I made the Manjaro installation USB with Etcher on Win10. Not sure if this makes a difference.
I am trying to install Manjaro on a MacBook Air 11" (2010) that has OSX Catalina (APFS). I installed rEFInd through OSX. Rebooted. At rEFInd I loaded up the installation USB and made my way through till “Partitions”. Once there, I did the following.
Clicked on “Manual partitioning”
Created a new “/boot/efi” partition, 300MB, FAT32, Flagged “/boot” and “/boot/efi”
Created a new OS partition, 55GB, ext4, Mount Point “/”
Created a swap partition, 2GB, linuxswap
After the installation and restart, I get some weird error msgs. I reboot + hold down Option key. Boot into OSX then reinstall rEFInd. Reboot again to rEFInd screen. Boot into Manjaro. I get a “failed to start light display manager” msg and it just hangs there. What am I doing wrong? I would appreciate any help.
Sincerely,
Girl Lost in Manjaro
