Hello y’all!
I am reposting this from the reddit thread.
Let me extend what the title says: I have a Razer Notebook, with an eGPU (AMD Hawaii XT / Grenada XT [Radeon R9 290X/390X]) connected through Tunderbolt (Razer Core) and two monitors.
Installed is Manjaro with Gnome and wayland.
Depending on the resolution + refresh rate one or the other monitor shows a grey overlay over the area that shows the application windows. When the main screen is the one having issues, the top bar with the time/date and logout options is visible. When I move windows around on the screen with the overlay I can see the background and the windows themselves, same when I press the SUPER button to show all open windows, although the grey overlay is there as soon as I go back and try to work.
To have an idea of what I am talking about, here a video:
Here more information about the system:
inxi -SMGxxaz
System: Host: <redacted> Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=8997e623-856e-4a62-bfd8-08ddea5ab137 rw quiet
cryptdevice=UUID=4d9fc197-e920-4a53-8311-4d2528cea2ab:luks-4d9fc197-e920-4a53-8311-4d2528cea2ab
root=/dev/mapper/luks-4d9fc197-e920-4a53-8311-4d2528cea2ab
resume=/dev/mapper/luks-4d9fc197-e920-4a53-8311-4d2528cea2ab
Desktop: Gnome 3.36.4 wm: gnome-shell dm: GDM Distro: Manjaro Linux
Machine: Type: Laptop System: Razer product: Blade Stealth v: 2.04 serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Razer model: Razer serial: <filter> UEFI: Razer v: 8.02 date: 02/22/2018
Graphics: Device-1: Intel HD Graphics 620 vendor: Razer USA driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Advanced Micro Devices [AMD/ATI] Hawaii XT / Grenada XT [Radeon R9 290X/390X] vendor: PC Partner Limited
driver: amdgpu v: kernel bus ID: 07:00.0 chip ID: 1002:67b0
Display: wayland server: X.Org 1.20.8 driver: amdgpu compositor: gnome-shell
resolution: 1920x1080~50Hz, 1080x1920~50Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.3 direct render: Yes
mhwd --pci -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
xrandr | awk ’ /connected/ { print $1, $2 }’
xrandr | awk ' /connected/ { print $1, $2 }'
XWAYLAND1 connected
XWAYLAND2 connected
for p in /sys/class/drm//status; do con=${p%/status}; echo -n "${con#/card?-}: "; cat $p; done
DP-1: disconnected
DP-2: disconnected
eDP-1: connected
HDMI-A-1: disconnected
DP-3: connected
DVI-D-1: disconnected
DVI-D-2: disconnected
HDMI-A-2: connected
I tried autorandr like suggested.
I saved the laptop profile, then connected everything and it works well, until I close the lid of the laptop. As soon as I close the lid, the overlay comes back to the display. (I also tried to disable the laptop display from the settings, same behaviour)
Here how that looks like:
I copied the triple monitor configuration and renamed to double.
Original triple
output XWAYLAND2
crtc 2
mode 1080x1920
pos 1920x0
rate 59.87
output XWAYLAND0
crtc 0
gamma 1e-10:1e-10:1e-10
mode 1920x1080
pos 0x452
rate 59.88
output XWAYLAND1
crtc 1
mode 2560x1440
pos 3000x952
rate 59.91
and edited to make it a dual monitor configuration by removing the WAYLAND1 output
output XWAYLAND2
crtc 2
mode 1080x1920
pos 1920x0
rate 59.87
output XWAYLAND0
crtc 0
mode 1920x1080
pos 0x452
rate 59.88
And now if I try to load the double profile (dual screen) it gives this error:
autorandr --load double
xrandr: cannot find crtc 2
Failed to apply profile 'double' (line 857):
Command failed: xrandr --fb 3000x1920 --output XWAYLAND0 --crtc 0 --gamma 1e-10:1e-10:1e-10 --mode 1920x1080 --pos 0x452 --rate 59.88 --reflect normal --rotate normal --output XWAYLAND2 --crtc 2 --gamma 1.0:1.0:1.0 --mode 1080x1920 --pos 1920x0 --rate 59.87 --reflect normal --rotate normal (line 857)
xrandr --listproviders
Providers: number : 0
autorandr --fingerprint
XWAYLAND0 --CONNECTED-BUT-EDID-UNAVAILABLE--XWAYLAND0
XWAYLAND2 --CONNECTED-BUT-EDID-UNAVAILABLE--XWAYLAND2
Any ideas?
Thank you!
