Hey everyone,
I dual boot windows and Manjaro. I recently reinstalled Manjaro on my partition. When booting into Manjaro both monitors work up until I login, then it switches off and presents a black screen “Display Port No Signal”. I went into Display Configuration and attempted enable it with no success. I accessed nvidia-settings
→ X Server Display Configuration
and enabled the affected monitor and messed then set its refresh rate to 165. It turned on for just a moment, presented a black screen once again, with the same ‘no signal’ text.
After that I tried to scale down my refresh rate on both monitors, from 165 → 144 → 50, mirroing it for both with no success. I also tried to do the same thing with the resolution. When that failed I tried swapping the display port cables and power cables, also with no success.
inxi -v7azy
^wl2m26bf6hvh
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=949a6168-86c0-41a2-b437-d2cd8bc8fb90 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B560 DS3H AC-Y1 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F3
date: 04/27/2021
RAM: total: 46.92 GiB used: 4.44 GiB (9.5%)
Info: model: 11th Gen Intel Core i5-11400 bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x56
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 801 3: 801 4: 801
5: 800 6: 800 7: 800 8: 800 9: 800 10: 801 11: 800 12: 800 bogomips: 62232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: eVga.com.
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2504
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3839x1080 s-dpi: 80 s-size: 1219x343mm (47.99x13.50")
s-diag: 1266mm (49.86")
Monitor-1: DP-0 pos: primary res: 1920x1080 dpi: 81
size: 600x330mm (23.62x12.99") diag: 685mm (26.96") modes: N/A
Monitor-2: DP-2 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
bus-ID: 1-6:6 v: kernel alternate: snd_sof_pci_intel_tgl chip-ID: 1038:1252
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:43c8 serial: <filter>
class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: SteelSeries ApS Arctis Pro type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
lanes: 1 port: 4000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
chip-ID: 10ec:c821 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-14:9 chip-ID: 13d3:3533 class-ID: e001 serial: <filter>
Local Storage: total: 8.68 TiB used: 1.43 TiB (16.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 004C temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD80EMAZ-00WJTA0 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1029 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Snap
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 322.33 GiB size: 316.2 GiB (98.10%) used: 16.53 GiB (5.2%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 949a6168-86c0-41a2-b437-d2cd8bc8fb90
used: 25.3 MiB (26.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 86AA-F298
ID-3: /run/media/alef/Exogen raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 923.49 GiB (12.4%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Exogen
uuid: 7C089BB4089B6BC0
ID-4: /run/media/alef/Operate raw-size: 609.17 GiB
size: 609.17 GiB (100.00%) used: 520.98 GiB (85.5%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: Operate uuid: 06CEF272CEF2597F
ID-5: /run/media/alef/Ordinal raw-size: 145.98 GiB
size: 145.98 GiB (100.00%) used: 94.1 MiB (0.1%) fs: ntfs dev: /dev/nvme0n1p5
maj-min: 259:5 label: Ordinal uuid: BCC481C3C4817FFE
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 329.84 GiB fs: ntfs label: N/A
uuid: 2628AD4328AD12BB
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 512.7 MiB fs: vfat
label: NO_LABEL uuid: 5F0C-E45D
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 509 MiB fs: ntfs label: N/A
uuid: 0488E04488E03638
ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdc1 maj-min: 8:33 size: 3.32 GiB fs: iso9660
ID-7: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: ROYUAN keydous type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 498mA
chip-ID: 3151:4010 class-ID: 0300
Hub-2: 1-2:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-2.2:11 info: Western Digital Elements Desktop (WDBWLG)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 30mA chip-ID: 1058:25a3 class-ID: 0806 serial: <filter>
Device-2: 1-5:4 info: SanDisk Cruzer Snap type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:55a5 class-ID: 0806 serial: <filter>
Device-3: 1-6:6 info: SteelSeries ApS Arctis Pro type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 250mA chip-ID: 1038:1252 class-ID: 0300
serial: <filter>
Device-4: 1-10:7 info: Razer USA DeathAdder Essential type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:006e class-ID: 0300
Device-5: 1-11:8 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 048d:5702 class-ID: 0300
Device-6: 1-14:9 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
Hub-4: 2-2:2 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s power: 96mA
chip-ID: 0bda:0411 class-ID: 0900
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 46 C
Processes: 307 Uptime: 1h 7m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1260 libs: 324 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.23
λ /var/log/ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
λ /var/log/ mhwd -l
> 0000:01:00.0 (0300:10de:2504) Display controller nVidia Corporation:
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
I also noticed this in Xorg log, googling it makes me believe this is probably what’s affecting me.
[ 7.716] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 7.716] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 7.716] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 7.716] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 7.716] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 7.716] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 7.716] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 7.716] (II) NVIDIA(0): Config Options in the README.
