Hey guys, I’m using a laptop with Intel and NVIDIA dual graphics cards. When I use dwarf, everything is normal. But when I added an external display screen, I found that the dwarf’s animation would have obvious frame dropping and jamming. So I tried to disable the NVIDIA graphics card. After restarting, the animation of both monitors was normal. It is normal to use only the built-in screen of the notebook. It is also normal to use the internal and external devices after disabling the nvidia graphics card. For this reason, I also compared one monitor with two monitors in the new manjaro in USB. After connecting the monitors, the animation of the dwarf desktop was obviously stuck. How to configure the dual display hybrid graphics card call?
This brother has the same problem as me
https://forum.manjaro.org/t/bad-performance-of-gnome-mutter-on-nvidia-cards
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=24d61417-e6ce-4b35-b64a-566180eb6f5e rw quiet splash apparmor=1
security=apparmor resume=UUID=c331d4b3-13b6-40b6-b9c6-7d3c49f5c0a5
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: G7 7790 v: N/A
Mobo: Dell model: 0F7T8V v: A00 serial: <superuser required> UEFI: Dell
v: 1.22.0 date: 11/10/2022
ID-1: BAT0 charge: 43.1 Wh (100.0%) condition: 43.1/60.0 Wh (71.8%)
volts: 16.6 min: 15.2 model: BYD DELL HYWXJ91 type: Li-poly serial: <filter>
status: full
RAM: total: 15.44 GiB used: 3.96 GiB (25.6%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4371 high: 4447 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4400 2: 4400 3: 4402
4: 4402 5: 4222 6: 4447 7: 4369 8: 4379 9: 4285 10: 4442 11: 4351 12: 4362
bogomips: 62431
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-1,eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Dell
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f10 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:7 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: nvidia gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-1 pos: right model: Lenovo LI2241 Wide serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x409d built: 2018
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
class-ID: 0200
IF: enp60s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
all]
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:11 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.38 TiB used: 64.24 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG30ZMS512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: ADDA0105 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 40WD
scheme: GPT
ID-1: / raw-size: 82.17 GiB size: 80.57 GiB (98.06%) used: 25.84 GiB (32.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 24d61417-e6ce-4b35-b64a-566180eb6f5e
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 94.3 MiB (14.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP
uuid: 6AA6-F1DC
ID-3: /home raw-size: 200 GiB size: 195.8 GiB (97.90%)
used: 38.31 GiB (19.6%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 67173ed7-4497-4fcf-99c3-bd364ddf6c82
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: c331d4b3-13b6-40b6-b9c6-7d3c49f5c0a5
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 459.15 GiB fs: ntfs label: OS
uuid: 2CE4D6A2E4D66D98
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: B430434330430BB4
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 14.86 GiB fs: ntfs label: Image
uuid: B80A43920A434D16
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.19 GiB fs: ntfs
label: DELLSUPPORT uuid: BEE873BFE873748D
ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-7: /dev/sda2 maj-min: 8:2 size: 631.33 GiB fs: ntfs
label: \xe8\xa5\xbf\xe6\x95\xb0 uuid: E89C29B39C297CE6
ID-8: /dev/sda3 maj-min: 8:3 size: 2 GiB fs: vfat label: NO_LABEL
uuid: DFCE-BC6B
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.1:4 info: QinHeng CH341 in serial mode usb to port converter
type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
speed: 12 Mb/s power: 480mA chip-ID: 1a86:5523 class-ID: ff00
Device-2: 1-2.3:6 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 258a:002a class-ID: 0300
Hub-3: 1-2.4:8 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-3:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-4: 1-4:5 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-4.4:9 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 2109:0102
class-ID: 1100 serial: <filter>
Device-2: 1-5:7 info: Microdia Integrated_Webcam_HD type: Video
Device-3: 1-11:10 info: Alienware LED controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
chip-ID: 187c:0550 class-ID: 0300 serial: <filter>
Device-4: 1-14:11 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-5: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 6-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
System Temperatures: cpu: 41.0 C pch: 48.0 C mobo: N/A
Processes: 352 Uptime: 44m wakeups: 642 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1393 pm: pacman pkgs: 1377 libs: 402
tools: gnome-software,pamac,yay pm: flatpak pkgs: 10 pm: snap pkgs: 6
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
The first half is a double-screen animation, and the second half is an internal display only
https://youtu.be/4UUbgbh-YFM
