I’m using manjaro alongside windows by dual booting. i am running 2 monitors with hdmi on a gtx 1650. When I first started manjaro i noticed that the right side of my right screen was linked to the left edge of my left screen. my first thought was to drag the monitors around in the display settings. when I do this however my mouse starts controlling the opposite screen to what it is on. If anyone can offer any help it would be greatly appreciated
Thanks
I’m using KDE with a GeForce GTX 960 an found the proprietary NVIDIA X Server Settings tool more reliable than KDE’s display settings.
ok thx how do you get that
nevermind i have xfce
It has been installed together with the nvidia driver. I think it should be there for all desktop environments.
In KDE it is in the settings start menu, the executable is /usr/share/applications/nvidia-settings.
i will try that and tell you if it worked
thx
Have you looked also into ~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml
file ? Maybe remove it and reboot the system.
