Hello everyone,
I am having troubles dual booting my system.
Goal: Two separate Linux systems on one drive, using same boot and swap partition. One is for aimed for my work and one for me privately.
What I did: Created the partitions with an GPT partition table, boot, swap, root-work, root-private and one home partition (only for root-private). Installed Manjaro (i3wm edition) on both root partitions separately, successfully.
Installed systemd-boot. All necessary files (vmlinuz, initramfs) are in /boot. Created two entries in /boot/loader/entries/system1.conf and system2.conf with the PARTUUID from blkid.
Problem: system1 boots without problems, but when I try to boot system2 (via the menu form systemd-boot during startup) it tells me:
[FAILED] Failed to mount /boot.
See âsystemctl status boot.mountâ for details.
[FAILED] Dependency failed for Local File Systems.
At the bottom is a âemergency consoleâ but it wont let me log in (no response whatsoever). I can only hard shut down.
I also checked the partition with fsck.ext4, but no problems reported.
The strange thing (in my point of view) is that one system works and one doesnât, while both should be the same (manjaro) and both have âsameâ boot and /etc/fstab entries (except PARTUUID information of course).
Any suggestions, ideas, help?
Thanks a lot
