Sound works fine if I don’t mute->unmute it, when I mute and unmute it then it won’t play any sound on my speakers. If I reset my audio interface (drivers) with sudo alsactl init
it starts playing sounds again, but if i mute/unmute it than stops again! Any fix for this?
When I had sound problems in Linux, I usually turned the sound all the way up in windows and then booted into linux.
Also make sure fast shutdown is disabled in windows.
