Hi,
I have a dual monitor setup that previously worked fine, but stopped working after I disconnected one monitor to use for something else and then reconnected. The monitors are both connected via Displayport. When I have both monitors connected only one is detected and working. As soon as I disconnect the working monitor the one that previously was not working is detected and works fine. On the login screen both monitors work but as soon as I log in one switched of and displays “No DP signal detected”
With both monitor connected
inxi -Fzxu
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Dell product: OptiPlex 9020 v: 00
serial: <superuser required>
Mobo: Dell model: 0PC5F7 v: A02 serial: <superuser required> UEFI: Dell
v: A24 date: 10/24/2018
Device-1: hidpp_battery_0
model: Logitech MX Vertical Advanced Ergonomic Mouse
charge: 55% (should be ignored) status: discharging
Info: quad core model: Intel Core i7-4770 bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1245 high: 2590 min/max: 800/3900 cores: 1: 2590 2: 798
3: 798 4: 798 5: 2225 6: 799 7: 799 8: 1153 bogomips: 54299
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
gpu: i915 resolution: 1: N/A 2: 2560x1440~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: Plantronics Plantronics Blackwire 325.1 type: USB
driver: plantronics,snd-usb-audio,usbhid bus-ID: 3-12:5
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0
Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 3-7:4
IF: wlp0s20u7 state: up mac: <filter>
Local Storage: total: 1.81 TiB used: 316.7 GiB (17.1%)
ID-1: /dev/sda vendor: Intel model: SSDSC2BW480A4 size: 447.13 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 860 PRO 512GB size: 476.94 GiB
ID-3: /dev/sdc vendor: Western Digital model: WD1003FZEX-00K3CA0
ID-1: / size: 451.27 GiB used: 42.19 GiB (9.3%) fs: ext4 dev: /dev/sdb2
uuid: b762e455-c5b1-4ddb-9df6-c76e33b2c79d
ID-2: /boot/efi size: 299.4 MiB used: 292 KiB (0.1%) fs: vfat
dev: /dev/sdb1 uuid: 50C8-29A4
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
dev: /dev/sdb3 uuid: 4bac82a9-c287-42b5-b706-9bcd184a826b
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 227 Uptime: 17m Memory: 15.54 GiB used: 2.27 GiB (14.6%)
Init: systemd Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1242
Shell: fish v: 3.4.1 inxi: 3.3.16
and xrandr
output:
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
VGA-1 disconnected (normal left inverted right x axis y axis)
DP-1 connected (normal left inverted right x axis y axis)
2560x1440 59.95 +
2048x1080 60.00 24.00
1920x1080 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1600x1200 60.00
1280x1024 75.02 60.02
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
DP-2-8 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+
1600x1200 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
720x400 70.08
DP-2-1 disconnected (normal left inverted right x axis y axis)
when I disconnect the now working monitor the outputs look as follows:
inxi -Fzxu
Speed (MHz): avg: 1444 high: 3363 min/max: 800/3900 cores: 1: 1095 2: 798
3: 1452 4: 1799 5: 799 6: 1265 7: 981 8: 3363 bogomips: 54299
gpu: i915 resolution: 1440x2560~60Hz
bus-ID: 3-7:4
Processes: 226 Uptime: 20m Memory: 15.54 GiB used: 2.4 GiB (15.4%)
xrandr
Screen 0: minimum 320 x 200, current 1440 x 2560, maximum 16384 x 16384
DP-1 connected primary 1440x2560+0+0 left (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+
1600x1200 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
720x400 70.08
DP-2-8 disconnected (normal left inverted right x axis y axis)
I have tried rebooting and restarting xserver but nothing changed.
Any help is highly appreciated.
Cheers,
Davy
