Yes, unfortunately. I usually turn off “smooth scrolling” (or whatever it’s called) in the browser.
UPDATE:
I found a “solution” to my original problem without having to install optimus-manager.
I modified a guide I found at xrandr virtual splitscreen cookbook
It uses the xrandr --setmonitor command to create virtual monitors. The idea is I take the screen in split it into 2 virtual monitors. Someone more linux savvy than me might be able to make this more eloquent, but the below is a down-and-dirty way I got it to work. It allows me to maximize windows and have them stay in whatever monitor I want. It also allows me to snap windows in both monitors correctly. I don’t have to worry about logging in and out to change from intel or nvidia mode.
Upon first logging in, if I am am using two monitors, I run a script with the following commands:
xrandr --setmonitor veDP-1 1920/344x1080/193+1920+0 eDP-1
xrandr --setmonitor vHDMI-1-0 1920/480x1080/270+0+0 HDMI-1-0
xrandr --fb 3840x1080
xrandr --output eDP-1 --primary --mode 1920x1080 --rate 120.11 --output HDMI-1-0 --panning 1920x1080 --mode 1920x1080 --left-of eDP-1 --rate 60
If I am running with only a single monitor, I run a script with the following commands:
xrandr --delmonitor veDP-1
xrandr --delmonitor vHDMI-1-0
xrandr --fb 1920x1081
xrandr --fb 1920x1080
While running my session, I can run either script to switch between using only one monitor or only two.
Also, run the script after either plugging in a monitor, or unplugging it. Running the one monitor setup script before unplugging the second monitor causes it to wonk out.
I’m hoping to automate this somehow, but I don’t know really know how to go about it.
I would say this qualifies as a solution. The only way to “automate” that is to have 2 .desktop files on the … erm… desktop and double-clicking them to get the config you want.
- Here is a rather elaborate tutorial on how to create a desktop file.
- Alternatively, modify this very crude desktop file:
[Desktop Entry]
Version=1.0
Exec=/path/to/file.sh
Name=2 Monitors
GenericName=Monitor config
Comment=Change Screen config to use 2 monitors
Encoding=UTF-8
Terminal=true
Type=Application
Categories=Application;Utilities;
