Hello all,
I have the following setup:
$ lspci | grep -i vga
03:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 760] (rev a1)
08:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev e7)
and I am using the nvidia gpu as the main gpu for manjaro and the radeon one I use it for a virtual machine with qemu/kvm in a windows 10 client. For this I am isolating the radeon gpu right from the start to use vfio drivers.
08:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev e7) (prog-if 00 [VGA controller])
Subsystem: Sapphire Technology Limited Nitro+ Radeon RX 570/580/590
Flags: bus master, fast devsel, latency 0, IRQ 255, IOMMU group 21
Memory at 7fd0000000 (64-bit, prefetchable) [size=256M]
Memory at 7fe0000000 (64-bit, prefetchable) [size=2M]
I/O ports at f000 [disabled] [size=256]
Memory at fcb00000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at fcb40000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: vfio-pci
Kernel modules: amdgpu
08:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
Subsystem: Sapphire Technology Limited Device aaf0
Flags: fast devsel, IRQ 255, IOMMU group 21
Memory at fcb60000 (64-bit, non-prefetchable) [disabled] [size=16K]
Kernel modules: snd_hda_intel
while for nvidia I have:
03:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 760] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 3265
Flags: bus master, fast devsel, latency 0, IRQ 100, IOMMU group 19
Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
Memory at 7fe8000000 (64-bit, prefetchable) [size=128M]
Memory at 7ff0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at fc000000 [virtual] [disabled] [size=512K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
Can anyone help me figure out if the nvidia video drivers are installed correctly in manjaro?
My confusion comes from this:
$ sudo mhwd -l
> 0000:03:00.0 (0300:10de:1187) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-450xx-prime 2019.10.25 false PCI
video-hybrid-amd-nvidia-440xx-prime 2019.10.25 false PCI
video-hybrid-amd-nvidia-435xx-prime 2019.10.25 false PCI
video-nvidia-450xx 2019.10.25 false PCI
video-nvidia-440xx 2019.10.25 false PCI
video-nvidia-435xx 2019.10.25 false PCI
video-nvidia-430xx 2019.10.25 false PCI
video-nvidia-418xx 2019.10.25 false PCI
video-nvidia-390xx 2019.10.25 false PCI
video-nvidia-340xx 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:08:00.0 (0300:1002:67df) Display controller ATI Technologies Inc:
and this:
$ sudo mhwd -li
> Installed PCI configs:
Shouldn’t the nvidia gpu run video-nvidia-450xx
? why did it installl the hybrid amd-nvidia driver? Is this correct?
