I installed Manjaro Gnome and then I installed KDE as the second desktop environment and after installing I encounter these problems!
How to solve it?
This is not a Manjaro problem but a user problem.
Decide for one and remove the other.
There has been a couple of topics discussing why it is a bad idea to mix Gnome and Plasma.
Please see Search results for 'install gnome and plasma on same system' - Manjaro Linux Forum
Some even claim it has never been proved it is a bad idea.
Your topic is a fine example of why you shouldn’t mix Gnome and Plasma.
I renamed your topic to reflect the real issue
Nice picture - I don’t see any problems in it or with it. ![]()
Plasma seems to be in use …
- Decide which DE you want to use.
- Reinstall Manjaro with only the DE you want to use.
- Do not install any other DEs.
- Enjoy Manjaro
P.S: I suggest KDE (it works well with Wayland if using amdgpu).
Cheers.
That’s the solution, but I can’t decide what to use kde or gnome as the two are the most popular!
But there is a way to install manjaro a arch linux installation?
Do you use an AMD or Nvidia graphics card?
Or, better still, could you provide output from this command?
We might be able to help you choose, if we know more about your system.
I use amd (on real machine)!
Please, stop posting pictures if you could have posted the text, alternatively.
@linux-aarhus told you all you need to know - mixing Plasma and Gnome in one install is a no-brainer and always has been. If you like both DE’s, implement a dual boot case, use the same user name then and share all your data in a separate data partition which both installs can access, then you can quickly switch and have full access to all your data. ![]()
OK, then I’d recommend KDE rather than Gnome.
Now, you can delete those screenshots (they annoy the older folk).
Cheers.
Sorry but I can’t copy text because I don’t want to install VMware tools and I need to screenshot these
How?Please help me!
@VictorGeorgianDragan I restored the replies you deleted. Installing Manjaro in a virtual machine using proprietary tools makes a huge difference versus installing normally. Helpful volunteers need more information in order to help you.
Please see:
