
Sep 28 21:18:16 r-cave plasmashell[550]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55c6b7d2bd20)
Sep 28 21:18:16 r-cave plasmashell[550]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55c6b7be1210)
Sep 28 21:18:16 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Sep 28 21:18:16 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 28 21:18:16 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Sep 28 21:18:17 r-cave plasmashell[550]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Sep 28 21:18:17 r-cave plasmashell[550]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Sep 28 21:18:17 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/PulseAudio.qml:9:1: module "org.kde.plasma.private.volume" is not installed
Sep 28 21:18:17 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Sep 28 21:18:17 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2369, resource id: 4194351, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:18:17 r-cave kwin_x11[525]: kwin_core: XCB error: 152 (BadDamage), sequence: 2371, resource id: 18874405, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 28 21:18:17 r-cave plasmashell[550]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 28 21:18:20 r-cave plasmashell[550]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 28 21:18:21 r-cave plasmashell[550]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 28 21:18:22 r-cave plasmashell[550]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 28 21:18:22 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/DeviceItem.qml:33:32: QML Action: Accessible must be attached to an Item
Sep 28 21:18:23 r-cave bluetoothd[395]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Sep 28 21:18:24 r-cave plasmashell[550]: trying to show an empty dialog
Sep 28 21:18:31 r-cave pamac-manager[816]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Sep 28 21:18:32 r-cave pulseaudio[857]: stat('/etc/pulse/default.pa.d'): No such file or directory
Sep 28 21:18:32 r-cave bluetoothd[395]: src/profile.c:register_profile() :1.54 tried to register 00001108-0000-1000-8000-00805f9b34fb which is already registered
Sep 28 21:18:32 r-cave bluetoothd[395]: src/profile.c:register_profile() :1.54 tried to register 0000111f-0000-1000-8000-00805f9b34fb which is already registered
Sep 28 21:18:32 r-cave pulseaudio[857]: org.bluez.ProfileManager1.RegisterProfile() failed: org.bluez.Error.NotPermitted: UUID already registered
Sep 28 21:18:35 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5982, resource id: 4194408, major code: 15 (QueryTree), minor code: 0
Sep 28 21:18:39 r-cave plasmashell[550]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Sep 28 21:18:39 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7045, resource id: 27263133, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:18:39 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7061, resource id: 27263134, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:18:40 r-cave dolphin[893]: kf.kio.widgets: Cannot read information about filesystem under path "/home/r/.cache/thumbnails/"
Sep 28 21:19:00 r-cave dolphin[893]: kf.kio.widgets: Cannot read information about filesystem under path "/home/r/.cache/thumbnails/"
Sep 28 21:19:01 r-cave dolphin[893]: kf.kio.widgets: Cannot read information about filesystem under path "/home/r/.cache/thumbnails/"
Sep 28 21:19:02 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11950, resource id: 58720267, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:19:02 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11954, resource id: 4194321, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:19:02 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11970, resource id: 27263159, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:19:05 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12491, resource id: 27263169, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:19:07 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13805, resource id: 18875350, major code: 3 (GetWindowAttributes), minor code: 0
Sep 28 21:19:07 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13806, resource id: 18875350, major code: 14 (GetGeometry), minor code: 0
Sep 28 21:19:15 r-cave kioslave5[676]: kf.kio.core: timeoutSpecialCommand() did not call finished() or error()! Please fix the kio_http KIO slave
Sep 28 21:19:15 r-cave kioslave5[674]: kf.kio.core: timeoutSpecialCommand() did not call finished() or error()! Please fix the kio_http KIO slave
Sep 28 21:19:39 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22937, resource id: 27263179, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:41:55 r-cave kwin_x11[525]: kwin_core: XCB error: 152 (BadDamage), sequence: 2056, resource id: 18888140, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 28 21:42:13 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5261, resource id: 60817476, major code: 18 (ChangeProperty), minor code: 0
Sep 28 21:42:13 r-cave kwin_x11[525]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5270, resource id: 27263213, major code: 18 (ChangeProperty), minor code: 0
