Dual GPU Dual Display Issues
Hello,
I just installed Manjaro and am having trouble getting my triple display setup to work. I have two displays connected to the onboard AMD GPU and one display connected to an external NVIDIA GeForce 1050 Ti. The issue is that one of the GPUs does not output any images, and the displays are not being recognized.
Prior Fixing Attempts:
- Swapped HDMI cables
- Checked functionality on Windows
- Reinstalled drivers (both OSS and non-OSS)
- Tried different versions of the NVIDIA drivers (following the wiki “guide”)
- Used the AUR version of the drivers (e.g., nvidia-open and nvidia-open-beta)
When using the “Visual-Linux” driver, it detects all my displays, but the display connected to the NVIDIA card shows half of the screen in white, with the cursor visible but windows appearing below it.
System Information:
- Desktop Environment: GNOME
inxi -zv8
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=10ce4a16-fdf0-46de-839c-2f4ec5c6d0ce rw quiet splash
resume=UUID=bcd3a6c5-f86e-4aaf-9165-2c976d1a78b5 udev.log_priority=3
nvidia-drm.modeset=1
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: B.70 date: 06/10/2020
System RAM: total: 24 GiB available: 23.17 GiB used: 4.62 GiB (19.9%)
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMW16GX4M2C3200C16 serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: 3000 C16 Series serial: N/A
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2062 min/max: 1400/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2062 2: 2062 3: 2062
4: 2062 5: 2062 6: 2062 7: 2062 8: 2062 bogomips: 59217
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
v: 550.135 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 10:00.0
chip-ID: 10de:1c82 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Micro-Star MSI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1
empty: DP-1,DVI-D-1 bus-ID: 29:00.0 chip-ID: 1002:15d8 class-ID: 0300
temp: 36.0 C
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: nvidia gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Dell E2311H serial: <filter> built: 2011
res: 1920x1080 dpi: 96 gamma: 1.2 chroma: red: x: 0.627 y: 0.349 green:
x: 0.337 y: 0.624 blue: x: 0.153 y: 0.051 white: x: 0.314 y: 0.329
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
1280x720, 1024x768, 800x600, 640x480, 720x400
Monitor-2: HDMI-A-1 model: Acer K242HYL serial: <filter> built: 2020
res: 1920x1080 dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
x: 0.318 y: 0.624 blue: x: 0.153 y: 0.078 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 2 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO)
device-ID: 1002:15d8 memory: 250 MiB unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 10:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 29:00.1 chip-ID: 1002:15de class-ID: 0403
Device-3: Razer USA RZ19-0229 Gaming Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 1532:0511 class-ID: 0300
serial: <filter>
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active
vendor: Micro-Star MSI driver: r8168 v: 8.054.00-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:2
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.13 TiB used: 10.84 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8R0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Patriot model: Burst size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: P1.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Silicon Motion model: 1000
size: 3.72 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> scheme: MBR
ID-1: / raw-size: 214.48 GiB size: 210.05 GiB (97.94%)
used: 10.84 GiB (5.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 10ce4a16-fdf0-46de-839c-2f4ec5c6d0ce
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 2BE2-422E
dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: bcd3a6c5-f86e-4aaf-9165-2c976d1a78b5
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 931.5 GiB fs: ntfs label: N/A
uuid: 3C32CFDA32CF9774
ID-3: /dev/sdc1 maj-min: 8:33 size: 2.76 GiB fs: iso9660
ID-4: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 96E6-0934
Device-1: 1-10:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Device-1: 3-2:2 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 1532:0084 class-ID: 0300
Device-2: 3-3:3 info: Razer USA RZ19-0229 Gaming Microphone
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
chip-ID: 1532:0511 class-ID: 0300 serial: <filter>
Device-3: 3-4:4 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
Drive type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Logitech G213 Prodigy Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 36.5 C mobo: 35.5 C gpu: amdgpu temp: 36.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 909 libs: 296 tools: gnome-software,pamac,yay
1: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
2: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
3: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 310
1: cpu: 100% command: ps pid: 7547 mem: 3.57 MiB (0.0%)
2: cpu: 31.3% command: firefox pid: 1864 mem: 830.6 MiB (3.5%)
3: cpu: 23.1% command: firefox pid: 2026 mem: 154.9 MiB (0.6%)
4: cpu: 14.0% command: firefox pid: 2177 mem: 415.3 MiB (1.7%)
5: cpu: 13.1% command: gnome-shell pid: 1336 mem: 322.4 MiB (1.3%)
Memory top: 5 of 310
1: mem: 830.6 MiB (3.5%) command: firefox pid: 1864 cpu: 31.3%
2: mem: 430.2 MiB (1.8%) command: firefox pid: 2304 cpu: 2.9%
3: mem: 415.3 MiB (1.7%) command: firefox pid: 2177 cpu: 14.0%
4: mem: 369.3 MiB (1.5%) command: firefox pid: 4057 cpu: 4.5%
5: mem: 322.4 MiB (1.3%) command: gnome-shell pid: 1336 cpu: 13.1%
Processes: 310 Power: uptime: 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.23 GiB services: gsd-power,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: gnome-terminal
inxi: 3.3.37
Kernel Information:
- Currently running: `6.12.4-1-MANJARO (linux612)`
- Installed kernels:
- linux612
PCI Devices:
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7a38
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
Subsystem: Device 7a38:1462
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
10:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
Subsystem: ASUSTeK Computer Inc. Device 864b
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
10:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
12:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 xHCI Compliant Host Controller (rev 01)
Subsystem: ASMedia Technology Inc. Device 1142
Kernel driver in use: xhci_hcd
12:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller (rev 01)
Subsystem: ASMedia Technology Inc. Device 1062
Kernel driver in use: ahci
12:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge (rev 01)
Subsystem: ASMedia Technology Inc. Device 0201
20:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
Subsystem: ASMedia Technology Inc. Device 3306
20:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
20:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
20:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
25:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Kernel driver in use: r8168
Kernel modules: r8169, r8168
29:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] (rev c8)
Kernel driver in use: amdgpu
Kernel modules: amdgpu
29:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
29:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
29:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
29:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
2a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61)
Drivers
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-vesa 2017.03.12 true PCI
video-linux 2024.05.06 true PCI
video-hybrid-amd-nvidia-prime 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
network-r8168 2023.09.12 true PCI
Relevant Error Messages:
$ journalctl --boot=-1 --priority=3 --catalog --no-pager
Jan 13 21:36:10 jodokus-ms7a38 kernel: amdgpu 0000:29:00.0: amdgpu: Secure display: Generic Failure.
Jan 13 21:36:10 jodokus-ms7a38 kernel: amdgpu 0000:29:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Any information or suggestions would be greatly appreciated.
