marko
21 April 2021 20:56
1
About the system, briefly :
Lenovo G50-70
dual boot Windows 10 & Manjaro Linux 21.0
Description of the issue :
When I boot into anything else besides Windows 10 by putting it on the 1st spot in the boot order in the UEFI firmware menu, the system boots into grub as it should.
After a restart I get greeted with the error message Default Boot Device Missing or Boot Failed
“OK” gets me to an empty menu and if I restart via power button, the system boots to Windows as if there is no issue at all.
If the boot order is to be checked, it is automatically reset to Windows being first in the list. (BTW, if I go to the boot menu in the UEFI firmware and boot directly to an entry there, no issues booting - that’s how I am writing from Manjaro)
What I already tried :
I know for a fact, it is not a Manjaro issue. Have had it for a month since trying to boot Manjaro from a flash drive while running Windows in “dual” boot with Linux Mint (used it in dual boot with Win10 before switching to Manjaro). That much I have realized so far.
It might be that my UEFI fiormware got jinxed back then, since my USB Flash Drive didn’t have a separate EFI partition on it, and the UEFI firmware treated the Drive as the internal disk.
The output to test -d /sys/firmware/efi && echo efi || echo bios
efi
efibootmgr --verbose
Timeout: 0 seconds
BootOrder: 0000,0001,2001,2002,2003
Boot0000* Windows Boot Manager HD(2,GPT,f6bb127c-dc18-43d9-9c7e-40d5350213af,0xe1800,0x31800)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC
Boot0001* ubuntu HD(2,GPT,f6bb127c-dc18-43d9-9c7e-40d5350213af,0xe1800,0x31800)/File(\EFI\ubuntu\grubx64.efi)RC
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
Inxi
Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=794d3601-1eb1-4a4f-bcb8-ea0b95597e01 rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70 serial: <filter>
Chassis: type: 10 v: Lenovo G50-70 serial: <filter>
Mobo: LENOVO model: Lancer 5A2 v: 31900058STD serial: <filter> UEFI: LENOVO
v: 9ACN32WW date: 07/20/2015
ID-1: BAT0 charge: 25.3 Wh (100.0%) condition: 25.3/31.7 Wh (79.9%)
volts: 15.8 min: 14.4 model: Lenovo IdeaPad type: Unknown serial: <filter>
status: Full
RAM: total: 7.67 GiB used: 1.92 GiB (25.1%)
Info: Dual Core model: Intel Core i3-4010U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 3 MiB bogomips: 13568
Speed: 798 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 798 2: 799 3: 798
4: 798
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu bus-ID: 03:00.0
chip-ID: 1002:666f class-ID: 0380
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 2-6:4
chip-ID: 5986:0652 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.0.2 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
vendor: Lenovo driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lenovo driver: ath9k v: kernel port: 4000 bus-ID: 02:00.0
chip-ID: 168c:0036 class-ID: 0280
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 2-7:6 chip-ID: 0cf3:3004 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 70.42 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G1B0A-00H9H0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-1: / raw-size: 125 GiB size: 122.48 GiB (97.98%) used: 41.05 GiB (33.5%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 794d3601-1eb1-4a4f-bcb8-ea0b95597e01
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 25.7 MiB (27.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 10C2-A921
ID-3: /home raw-size: 340.75 GiB size: 334.34 GiB (98.12%)
used: 6.83 GiB (2.0%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 9728ace2-e6fa-4e47-8172-f7ce92ccec79
ID-4: /run/timeshift/backup raw-size: 100.1 GiB size: 97.97 GiB (97.87%)
used: 22.52 GiB (23.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: Manjaro TS uuid: 0479f80e-bc9c-4d6d-85f8-39cac1857ad9
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Recovery
uuid: 08382A8F382A7BB6
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 464.65 GiB fs: ntfs label: N/A
uuid: 38C6C4EFC6C4AF06
ID-4: /dev/sda5 maj-min: 8:5 size: 569 MiB fs: ntfs label: N/A
uuid: 0494DE8294DE75A0
ID-5: /dev/sdb2 maj-min: 8:18 size: 365.66 GiB fs: vfat label: CROSS-SHARE
uuid: 0998-C9EE
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 2-3:2 info: Logitech G102 LIGHTSYNC Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
Device-2: 2-4:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 2-6:4 info: Acer Lenovo EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:0652
Device-4: 2-7:6 info: Qualcomm Atheros AR3012 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 45.0 C
Processes: 219 Uptime: 16m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1302 apt: 0 pacman: 1297
lib: 328 flatpak: 0 snap: 5 Shell: Zsh v: 5.8 running-in: tilix inxi: 3.3.04``
I’ve followed this post to get Manjaro to appear.
Ideas so far :
Recently figured that flashing the UEFI firmware with a new image might solve the issue. It’s just that it is a very destructive option if it backfires, and there might be some less destructive ways to deal with it which I might not be aware of as I am very new to this topic.
Are there any ideas what I can try, so booting directly via grub can be possible again?
Really don’t want to render my only Laptop unbootable if there are better avenues to pursue than flashing the UEFI firmware.
marko
23 April 2021 18:50
2
Update : Reflashed my BIOS with more up to date version.
Results : New BIOS firmware version; other than that - none. The issue persists as it was.
Conclusions : The issue is either my new 1 TB SSD or there is something in Manjaro. The latter unlikely.
Fabby
23 April 2021 18:51
3
OK, the way you installed your system is by using the UEFI firmware, so what you’re seeing is a “feature” of said firmware.
As you didn’t post an inxi --admin --verbosity=7 --filter --no-host --width
we’re a bit in the dark here, boot looking at the symptoms of your issue, there is no way of Manjaro / Mint / Windows changing anything as the UEFI firmware runs above the OS .
So if you want to change anything:
You have to take a different option in UEFI
You’re in for a complete reinstall of Manjaro…
You might be in for a W10 reinstall if you change that option (though that’s very unlikely)
How do you want to proceed???
Live with it the way it is…
Change!
marko
23 April 2021 18:55
4
Here is my inxi. A a novice, didn’t know/think about it:
status: Full
4: 798
scheme: GPT
uuid: 10C2-A921
file: /swapfile
uuid: 0998-C9EE
lib: 328 flatpak: 0 snap: 5 Shell: Zsh v: 5.8 running-in: tilix inxi: 3.3.04```
marko
23 April 2021 19:03
5
Are you offering something with installing Manjaro in BIOS mode?
I attempted it, but I probably should not have let Calamares to carry me through BIOS mode install automatically
I have Backup of my homefolder on cloud via Deja Dup program (or “app”, as it is hip to say nowadays) and I have timeshift on a separate internal SSD. Windows is also backed up, so I have probably nothing to loose.
Can reinstalling windows be substituted with restoring system image?
marko
23 April 2021 19:30
7
It says efi. For that install I did nothing with UEFI system.
I tried once BIOS installation, but Calamares somehow filled up my 100 MB ESP so I needed to restore my system from back up to undo it. Since it was BIOS install, it shouldn’t have did anything with ESP, as far as I understand.
Can the issue be caused by a new SSD drive? That is the main drive right now, with the ESP.
Fabby
23 April 2021 19:37
8
Note 1: Well, except that you don’t have a Manjaro issue but an UEFI issue. Let me go grab the old Lenovo I’ve got lying around and check the UEFI menu…
marko
23 April 2021 19:41
9
Timeout: 0 seconds
ubuntu is the Manjaro boot loader. That is a fix for another “feature” of UEFI firmware → UEFI: Manjaro is missing
Manjaro folder and bootloader under the name of “Manjaro” actually exists in /boot/efi/EFI, UEFI just deosn’t acknowledge it.
Fabby
23 April 2021 19:57
10
Oh ooh… No wonder you’re having troubles!
Lemme boot my Lenovo (spare laptop in case my main one crashes) I’ve got lying around (It’s a single boot Manjaro only) and I’ll get back to you…
marko
23 April 2021 19:59
11
Is there something wrong with the instructions in the thread. That was the only possible way to get Manjaro into the boot menu.
Fabby
23 April 2021 20:06
12
My Lenovo is dead , but there should be a menu item in the UEFO settings to add additional .efi
files except the one from Micro$oft. I’m going to try and call in someone who has a Lenovo from the chat channel to help you trhough the initial setup using UEFI.
The article you linked to is 3 years old and is for a Yoga, not for a G50…
marko
23 April 2021 20:08
13
Yes I am aware.
There is also another thing. There are Lenovo InsydeH20 firmware laptops which have it. Mine doesn’t have a menu to add a trusted efi file. I am really limited to some other guys with Lenovo, who are able to do that.
I was partially hoping that by updating firmware I get those menues, it is not the case. My bios chip is probably very old. Last updated firmware is from the year 2015 and I didn’t have the latest version on my bios.
Fabby
24 April 2021 19:55
14
@stephane I know you’re a wizard at UEFI and I’m stuck here but I’ve copied all the Root Cause Analysis into the Original Post.
Could you have a look, SVP?
what have you done exactly on with ubuntu efi folder ?
if you have copied manjaro folder inside ubuntu folder it will not works
=> delete entre UEFI
sudo efibootmgr -b 0001 -B
==> then redo grub -install with chroot
check info in your UEFI motherboard
disable secure boot
disable fast boot
disks on AHCI
no legacy
no CSM
UEFI only or others ( not windows )
you should see
UEFI < USB vendor name > < partition 1 > → boot in EFI
open a terminal and check
inxi -Mxa ( check for UEFI only )
sudo lsbk -fs ( check uuid /boot/efi)
sudo parted -l ( check flag boot & esp on /boot/efi )
sudo manjaro chroot -a
cat /etc/fstab ( check /boot/efi & UUID here )
exit
marko
24 April 2021 21:56
16
I did that.
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=ubuntu --recheck --debug
Basically what you said From the old article above.
So just the boot entry. Does efibootmgr remove the folder form /boot/efi/EFI as well?
Do I need live USB starting from here, or I can do it from the disk? (will perform when you explain)
disable secure boot ---- check
disable fast boot ---- check
disks on AHCI ---- check
no legacy ---- check
no CSM ---- check
UEFI only or others ( not windows ) ---- what do you mean?
UEFI only boot ---- check
Additional info requested:
inxi -Mxa ✔
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-70
Mobo: LENOVO model: Lancer 5A2 v: 31900058STD serial: <superuser required>
UEFI: LENOVO v: 9ACN32WW date: 07/20/2015
sudo lsblk -fs 127 ✘
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0
squash 4.0 0 100% /var/lib/s
loop1
loop2
loop3
loop4
sda1 ntfs Recovery
│ 08382A8F382A7BB6
└─sda
sda2 vfat FAT32 10C2-A921 69,3M 27% /boot/efi
└─sda
sda3
└─sda
sda4 ntfs 38C6C4EFC6C4AF06
└─sda
sda5 ntfs 0494DE8294DE75A0
└─sda
sda6 ext4 1.0 794d3601-1eb1-4a4f-bcb8-ea0b95597e01 74,9G 34% /
└─sda
sda7 ext4 1.0 9728ace2-e6fa-4e47-8172-f7ce92ccec79 310,4G 2% /home
└─sda
sdb1 ext4 1.0 Manjaro TS
│ 0479f80e-bc9c-4d6d-85f8-39cac1857ad9 65G 29% /run/times
└─sdb
sdb2 vfat FAT32 CROSS-SHARE
│ 0998-C9EE
└─sdb
Can’t performed chroot as described but here is the content of fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=10C2-A921 /boot/efi vfat umask=0077 0 2
UUID=794d3601-1eb1-4a4f-bcb8-ea0b95597e01 / ext4 defaults,noatime 0 1
UUID=9728ace2-e6fa-4e47-8172-f7ce92ccec79 /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
/swapfile none swap defaults 0 0
Did the part I understood, will check wiki or something for other things tomorrow in the day time
Thanks a lot stephane!!!
marko
24 April 2021 22:16
18
Then I read up correctly. Just rechecking with knowledgeable people.
Fabby
24 April 2021 22:21
19
FYI: efibootmgr
just controls the UEFI NVRAM, not the ESP …
missing this
so you confirm that
sda2 & sda6&sda7 is for manjaro , not other distribution ?
