Dummy Output after system update — audio hardware no longer detected
Hi,
After doing a regular Manjaro system update, my audio stopped working. Before the update, the built-in audio hardware worked normally. After rebooting, the only available output device is “Dummy Output”, and the system does not seem to detect my actual audio hardware.
I have not intentionally changed any audio configuration that I am aware and am at my wits end.
I ran:
alsa-info.sh --upload
the result of which you can find here (ttps://alsa-project.org/db/?f=0e8ca6b4d27aa0525f6768797de0aea3a163a454)
Here is some other diagnostic output:
==================== BASIC SYSTEM ====================
lör 25 apr 2026 12:46:41 CEST
Linux darth-pc 6.6.128-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Mar  4 20:00:03 UTC 2026 x86_64 GNU/Linux
NAME="Manjaro Linux"
PRETTY_NAME="Manjaro Linux"
ID=manjaro
ID_LIKE=arch
BUILD_ID=rolling
ANSI_COLOR="32;1;24;144;200"
HOME_URL="https://manjaro.org/"
DOCUMENTATION_URL="https://wiki.manjaro.org/"
SUPPORT_URL="https://forum.manjaro.org/"
BUG_REPORT_URL="https://manjaro.org/help/"
PRIVACY_POLICY_URL="https://manjaro.org/privacy-policy/"
LOGO=manjarolinux
### Installed kernels
e[32mCurrently running:e[0m 6.6.128-1-MANJARO (linux66)
   * linux510
   * linux66
### Full system info
  Kernel: 6.6.128-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=54a35d1e-94b8-4aa3-8e41-1033c0b4dc89 rw quiet apparmor=1
    security=apparmor resume=UUID=7f6fa23a-ae81-4a6b-ae5f-696b91a17d5f
    udev.log_priority=3
  Desktop: GNOME v: 49.5 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: xfce4-screensaver dm: LightDM v: 1.32.0
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X403FA_X403FA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X403FA v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends
    v: X403FA.302 date: 05/30/2019
  ID-1: BAT0 charge: 38.7 Wh (84.6%) condition: 45.7/72.7 Wh (62.9%)
    volts: 15.8 min: 15.8 model: ASUSTeK X403 type: Li-ion serial: <filter>
    charging: status: discharging control: start: N/A end: 100% cycles: 616
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
    status: discharging
  System RAM: total: 16 GiB available: 15.42 GiB used: 6.61 GiB (42.9%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron part-no: MT52L1G32D4PG-093
    serial: N/A
  Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
    serial: N/A
  Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 400/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 32012
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb
    ibpb_exit_to_user ibrs ida intel_pt invpcid lahf_lm lm mca mce md_clear
    mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: ASUSTeK
    ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:56d3
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: 27XCF built: 2023 res: 1920x1080 dpi: 82
    gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green: x: 0.314 y: 0.627 blue:
    x: 0.149 y: 0.051 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x960, 1366x768, 1280x800, 1152x864, 1280x768,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x240
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080
    dpi: 158 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
    blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
    GT2) device-ID: 8086:3ea0 memory: 15.06 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.341 layers: 6 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (WHL GT2) driver: mesa intel v: 26.0.2-arch1.1
    device-ID: 8086:3ea0 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.6.128-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 476.94 GiB used: 300.67 GiB (63.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPNUW-512G-1002 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20110000 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 321.41 GiB size: 315.3 GiB (98.10%)
    used: 255.26 GiB (81.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:3
    label: N/A uuid: 54a35d1e-94b8-4aa3-8e41-1033c0b4dc89
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 25.4 MiB (9.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: FC4B-C52B
  ID-3: /mnt/745F422F03D9C169 raw-size: 146.62 GiB
    size: 146.62 GiB (100.00%) used: 45.37 GiB (30.9%) fs: ntfs
    dev: /dev/nvme0n1p3 maj-min: 259:2 label: N/A uuid: 745F422F03D9C169
  ID-1: swap-1 type: partition size: 8 GiB used: 20.2 MiB (0.2%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:4 label: N/A
    uuid: 7f6fa23a-ae81-4a6b-ae5f-696b91a17d5f
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56d3 class-ID: 0e02
    serial: <filter>
  Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 41.0 C pch: 37.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Packages: 2268 pm: pacman pkgs: 2248 libs: 584 tools: pamac,yay pm: flatpak
    pkgs: 8 pm: snap pkgs: 12
    1: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    7: https://linorg.usp.br/manjaro/stable/$repo/$arch
    8: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    9: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    10: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 309
  1: cpu: 300% command: ps pid: 141112 mem: 4.40 MiB (0.0%)
  2: cpu: 89.7% command: file-roller pid: 141065 mem: 54.1 MiB (0.3%)
  3: cpu: 54.5% command: org.gnome.NautilusPreviewer started-by: gjs
    pid: 141064 mem: 227.5 MiB (1.4%)
  4: cpu: 24.4% command: ding.js started-by: gjs pid: 141047
    mem: 57.5 MiB (0.3%)
  5: cpu: 17.8% command: chrome pid: 122950 mem: 337.8 MiB (2.1%)
  Memory top: 5 of 309
  1: mem: 584.5 MiB (3.7%) command: steamwebhelper pid: 30744 cpu: 0.1%
  2: mem: 530.4 MiB (3.3%) command: ./steamwebhelper pid: 30644 cpu: 0.0%
  3: mem: 501.5 MiB (3.1%) command: chrome pid: 122874 cpu: 15.8%
  4: mem: 495.6 MiB (3.1%) command: steam pid: 30426 cpu: 0.2%
  5: mem: 363.8 MiB (2.3%) command: steamwebhelper pid: 30689 cpu: 0.0%
  Processes: 309 Power: uptime: 2d 16h 9m states: freeze,mem,disk
    suspend: s2idle avail: deep wakeups: 5 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.16 GiB services: gsd-power,upowerd
    Init: systemd v: 259 default: graphical tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
### Kernel command line
BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=54a35d1e-94b8-4aa3-8e41-1033c0b4dc89 rw quiet apparmor=1 security=apparmor resume=UUID=7f6fa23a-ae81-4a6b-ae5f-696b91a17d5f udev.log_priority=3
==================== AUDIO HARDWARE ====================
### PCI audio devices
00:1f.3 Audio device [0403]: Intel Corporation Cannon Point-LP High Definition Audio Controller [8086:9dc8] (rev 30)
	DeviceName: Onboard - Sound
	Subsystem: ASUSTeK Computer Inc. Device [1043:1771]
	Kernel driver in use: sof-audio-pci-intel-cnl
	Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
00:1f.4 SMBus [0c05]: Intel Corporation Cannon Point-LP SMBus Controller [8086:9da3] (rev 30)
	DeviceName: Onboard - Other
	Kernel driver in use: i801_smbus
### USB devices
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 13d3:56d3 IMC Networks USB2.0 HD UVC WebCam
Bus 001 Device 004: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
### /dev/snd
total 0
drwxr-xr-x   3 root root      200 22 apr 20.37 .
drwxr-xr-x  21 root root     4700 22 apr 20.37 ..
drwxr-xr-x   2 root root       60 22 apr 20.37 by-path
crw-rw----+  1 root audio 116,  6 22 apr 20.37 controlC0
crw-rw----+  1 root audio 116,  5 22 apr 20.37 hwC0D2
crw-rw----+  1 root audio 116,  2 22 apr 20.37 pcmC0D1p
crw-rw----+  1 root audio 116,  3 22 apr 20.37 pcmC0D2p
crw-rw----+  1 root audio 116,  4 22 apr 20.37 pcmC0D3p
crw-rw----+  1 root audio 116,  1 22 apr 20.37 seq
crw-rw----+  1 root audio 116, 33 22 apr 20.37 timer
### Processes using sound devices
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  darth      1997 F.... wireplumber
/dev/snd/seq:        darth      1996 F.... pipewire
==================== ALSA ====================
### ALSA cards
 0 [sofhdadsp      ]: sof-hda-dsp - sof-hda-dsp
                      ASUSTeKCOMPUTERINC.-VivoBook_ASUSLaptopX403FA_X403FA-1.0-X403FA
### ALSA devices
  1:        : sequencer
  2: [ 0- 1]: digital audio playback
  3: [ 0- 2]: digital audio playback
  4: [ 0- 3]: digital audio playback
  5: [ 0- 2]: hardware dependent
  6: [ 0]   : control
 33:        : timer
### ALSA modules
 0 snd_soc_skl_hda_dsp
### Playback devices
**** List of PLAYBACK Hardware Devices ****
card 0: sofhdadsp [sof-hda-dsp], device 1: HDMI1 (*) []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 2: HDMI2 (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI3 (*) []
  Subdevices: 1/1
### Capture devices
**** List of CAPTURE Hardware Devices ****
### All ALSA PCMs
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
usbstream:CARD=sofhdadsp
    sof-hda-dsp
    USB Stream Output
### ALSA mixer state, if card 0 exists
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'PGA2.0 2 Master',0
  Capabilities: pvolume
  Limits: Playback 0 - 32
  Mono:
  Front Left: Playback 32 [100%] [0.00dB]
  Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA3.0 3 Master',0
  Mono:
Simple mixer control 'PGA4.0 4 Master',0
  Mono:
### ALSA config files
ls: cannot access '/etc/asound.conf': No such file or directory
ls: cannot access '/home/darth/.asoundrc': No such file or directory
==================== KERNEL MODULES / FIRMWARE ====================
### Sound-related loaded modules
snd_seq_dummy          12288  0
snd_hrtimer            12288  1
snd_seq               126976  7 snd_seq_dummy
snd_seq_device         16384  1 snd_seq
snd_soc_skl_hda_dsp    24576  3
snd_soc_intel_hda_dsp_common    16384  1 snd_soc_skl_hda_dsp
snd_sof_probes         24576  0
snd_soc_hdac_hdmi      45056  1 snd_soc_skl_hda_dsp
snd_soc_dmic           12288  1
snd_sof_pci_intel_cnl    12288  0
snd_sof_intel_hda_common   241664  1 snd_sof_pci_intel_cnl
soundwire_intel        81920  1 snd_sof_intel_hda_common
snd_sof_intel_hda_mlink    36864  2 soundwire_intel,snd_sof_intel_hda_common
soundwire_cadence      45056  1 soundwire_intel
snd_sof_intel_hda      20480  1 snd_sof_intel_hda_common
snd_hda_codec_hdmi     98304  1
snd_sof_pci            24576  2 snd_sof_intel_hda_common,snd_sof_pci_intel_cnl
snd_sof_xtensa_dsp     16384  1 snd_sof_intel_hda_common
snd_sof               425984  4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_probes,snd_sof_intel_hda
snd_sof_utils          16384  1 snd_sof
soundwire_generic_allocation    12288  1 soundwire_intel
soundwire_bus         139264  3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
snd_soc_skl           241664  0
snd_soc_hdac_hda       28672  2 snd_sof_intel_hda_common,snd_soc_skl
snd_hda_ext_core       36864  6 snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_soc_skl,snd_sof_intel_hda
snd_soc_sst_ipc        16384  1 snd_soc_skl
snd_soc_sst_dsp        40960  1 snd_soc_skl
snd_soc_acpi_intel_match    94208  3 snd_sof_intel_hda_common,snd_soc_skl,snd_sof_pci_intel_cnl
snd_soc_acpi           16384  3 snd_soc_acpi_intel_match,snd_sof_intel_hda_common,snd_soc_skl
snd_soc_core          446464  9 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_skl,snd_sof_probes,snd_soc_dmic,snd_soc_skl_hda_dsp
snd_compress           28672  2 snd_soc_core,snd_sof_probes
ac97_bus               12288  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_hda_intel          65536  0
snd_intel_dspcfg       36864  4 snd_hda_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_skl
snd_intel_sdw_acpi     16384  2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_hda_codec         217088  7 snd_hda_codec_hdmi,snd_hda_intel,snd_soc_intel_hda_dsp_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda,snd_soc_skl_hda_dsp
snd_hda_core          139264  10 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_intel_hda_dsp_common,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
snd_hwdep              20480  1 snd_hda_codec
snd_pcm               200704  13 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_sof_utils,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
ledtrig_audio          12288  1 asus_wmi
snd_timer              49152  3 snd_seq,snd_hrtimer,snd_pcm
snd                   155648  20 snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_sof,snd_timer,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_pcm
soundcore              16384  1 snd
i2c_hid_acpi           12288  0
i2c_hid                40960  1 i2c_hid_acpi
acpi_tad               20480  0
acpi_pad               24576  0
acpi_thermal_rel       20480  1 int3400_thermal
### Sound-related kernel messages
apr 22 20:37:37 darth-pc kernel: Linux version 6.6.128-1-MANJARO (builduser@runnervmnay03) (gcc (GCC) 15.2.1 20260209, GNU ld (GNU Binutils) 2.46) #1 SMP PREEMPT_DYNAMIC Wed Mar  4 20:00:03 UTC 2026
apr 22 20:37:37 darth-pc kernel: software IO TLB: area num 8.
apr 22 20:37:37 darth-pc kernel: Dynamic Preempt: full
apr 22 20:37:37 darth-pc kernel: SRBDS: Mitigation: Microcode
apr 22 20:37:37 darth-pc kernel: GDS: Mitigation: Microcode
apr 22 20:37:37 darth-pc kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
apr 22 20:37:37 darth-pc kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
apr 22 20:37:37 darth-pc kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
apr 22 20:37:37 darth-pc kernel: ACPI: Dynamic OEM Table Load:
apr 22 20:37:37 darth-pc kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
apr 22 20:37:37 darth-pc kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
apr 22 20:37:37 darth-pc kernel: software IO TLB: mapped [mem 0x000000007dded000-0x0000000081ded000] (64MB)
apr 22 20:37:37 darth-pc kernel: microcode: Current revision: 0x000000f6
apr 22 20:37:37 darth-pc kernel: microcode: Updated early from: 0x000000b8
apr 22 20:37:37 darth-pc kernel: microcode: Microcode Update Driver: v2.2.
apr 22 20:37:37 darth-pc kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
apr 22 20:37:37 darth-pc kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
apr 22 20:37:37 darth-pc kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
apr 22 20:37:38 darth-pc systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
apr 22 20:37:39 darth-pc kernel: input: PC Speaker as /devices/platform/pcspkr/input/input19
apr 22 20:37:39 darth-pc kernel: iwlwifi 0000:00:14.3: loaded firmware version 46.7e3e4b69.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
apr 22 20:37:39 darth-pc kernel: snd_hda_intel:azx_probe: snd_hda_intel 0000:00:1f.3: HDAudio driver not selected, aborting probe
apr 22 20:37:39 darth-pc kernel: mousedev: PS/2 mouse device common for all mice
apr 22 20:37:40 darth-pc kernel: snd_sof_pci:sof_pci_probe: sof-audio-pci-intel-cnl 0000:00:1f.3: PCI DSP detected
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: enabling device (0000 -> 0002)
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0xc00
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: found ML capability at 0xc00
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x800
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: found DSP capability at 0x800
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x500
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: found GTS capability at 0x500
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x1f00
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: found DRSM capability at 0x1f00
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: checking for capabilities at offset 0x700
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ctrl_get_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: found SPIB capability at 0x700
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_init: sof-audio-pci-intel-cnl 0000:00:1f.3: hda global caps = 0x1009701
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_init: sof-audio-pci-intel-cnl 0000:00:1f.3: detected 9 playback and 7 capture streams
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: use msi interrupt mode
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_probe: sof-audio-pci-intel-cnl 0000:00:1f.3: using IPC IRQ 136
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_init_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: PP capability, will probe DSP later.
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda:hda_codec_detect_mask: sof-audio-pci-intel-cnl 0000:00:1f.3: codec_mask = 0x4
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 22 20:37:40 darth-pc kernel: snd_intel_sdw_acpi:sdw_intel_scan_controller: acpi PRP00001:00: ACPI reports 4 SDW Link devices
apr 22 20:37:40 darth-pc kernel: snd_intel_sdw_acpi:sdw_intel_scan_controller: acpi PRP00001:00: Link 0 not selected in firmware
apr 22 20:37:40 darth-pc kernel: snd_intel_sdw_acpi:sdw_intel_scan_controller: acpi PRP00001:00: Link 1 not selected in firmware
apr 22 20:37:40 darth-pc kernel: snd_intel_sdw_acpi:sdw_intel_scan_controller: acpi PRP00001:00: Link 2 not selected in firmware
apr 22 20:37:40 darth-pc kernel: snd_intel_sdw_acpi:sdw_intel_scan_controller: acpi PRP00001:00: Link 3 not selected in firmware
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_init_caps: sof-audio-pci-intel-cnl 0000:00:1f.3: skipping SoundWire, no links enabled
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda:hda_codec_probe: sof-audio-pci-intel-cnl 0000:00:1f.3: HDA codec #2 probed OK: response: 8086280b
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda:request_codec_module: snd_hda_codec_hdmi ehdaudio0D2: loading codec module: hdaudio:v8086280Br00100000a01
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: hda codecs found, mask 4
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
apr 22 20:37:40 darth-pc kernel: snd_intel_dspcfg:intel_nhlt_get_dmic_geo: sof-audio-pci-intel-cnl 0000:00:1f.3: dmic number 0 max_ch 0
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: DMICs detected in NHLT tables: 0
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_load_firmware_raw: sof-audio-pci-intel-cnl 0000:00:1f.3: request_firmware intel/sof/sof-cnl.ri successful
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 1 size 0x1a0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 6 size 0x20
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_ext_man_get_cavs_config_data: sof-audio-pci-intel-cnl 0000:00:1f.3: FW clock config: HPRO
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 0 size 0x50
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: version 2:2:0-57864
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 2 size 0x70
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_get_cc_info: sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: used compiler XCC 12:0:8 <RG-2017.8-linux> used optimization flags -O2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 3 size 0x30
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 4 size 0x20
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_fw_ext_man_get_dbg_abi_info: sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: DBG_ABI 5:3:0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_fw_parse_ext_man: sof-audio-pci-intel-cnl 0000:00:1f.3: found sof_ext_man header type 5 size 0x20
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_fw_ext_man_get_config_data: sof-audio-pci-intel-cnl 0000:00:1f.3: manifest can hold up to 3 config elements
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_fw_ext_man_get_config_data: sof-audio-pci-intel-cnl 0000:00:1f.3: get index 0 token 1 val 384
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_fw_ext_man_get_config_data: sof-audio-pci-intel-cnl 0000:00:1f.3: get index 1 token 2 val 1
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_fw_ext_man_get_config_data: sof-audio-pci-intel-cnl 0000:00:1f.3: get index 2 token 0 val 0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_hw_params: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_setup_bdl: sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x0
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_setup_bdl: sof-audio-pci-intel-cnl 0000:00:1f.3: periods:1
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: Attempting iteration 0 of Core En/ROM load...
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5000001 successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_cl_copy_fw: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_trigger: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x140000 successful
apr 22 20:37:40 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware download successful, booting...
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_get_windows: sof-audio-pci-intel-cnl 0000:00:1f.3:  mailbox upstream 0x81000 - size 0x1000
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_get_windows: sof-audio-pci-intel-cnl 0000:00:1f.3:  mailbox downstream 0xa0000 - size 0x2000
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_get_windows: sof-audio-pci-intel-cnl 0000:00:1f.3:  stream region 0xc1000 - size 0x1000
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_get_windows: sof-audio-pci-intel-cnl 0000:00:1f.3:  debug region 0xc0000 - size 0x800
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 22 20:37:40 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_probe_continue: sof-audio-pci-intel-cnl 0000:00:1f.3: SOF firmware trace disabled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_machine_register: sof-audio-pci-intel-cnl 0000:00:1f.3: created machine skl_hda_dsp_generic
apr 22 20:37:40 darth-pc kernel: snd_sof_pci:sof_pci_probe_complete: sof-audio-pci-intel-cnl 0000:00:1f.3: Completing SOF PCI probe
apr 22 20:37:40 darth-pc kernel: snd_sof:snd_sof_load_topology: sof-audio-pci-intel-cnl 0000:00:1f.3: loading topology:intel/sof-tplg/sof-hda-generic-idisp.tplg
apr 22 20:37:40 darth-pc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 0 (iDisp3 Tx) is ready [type: 7, pipe: 0, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 7 name iDisp3 Tx not handled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 1 (iDisp2 Tx) is ready [type: 7, pipe: 1, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 7 name iDisp2 Tx not handled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 2 (PCM1P) is ready [type: 23, pipe: 2, pins: 0 / 0, stream: Passthrough Playback 1]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_control_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 2 Master Playback Volume
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_control_load_volume: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 3 chans 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 3 (PGA2.0) is ready [type: 6, pipe: 2, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 4 (BUF2.0) is ready [type: 31, pipe: 2, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 5 (BUF2.1) is ready [type: 31, pipe: 2, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 6 (HDA0.OUT) is ready [type: 27, pipe: 2, pins: 0 / 0, stream: iDisp1]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_connect_dai_widget: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget HDA0.OUT -> DAI link iDisp1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 7 (PIPELINE.2.HDA0.OUT) is ready [type: 32, pipe: 2, pins: 0 / 0, stream: HDA0.OUT]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 8 (iDisp1_out) is ready [type: 1, pipe: 2, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 1 name iDisp1_out not handled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 9 (iDisp1 Tx) is ready [type: 7, pipe: 2, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 7 name iDisp1 Tx not handled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 10 (PCM2P) is ready [type: 23, pipe: 3, pins: 0 / 0, stream: Passthrough Playback 2]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_control_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 3 Master Playback Volume
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_control_load_volume: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 11 chans 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 11 (PGA3.0) is ready [type: 6, pipe: 3, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 12 (BUF3.0) is ready [type: 31, pipe: 3, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 13 (BUF3.1) is ready [type: 31, pipe: 3, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 14 (HDA1.OUT) is ready [type: 27, pipe: 3, pins: 0 / 0, stream: iDisp2]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_connect_dai_widget: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget HDA1.OUT -> DAI link iDisp2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 15 (PIPELINE.3.HDA1.OUT) is ready [type: 32, pipe: 3, pins: 0 / 0, stream: HDA1.OUT]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 16 (iDisp2_out) is ready [type: 1, pipe: 3, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 1 name iDisp2_out not handled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 17 (PCM3P) is ready [type: 23, pipe: 4, pins: 0 / 0, stream: Passthrough Playback 3]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_control_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load control type 1 name : 4 Master Playback Volume
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_control_load_volume: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load kcontrol index 18 chans 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 18 (PGA4.0) is ready [type: 6, pipe: 4, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 19 (BUF4.0) is ready [type: 31, pipe: 4, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 20 (BUF4.1) is ready [type: 31, pipe: 4, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 21 (HDA2.OUT) is ready [type: 27, pipe: 4, pins: 0 / 0, stream: iDisp3]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_connect_dai_widget: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: connected widget HDA2.OUT -> DAI link iDisp3
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 22 (PIPELINE.4.HDA2.OUT) is ready [type: 32, pipe: 4, pins: 0 / 0, stream: HDA2.OUT]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: widget 23 (iDisp3_out) is ready [type: 1, pipe: 4, pins: 0 / 0, stream: none]
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_widget_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: widget type 1 name iDisp3_out not handled
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_dai_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm HDMI1 1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_dai_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm HDMI2 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_dai_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: load pcm HDMI3 3
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF2.0 control none source PCM1P
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink PGA2.0 control none source BUF2.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF2.1 control none source PGA2.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink HDA0.OUT control none source BUF2.1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF3.0 control none source PCM2P
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink PGA3.0 control none source BUF3.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF3.1 control none source PGA3.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink HDA1.OUT control none source BUF3.1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF4.0 control none source PCM3P
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink PGA4.0 control none source BUF4.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink BUF4.1 control none source PGA4.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_route_load: sof-audio-pci-intel-cnl 0000:00:1f.3: sink HDA2.OUT control none source BUF4.1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_link_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 1 for dai link iDisp1!
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_link_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 2 for dai link iDisp2!
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_link_load: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: 1 hw_configs found, default id: 3 for dai link iDisp3!
apr 22 20:37:40 darth-pc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_pipeline: sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.4.HDA2.OUT: period 1000 pri 0 mips 5000 core 0 frames 0 dynamic 1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_dai: sof-audio-pci-intel-cnl 0000:00:1f.3: dai HDA2.OUT: type 3 index 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_dbg_comp_config: sof-audio-pci-intel-cnl 0000:00:1f.3:  config: periods snk 0 src 2 fmt 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_link_hda_load: sof-audio-pci-intel-cnl 0000:00:1f.3: HDA config rate 48000 channels 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_buffer: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF4.1: size 768 caps 0x71
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_buffer: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF4.0: size 768 caps 0x71
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_pga: sof-audio-pci-intel-cnl 0000:00:1f.3: loaded PGA PGA4.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_dbg_comp_config: sof-audio-pci-intel-cnl 0000:00:1f.3:  config: periods snk 2 src 2 fmt 2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_host: sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM3P
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_dbg_comp_config: sof-audio-pci-intel-cnl 0000:00:1f.3:  config: periods snk 2 src 0 fmt 0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_pipeline: sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.3.HDA1.OUT: period 1000 pri 0 mips 5000 core 0 frames 0 dynamic 1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_dai: sof-audio-pci-intel-cnl 0000:00:1f.3: dai HDA1.OUT: type 3 index 1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_buffer: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF3.1: size 768 caps 0x71
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_buffer: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF3.0: size 768 caps 0x71
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_pga: sof-audio-pci-intel-cnl 0000:00:1f.3: loaded PGA PGA3.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_host: sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM2P
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_pipeline: sof-audio-pci-intel-cnl 0000:00:1f.3: pipeline PIPELINE.2.HDA0.OUT: period 1000 pri 0 mips 5000 core 0 frames 0 dynamic 1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_dai: sof-audio-pci-intel-cnl 0000:00:1f.3: dai HDA0.OUT: type 3 index 0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_buffer: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF2.1: size 768 caps 0x71
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_buffer: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer BUF2.0: size 768 caps 0x71
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_pga: sof-audio-pci-intel-cnl 0000:00:1f.3: loaded PGA PGA2.0
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_ipc3_widget_setup_comp_host: sof-audio-pci-intel-cnl 0000:00:1f.3: loaded host PCM1P
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_pcm_new: sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM HDMI1
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_pcm_new: sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Passthrough Playback 1 playback DMA buffer size 0x10000 max 0x10000
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_pcm_new: sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM HDMI2
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_pcm_new: sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Passthrough Playback 2 playback DMA buffer size 0x10000 max 0x10000
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_pcm_new: sof-audio-pci-intel-cnl 0000:00:1f.3: creating new PCM HDMI3
apr 22 20:37:40 darth-pc kernel: snd_sof:sof_pcm_new: sof-audio-pci-intel-cnl 0000:00:1f.3: spcm: allocate Passthrough Playback 3 playback DMA buffer size 0x10000 max 0x10000
apr 22 20:37:40 darth-pc kernel: input: sof-hda-dsp HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input23
apr 22 20:37:40 darth-pc kernel: input: sof-hda-dsp HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input24
apr 22 20:37:40 darth-pc kernel: input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input25
apr 22 20:37:40 darth-pc kernel: Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
apr 22 20:37:40 darth-pc kernel: Bluetooth: hci0: Firmware Version: 201-12.24
apr 22 20:37:40 darth-pc kernel: Bluetooth: hci0: Firmware already loaded
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_open: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 3 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_open: sof-audio-pci-intel-cnl 0000:00:1f.3: period min 192 max 16384 bytes
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_open: sof-audio-pci-intel-cnl 0000:00:1f.3: period count 2 max 16
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_open: sof-audio-pci-intel-cnl 0000:00:1f.3: buffer max 65536 bytes
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_calc_stream_format: sof-audio-pci-intel-cnl 0000:00:1f.3: format_val=0x31, rate=48000, ch=2, format=10
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_hw_params: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 3 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_hw_params: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x160]=0x40000 successful
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_setup_bdl: sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x12c0
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_setup_bdl: sof-audio-pci-intel-cnl 0000:00:1f.3: periods:4
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30100000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PIPELINE.4.HDA2.OUT setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30010000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PCM3P setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30200000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF4.0 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x50010000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PGA4.0 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF4.1 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x80010000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget HDA2.OUT setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route PCM3P -> BUF4.0
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30030000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route BUF4.0 -> PGA4.0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route PGA4.0 -> BUF4.1
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route BUF4.1 -> HDA2.OUT
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_complete_pipeline: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.4.HDA2.OUT id 22
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30130000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_pcm_hw_params: sof-audio-pci-intel-cnl 0000:00:1f.3: stream_tag 1
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60010000
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_set_stream_data_offset: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: stream dir 0, posn mailbox offset is 790528
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_hw_free: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 3 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x60030000
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30020000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PCM3P freed
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30210000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF4.0 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PGA4.0 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF4.1 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x30110000
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PIPELINE.4.HDA2.OUT freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget HDA2.OUT freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_close: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 3 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_open: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 1 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_hw_params: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 1 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_setup_bdl: sof-audio-pci-intel-cnl 0000:00:1f.3: period_bytes:0x2000
apr 22 20:37:51 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_stream_setup_bdl: sof-audio-pci-intel-cnl 0000:00:1f.3: periods:8
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PIPELINE.2.HDA0.OUT setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PCM1P setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF2.0 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PGA2.0 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF2.1 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget HDA0.OUT setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route PCM1P -> BUF2.0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route BUF2.0 -> PGA2.0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route PGA2.0 -> BUF2.1
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route BUF2.1 -> HDA0.OUT
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_complete_pipeline: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.2.HDA0.OUT id 7
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_hw_free: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 1 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PCM1P freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF2.0 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PGA2.0 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF2.1 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PIPELINE.2.HDA0.OUT freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget HDA0.OUT freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_close: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 1 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_open: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: open stream 2 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_hw_params: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: hw params stream 2 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PIPELINE.3.HDA1.OUT setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PCM2P setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF3.0 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PGA3.0 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF3.1 setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_setup_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget HDA1.OUT setup complete
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route PCM2P -> BUF3.0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route BUF3.0 -> PGA3.0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route PGA3.0 -> BUF3.1
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_route_setup: sof-audio-pci-intel-cnl 0000:00:1f.3: setting up route BUF3.1 -> HDA1.OUT
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_ipc3_complete_pipeline: sof-audio-pci-intel-cnl 0000:00:1f.3: tplg: complete pipeline PIPELINE.3.HDA1.OUT id 15
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_hw_free: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: free stream 2 dir 0
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PCM2P freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF3.0 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PGA3.0 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget BUF3.1 freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget PIPELINE.3.HDA1.OUT freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_widget_free_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: widget HDA1.OUT freed
apr 22 20:37:51 darth-pc kernel: snd_sof:sof_pcm_close: sof-audio-pci-intel-cnl 0000:00:1f.3: pcm: close stream 2 dir 0
apr 22 21:17:37 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000010 at  00000044
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
apr 22 21:17:37 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 7 -> 0
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
apr 22 21:17:37 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 22 21:17:37 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: IMR restore supported, booting from IMR directly
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 22 21:17:37 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 22 21:17:37 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 22 21:17:37 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 22 21:17:37 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 22 21:17:37 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 22 21:17:37 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 22 21:17:37 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 22 21:17:37 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
apr 23 00:54:55 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000010 at  00000044
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
apr 23 00:54:55 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 7 -> 0
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
apr 23 00:54:55 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 23 00:54:55 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: IMR restore supported, booting from IMR directly
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 23 00:54:55 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 23 00:54:55 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 23 00:54:55 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 23 00:54:55 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 23 00:54:55 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 23 00:54:55 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 23 00:54:55 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 23 00:54:55 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
apr 23 11:36:48 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000010 at  00000044
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
apr 23 11:36:48 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 7 -> 0
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
apr 23 11:36:48 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 23 11:36:48 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: IMR restore supported, booting from IMR directly
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 23 11:36:48 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 23 11:36:48 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 23 11:36:48 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 23 11:36:48 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 23 11:36:48 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 23 11:36:48 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 23 11:36:48 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 23 11:36:48 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
apr 24 10:33:03 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000010 at  00000044
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
apr 24 10:33:03 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 7 -> 0
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
apr 24 10:33:03 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 24 10:33:03 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: IMR restore supported, booting from IMR directly
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 24 10:33:03 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 24 10:33:03 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 24 10:33:03 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 24 10:33:03 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 24 10:33:03 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 24 10:33:03 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 24 10:33:03 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 24 10:33:03 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
apr 25 12:06:15 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40010000
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010f0f successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask f
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000010 at  00000044
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D3
apr 25 12:06:15 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 7 -> 0
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
apr 25 12:06:15 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 25 12:06:15 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: IMR restore supported, booting from IMR directly
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 25 12:06:15 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 25 12:06:15 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 25 12:06:15 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 25 12:06:15 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 25 12:06:15 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 25 12:06:15 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 25 12:06:15 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 25 12:06:15 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 1
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000044
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000040 at  00000048
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000048
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000000 at  00000048
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000040 at  00000048
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda:hda_codec_i915_display_power: sof-audio-pci-intel-cnl 0000:00:1f.3: Turning i915 HDAC power 0
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_state_log: sof-audio-pci-intel-cnl 0000:00:1f.3: Current DSP power state: D0I0
apr 25 12:06:16 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 0 -> 2
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_load_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: loading firmware
apr 25 12:06:16 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 2 -> 3
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000002 at  00000048
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000004 at  00000044
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: booting DSP firmware
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_cl_boot_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: IMR restore supported, booting from IMR directly
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_up: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0f successful
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_leave: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0f0e successful
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_run: sof-audio-pci-intel-cnl 0000:00:1f.3: unstall/run core: core_mask = 1
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 1 : core_mask 1
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0xd4]=0x80000000 successful
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_reset_enter: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0xf0f0e0e successful
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_power_down: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x4]=0x1010e0e successful
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:hda_dsp_core_is_enabled: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP core(s) enabled? 0 : core_mask e
apr 25 12:06:16 darth-pc kernel: snd_sof_intel_hda_common:cl_dsp_init: sof-audio-pci-intel-cnl 0000:00:1f.3: FW Poll Status: reg[0x80000]=0x5 successful
apr 25 12:06:16 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx: 0x70000000
apr 25 12:06:16 darth-pc kernel: snd_sof:ipc3_fw_ready: sof-audio-pci-intel-cnl 0000:00:1f.3: DSP is ready 0x70000000 offset 0x81000
apr 25 12:06:16 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 3 -> 6
apr 25 12:06:16 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc rx done: 0x70000000
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_run_firmware: sof-audio-pci-intel-cnl 0000:00:1f.3: firmware boot complete
apr 25 12:06:16 darth-pc kernel: snd_sof:sof_set_fw_state: sof-audio-pci-intel-cnl 0000:00:1f.3: fw_state change: 6 -> 7
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000002 at  00000048
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIR: 00000004 at  00000044
apr 25 12:06:16 darth-pc kernel: snd_sof:snd_sof_pci_update_bits_unlocked: sof-audio-pci-intel-cnl 0000:00:1f.3: Debug PCIW: 00000000 at  00000044
apr 25 12:06:16 darth-pc kernel: snd_sof:ipc3_log_header: sof-audio-pci-intel-cnl 0000:00:1f.3: ipc tx: 0x40020000
==================== PIPEWIRE / PULSE / WIREPLUMBER ====================
### User audio services
Unit pulseaudio.service could not be found.
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
     Active: active (running) since Wed 2026-04-22 20:37:51 CEST; 2 days ago
 Invocation: be7de959db51430482f75fa15e0ebeb4
TriggeredBy: ● pipewire.socket
   Main PID: 1996 (pipewire)
      Tasks: 3 (limit: 18911)
     Memory: 8.6M (peak: 15.9M)
        CPU: 1.575s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─1996 /usr/bin/pipewire
apr 22 20:37:51 darth-pc systemd[1570]: Started PipeWire Multimedia Service.
apr 23 01:07:59 darth-pc pipewire[1996]: pw.node: (bluez_output_internal.80_99_E7_5B_46_CF.1-54) idle -> error (Received error event)
● pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
 Invocation: 364d59f1aa9f4aedab8971b23e08692c
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 2001 (pipewire-pulse)
     Memory: 19.5M (peak: 26.2M)
        CPU: 10.713s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─2001 /usr/bin/pipewire-pulse
apr 22 20:37:51 darth-pc systemd[1570]: Started PipeWire PulseAudio.
● wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
 Invocation: 7a3f05ba673a43de86e6331dc972aec0
   Main PID: 1997 (wireplumber)
      Tasks: 6 (limit: 18911)
     Memory: 13.5M (peak: 18.6M)
        CPU: 24.050s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
             └─1997 /usr/bin/wireplumber
apr 22 20:37:51 darth-pc systemd[1570]: Started Multimedia Service Session Manager.
apr 22 20:37:51 darth-pc wireplumber[1997]: spa.alsa: No sink and source at HiFi: Speaker
apr 22 20:37:51 darth-pc wireplumber[1997]: spa.alsa: No sink and source at HiFi: Headphones
apr 22 20:37:52 darth-pc wireplumber[1997]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
apr 22 20:37:52 darth-pc wireplumber[1997]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
apr 23 01:07:59 darth-pc wireplumber[1997]: spa.bluez5.sink.media: 0x55db4c90c528: connection (/org/bluez/hci0/dev_80_99_E7_5B_46_CF/sep3/fd0) terminated unexpectedly
apr 23 01:07:59 darth-pc wireplumber[1997]: pw.node: (bluez_output_internal.80_99_E7_5B_46_CF.1-54) running -> error (Received error event)
apr 23 01:07:59 darth-pc wireplumber[1997]: spa.bluez5: Failure in Bluetooth audio transport /org/bluez/hci0/dev_80_99_E7_5B_46_CF/sep3/fd0
### PipeWire versions
pipewire
Compiled with libpipewire 1.6.2
Linked with libpipewire 1.6.2
wireplumber
Compiled with libwireplumber 0.5.13
Linked with libwireplumber 0.5.13
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 244
Tile Size: 65472
User Name: darth
Host Name: darth-pc
Server Name: PulseAudio (on PipeWire 1.6.2)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: eef5:d503
### PipeWire/WirePlumber status
PipeWire 'pipewire-0' [1.6.2, darth@darth-pc, cookie:4009088259]
 └─ Clients:
        32. WirePlumber                         [1.6.2, darth@darth-pc, pid:1997]
        40. WirePlumber [export]                [1.6.2, darth@darth-pc, pid:1997]
        41. pipewire                            [1.6.2, darth@darth-pc, pid:2001]
        43. GNOME Volume Control Media Keys     [1.6.2, darth@darth-pc, pid:44148]
        57. gnome-shell                         [1.6.2, darth@darth-pc, pid:1633]
        58. GNOME Shell Volume Control          [1.6.2, darth@darth-pc, pid:1633]
        61. xdg-desktop-portal                  [1.6.2, darth@darth-pc, pid:2358]
        62. Mutter                              [1.6.2, darth@darth-pc, pid:1633]
        63. Steam Voice Settings                [1.6.2, darth@darth-pc, pid:30426]
        64. Google Chrome input                 [1.6.2, darth@darth-pc, pid:124664]
        65. Steam                               [1.6.2, darth@darth-pc, pid:30426]
        67. Chromium input                      [1.6.2, darth@darth-pc, pid:33095]
        72. wpctl                               [1.6.2, darth@darth-pc, pid:141341]
        81. libcanberra                         [1.6.2, darth@darth-pc, pid:1795]
Audio
 ├─ Devices:
 │      44. Cannon Point-LP High Definition Audio Controller [alsa]
 ├─ Sinks:
 │  *   77. Dummy Output                        [vol: 0.63]
 ├─ Sources:
 ├─ Filters:
 └─ Streams:
Video
 ├─ Devices:
 │      51. USB2.0 HD UVC WebCam                [v4l2]
 │      52. USB2.0 HD UVC WebCam                [v4l2]
 ├─ Sinks:
 ├─ Sources:
 │  *   59. USB2.0 HD UVC WebCam (V4L2)
 ├─ Filters:
 └─ Streams:
Settings
 └─ Default Configured Devices:
         0. Audio/Sink    bluez_output.80:99:E7:5B:46:CF
### PulseAudio-compatible sinks/sources/cards
189	auto_null	PipeWire	float32le 2ch 48000Hz	SUSPENDED
189	auto_null.monitor	PipeWire	float32le 2ch 48000Hz	SUSPENDED
44	alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic	alsa
### Detailed cards
Card #44
	Driver: alsa
	Owner Module: n/a
	Properties:
		device.enum.api = "udev"
		device.api = "alsa"
		media.class = "Audio/Device"
		api.alsa.path = "hw:0"
		api.alsa.card = "0"
		api.alsa.card.name = "sof-hda-dsp"
		api.alsa.card.longname = "ASUSTeKCOMPUTERINC.-VivoBook_ASUSLaptopX403FA_X403FA-1.0-X403FA"
		device.plugged.usec = "7299702"
		device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
		device.bus = "pci"
		device.subsystem = "sound"
		device.vendor.id = "0x8086"
		device.product.id = "0x9dc8"
		device.product.name = "Cannon Point-LP High Definition Audio Controller"
		device.name = "alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic"
		device.description = "Cannon Point-LP High Definition Audio Controller"
		device.nick = "sof-hda-dsp"
		device.icon_name = "audio-card-analog-pci"
		api.alsa.use-acp = "true"
		api.acp.auto-port = "false"
		api.dbus.ReserveDevice1.Priority = "-20"
		api.alsa.split-enable = "true"
		spa.object.id = "2"
		factory.id = "15"
		client.id = "40"
		object.id = "44"
		object.serial = "44"
		object.path = "alsa:acp:sofhdadsp"
		alsa.card = "0"
		alsa.card_name = "sof-hda-dsp"
		alsa.long_card_name = "ASUSTeKCOMPUTERINC.-VivoBook_ASUSLaptopX403FA_X403FA-1.0-X403FA"
		alsa.driver_name = "snd_soc_skl_hda_dsp"
		alsa.mixer_name = "Intel Kabylake HDMI"
		alsa.components = "HDA:8086280b,80860101,00100000"
		alsa.id = "sofhdadsp"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		HiFi: Play HiFi quality Music (sinks: 1, sources: 0, priority: 8500, available: no)
		pro-audio: Pro Audio (sinks: 3, sources: 0, priority: 1, available: yes)
	Active Profile: off
	Ports:
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=3"
				card.profile.port = "0"
			Part of profile(s): HiFi
### PipeWire nodes
	id 29, type PipeWire:Interface:Node/3
 		object.serial = "29"
 		factory.id = "11"
 		priority.driver = "200000"
 		node.name = "Dummy-Driver"
	id 30, type PipeWire:Interface:Node/3
 		object.serial = "30"
 		factory.id = "11"
 		priority.driver = "190000"
 		node.name = "Freewheel-Driver"
	id 45, type PipeWire:Interface:Node/3
 		object.serial = "45"
 		factory.id = "11"
 		client.id = "40"
 		priority.session = "100"
 		priority.driver = "1"
 		node.name = "Midi-Bridge"
 		media.class = "Midi/Bridge"
	id 48, type PipeWire:Interface:Node/3
 		object.serial = "48"
 		factory.id = "14"
 		client.id = "40"
 		node.description = "BLE MIDI 1"
 		node.name = "bluez_midi.server"
	id 59, type PipeWire:Interface:Node/3
 		object.serial = "59"
 		object.path = "v4l2:/dev/video0"
 		factory.id = "11"
 		client.id = "40"
 		device.id = "51"
 		priority.session = "1000"
 		node.description = "USB2.0 HD UVC WebCam (V4L2)"
 		node.name = "v4l2_input.pci-0000_00_14.0-usb-0_4_1.0"
 		node.nick = "USB2.0 HD UVC WebCam"
 		media.class = "Video/Source"
 		media.role = "Camera"
	id 77, type PipeWire:Interface:Node/3
 		object.serial = "189"
 		factory.id = "19"
 		client.id = "41"
 		node.description = "Dummy Output"
 		node.name = "auto_null"
 		media.class = "Audio/Sink"
==================== AUDIO PACKAGES ====================
local/alsa-card-profiles 1:1.6.2-1
    Low-latency audio/video router and processor - ALSA card profiles
local/alsa-firmware 1.2.4-4
    Firmware binaries for loader programs in alsa-tools and hotplug firmware loader
local/alsa-lib 1.2.15.3-2
    An alternative implementation of Linux sound support
local/alsa-oss 1.1.8-6
    OSS compatibility library
local/alsa-plugins 1:1.2.12-5
    Additional ALSA plugins
local/alsa-tools 1.2.15-3
    Advanced tools for certain sound cards
local/alsa-topology-conf 1.2.5.1-4
    ALSA topology configuration files
local/alsa-ucm-conf 1.2.15.3-1
    ALSA Use Case Manager configuration (and topologies)
local/alsa-utils 1.2.15.2-2
    Advanced Linux Sound Architecture - Utilities
local/gst-plugin-pipewire 1:1.6.2-1
    Multimedia graph framework - pipewire plugin
local/lib32-alsa-lib 1.2.15.3-1
    An alternative implementation of Linux sound support (32 bit)
local/lib32-alsa-oss 1.1.8-5
    OSS compatibility library (32 bit)
local/lib32-alsa-plugins 1.2.12-1
    Additional ALSA plugins (32-bit)
local/lib32-libcanberra 1:0.30+r2+gc0620e4-4
    A small and lightweight implementation of the XDG Sound Theme Specification (32-bit)
local/lib32-libpipewire 1:1.6.2-1
    Low-latency audio/video router and processor - 32-bit - client library
local/lib32-libpulse 17.0+r98+gb096704c0-1
    A featureful, general-purpose sound server (32-bit client libraries)
local/lib32-pipewire 1:1.6.2-1
local/libcanberra 1:0.30+r2+gc0620e4-6
local/libpipewire 1:1.6.2-1
    Low-latency audio/video router and processor - client library
local/libpulse 17.0+r98+gb096704c0-1
    A featureful, general-purpose sound server (client library)
local/libwireplumber 0.5.13-1
    Session / policy manager implementation for PipeWire - client library
local/linux-firmware-amdgpu 20260309-1
    Firmware files for Linux - Firmware for AMD Radeon GPUs
local/linux-firmware-atheros 20260309-1
    Firmware files for Linux - Firmware for Qualcomm Atheros WiFi and Bluetooth adapters
local/linux-firmware-broadcom 20260309-1
    Firmware files for Linux - Firmware for Broadcom and Cypress network adapters
local/linux-firmware-cirrus 20260309-1
    Firmware files for Linux - Firmware for Cirrus Logic audio devices
local/linux-firmware-intel 20260309-1
    Firmware files for Linux - Firmware for Intel devices
local/linux-firmware-mediatek 20260309-1
    Firmware files for Linux - Firmware for MediaTek and Ralink devices
local/linux-firmware-meta 20260309-1
    Firmware files for Linux - Default set (Meta Package)
local/linux-firmware-nvidia 20260309-1
    Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/linux-firmware-other 20260309-1
    Firmware files for Linux - Unsorted firmware for various devices
local/linux-firmware-radeon 20260309-1
    Firmware files for Linux - Firmware for ATI Radeon GPUs
local/linux-firmware-realtek 20260309-1
    Firmware files for Linux - Firmware for Realtek devices
local/linux-firmware-whence 20260309-1
    Firmware files for Linux - WHENCE file (vendor licenses)
local/manjaro-alsa 20221002-1
    Manjaro meta package for complete ALSA support
local/manjaro-pipewire 20231009-1
    Manjaro meta package for complete PipeWire support.
local/pipewire 1:1.6.2-1
local/pipewire-alsa 1:1.6.2-1
    Low-latency audio/video router and processor - ALSA configuration
local/pipewire-audio 1:1.6.2-1
    Low-latency audio/video router and processor - Audio support
local/pipewire-pulse 1:1.6.2-1
    Low-latency audio/video router and processor - PulseAudio replacement
local/pulseaudio-alsa 1:1.2.12-5
    ALSA Configuration for PulseAudio
local/python-pulsectl 23.5.2-1
    Python high-level interface and ctypes-based bindings for PulseAudio (libpulse)
local/sof-firmware 2025.12.2-1
    Sound Open Firmware
local/vlc-plugin-alsa 3.0.21-32
    Free and open source cross-platform multimedia player and framework - ALSA plugins
local/vlc-plugin-pulse 3.0.21-32
    Free and open source cross-platform multimedia player and framework - PulseAudio plugins
local/wireplumber 0.5.13-1
local/xfce4-pulseaudio-plugin 0.5.1-1 (xfce4-goodies)
    Pulseaudio plugin for the Xfce4 panel
local/zita-alsa-pcmi 0.6.1-3
    The successor of clalsadrv, provides easy access to ALSA PCM devices.
==================== RECENT USER AUDIO LOGS ====================
==================== RECENT SYSTEM ERRORS ====================
apr 22 20:37:40 darth-pc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
I had a similar issue on an older Linux Mint release.
It turned out that it was caused by a kernel version update.
Reverting to the previous kernel version, I had sound again.
alsa-info data shows a modprobe option added by user to force use of Sound Open Firmware driver
https://alsa-project.org/db/?f=0e8ca6b4d27aa0525f6768797de0aea3a163a454
!!Modprobe options (Sound related)
snd_intel_dspcfg: dsp_driver=3
$ modinfo -p snd_intel_dspcfg
dsp_driver:Force the DSP driver for Intel DSP (0=auto, 1=legacy, 2=SST, 3=SOF, 4=AVS) (int)
I suggest:
  1. Change the modprobe option to snd_intel_dspcfg dsp_driver=0 and reboot system to see if it can autodetect the correct drivers for audio devices
  2. Change the modprobe option to snd_intel_dspcfg dsp_driver=1 and reboot system to force use of legacy driver snd_hda_intel
This is a 3 year old kernel on a system where everything else is up-to-date. Please consider to use the latest LTS kernel which is 6.18.
Thanks alot everyone. It is sorted now I think.
Kernel 6.18 with snd_intel_dspcfg dsp_driver=1 fixed detection somehow. Booting without HDMI gives working speaker audio now. So it seems this is the way I should boot the pc now.
After plugging HDMI, PipeWire/WirePlumber sometimes stops routing audio to the analog speaker sink even though Settings still shows “Speakers - Built-in Audio”. However restarting PipeWire/WirePlumber seems to restore the audio.
Since this was so helpful, another issue I had (though less bad) was I had to move from GDM to LightDM as my login manager, since the former froze my screen (and system) after entering my password. Maybe the new kernel fixes it, or should I make another post about that?
Always a new post for a new issue.
Check audio card profiles in Audio GUI controls or:
pactl list cards
System may have changed audio profile to use HDMI output for audio playback instead of built-in speakers
