Dual Sense Gamepad No Longer Connects
After the May 4th update, neither of my Playstation Dual Sense controllers will connect to my motherboard’s built in bluetooth. Forgetting and re-pairing them does not work either, results in the same “Host is down(112)” error.
5/5/25 9:16 AM	systemd	Started Add Bluetooth Device - Add Bluetooth Device.
5/5/25 9:16 AM	systemd	Reached target Bluetooth.
5/5/25 9:16 AM	bluetoothd	No matching connection for device
5/5/25 9:16 AM	bluetoothd	profiles/input/device.c:control_connect_cb() connect to 88:03:4C:A0:21:DC: Host is down (112)
5/5/25 9:16 AM	bluedevil-wizard	kf.bluezqt: PendingCall Error: "br-connection-create-socket"
inxi -Fazy         ✔
  Kernel: 6.14.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=77427a09-ba79-423b-bbc0-7868b269c65d ro apparmor=1
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
  Type: Desktop System: Micro-Star product: MS-7C95 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 2.M1 date: 09/03/2024
  Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 1755 min/max: 550/4552 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1755 2: 1755 3: 1755
    4: 1755 5: 1755 6: 1755 7: 1755 8: 1755 9: 1755 10: 1755 11: 1755 12: 1755
    13: 1755 14: 1755 15: 1755 16: 1755 bogomips: 108798
    affected
  Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2b:00.0
    chip-ID: 10de:2782 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: HDMI-A-1 model: BenQ PJ serial: <filter> built: 2020 res:
    mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440 gamma: 1.2 size: N/A
    modes: max: 3840x2160 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
    memory: 11.71 GiB display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 Ti driver: nvidia v: 570.144 device-ID: 10de:2782
    surfaces: xcb,xlib,wayland
  Device-1: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 2b:00.1 chip-ID: 10de:22bc class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Creative SB Omni Surround 5.1
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2.4:3 chip-ID: 041e:322c class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.14.4-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-media-session
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
    tools: pacat,pactl,pavucontrol
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
    class-ID: e001
  Local Storage: total: 29.19 TiB used: 13.38 TiB (45.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: TeamGroup model: TM8FP4004T
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: VB421D65 temp: 35.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 3.64 TiB block-size: physical: 512 B
    fw-rev: ELFMC1.0 temp: 27.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWR180 size: 7.28 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: 0603 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST14000NM000J-2TX103
    size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: WDC WDS200T2B0A-00SM50
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    scheme: GPT
  ID-1: / raw-size: 3.73 TiB size: 3.67 TiB (98.40%) used: 2.27 TiB (61.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:6
    used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
  System Temperatures: cpu: 35.4 C mobo: N/A
  Fan Speeds (rpm): fan-1: 782 fan-2: 0 fan-3: 0 fan-4: 1528 fan-5: 0
    fan-6: 0 fan-7: 0 fan-8: 0 fan-9: 0 fan-10: 0
  Memory: total: 32 GiB available: 31.26 GiB used: 4.58 GiB (14.7%)
  Processes: 370 Power: uptime: 28m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,upowerd
  Packages: 2626 pm: pacman pkgs: 2581 libs: 618 tools: pamac,yay pm: flatpak
    pkgs: 33 pm: snap pkgs: 12 Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 11/13
    Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
