I want to set a dual system in dual hard disk, can anybody give me some comment? This is my configuration:
512GB SSD (Windows 10) Existing disk
240GB SSD (Manjaro) New Disk
The partition format of 2 SSDs is GBT (Both of them)
Here is the question, I don’t know is there any mistake in my ideas because I only install the dual system successfully on a single hard disk before.
My thoughts are like this:
/boot/efi partition installed at the existing SSD, that 100MB Windows efi.
/ partition installed at the new SSD, 40GB
/home partition installed at the new SSD, 200GB
However, do I need to reserve 512MB on the new SSD for the /boot partition? Or compress the existing SSD directly?
