Dumb question - zip file installs go where?
I’m a long-time dev moving to my first linux OS as may main. I’ve used linux in the past so I’m a small bit competent, however I have a very dumb newbie question:
When I download a zipped application to install, the instructions are usually: download zip to folder of choice, unzip, run installer. So… where is the application actually installed to? Is the installer pointing my path variable to whatever location I happened to unzip to?
EDIT for clarity: in this case I’m talking about the AWS CLI and SAM. Using ‘which aws’ shows /usr/local/bin/aws’, so I assume it’s in a safe spot and I can remove the unzipped stuff from my Downloads folder?
Wherever the install script tells it to.
We’re in 2022 though, so you should install apps with package manager or, if not available in aur/repo, make a PKGBUILD yourself.
Well that makes sense, assuming the installer doesn’t put it someplace dumb or just uses current location. Thank you!
